Homeassistant version 0.115.2 with Supervisor 245.
Unsupported as its running in docker-ce 19.03.13
on Ubuntu 18.04.5 LTS.
The logs in Owncloud state the following:
I have an internal certificate authority and all other aspects of hassio (supervised) work well. my access is via https for everything. It is not exposed to the Internet but even internally I like security as it is defense in depth.
On the same node (PC) I have an instance of Owncloud. I can access this via https://server/
But for some reason I cannot connect via ical? My config is as follows:
calendar:
- platform: caldav
username: !secret davname
password: !secret caldav
url: !secret calurl
verify_ssl: false
custom_calendars:
- name: skutter
calendar: personal
search: '.*'
From my owncloud log I get:
{"reqId":"hcNG4vUe7suKyHBalDJS","level":0,"time":"2020-09-23T20:25:19+00:00","remoteAddr":"192.168.161.50","user":"--","app":"webdav","method":"PROPFIND","url":"\/remote.php\/dav\/","message":"Exception: HTTP\/1.1 401 No public access to this resource., No 'Authorization: Basic' header found. Either the client didn't send one, or the server is misconfigured, No 'Authorization: Basic' header found. Either the client didn't send one, or the server is misconfigured: {\"Exception\":\"Sabre\\\\DAV\\\\Exception\\\\NotAuthenticated\",\"Message\":\"No public access to this resource., No 'Authorization: Basic' header found. Either the client didn't send one, or the server is misconfigured, No 'Authorization: Basic' header found. Either the client didn't send one, or the server is misconfigured\",\"Code\":0,\"Trace\":\"#0 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/event\\\/lib\\\/WildcardEmitterTrait.php(96): Sabre\\\\DAV\\\\Auth\\\\Plugin->beforeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#1 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(448): Sabre\\\\DAV\\\\Server->emit('beforeMethod:PR...', Array)\\n#2 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(241): Sabre\\\\DAV\\\\Server->invokeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#3 \\\/var\\\/www\\\/owncloud\\\/apps\\\/dav\\\/lib\\\/Server.php(326): Sabre\\\\DAV\\\\Server->start()\\n#4 \\\/var\\\/www\\\/owncloud\\\/apps\\\/dav\\\/appinfo\\\/v2\\\/remote.php(31): OCA\\\\DAV\\\\Server->exec()\\n#5 \\\/var\\\/www\\\/owncloud\\\/remote.php(165): require_once('\\\/var\\\/www\\\/ownclo...')\\n#6 {main}\",\"File\":\"\\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Auth\\\/Plugin.php\",\"Line\":161}"}
{"reqId":"Usnd0GLc3LxBu1tNHClU","level":0,"time":"2020-09-23T20:25:19+00:00","remoteAddr":"192.168.161.50","user":"--","app":"OC\\Authentication\\Token\\DefaultTokenProvider::invalidateToken","method":"PROPFIND","url":"\/remote.php\/dav\/","message":"invalidating token 4ab4c4992f6314f9743ae5901c858b0fa77ef25650a00c6aa8b34b32c1bea4c0870597213bc11ce370264184de992f26ff6995c3b5ede84bfec1c95cd3478b94"}
Now I have followed the many links I have found via Owncloud and Nextcloud but from all the advice given there I have still drawn a blank?
I have tried the following:
127.0.0.1
localhost
FQDN
Machine name
Network IP
but still no entries under My Calender’s?
Access from my android phone and tablet work fine as does Thunderbird on my desktop and also webdav via Nemo? I have also verified that Apache is set correctly.
All assistance would be appreciated!
