Sounds similar indeed ! Are you using the custom component or did you define the camera yourself in your HA config ?
Just installed HA OS on a NUC8 and am trying to use the M.2 Coral Accelerator M.2 PCI but so far itās not being detected. I concluded that this is due to missing drivers. Since HA OS is different from Debian I canāt use the instructions on the coral.ai website.
Any help would be appreciated.
Update: I decided to install Home Assistant Supervised on Debian 10 in order to be able to install the required drivers
Custom component and the snapshot is of the camera that it creates. This is so I get the frame where the object was detected with the bounding box.
am I completely wrong or blind but I cannot fugure out the binary_sensors for motion detection (if such existā¦) all other stuff works great⦠when person detect (motion detection ??) then it records as expected. Now i wanted to use this as a trigger. Possibe? I use hassio Addon with custom component but no motion sensors are created
Its
sensor.<camera_name>_person
and it shows ā0ā changing to ā1ā when a person is detected.
binary sensors config
binary_sensor:
sensors:
driveway_person_motion:
delay_off: 5
device_class: motion
friendly_name: "Driveway Person Motion"
availability_template: "{{ states('sensor.driveway_person') not in ('unknown', 'unavailable') }}"
value_template: "{{states('sensor.driveway_person')|float > 0}}"
driveway_cat_motion:
delay_off: 5
friendly_name: "Driveway Cat Motion"
availability_template: "{{ states('sensor.driveway_cat') not in ('unknown', 'unavailable') }}"
value_template: "{{states('sensor.driveway_cat')|float > 0}}"
garden_person_motion:
delay_off: 5
friendly_name: "Garden Person Motion"
availability_template: "{{ states('sensor.garden_person') not in ('unknown', 'unavailable') }}"
value_template: "{{states('sensor.garden_person')|float > 0}}"
garden_cat_motion:
delay_off: 5
friendly_name: "Garden Cat Motion"
availability_template: "{{ states('sensor.garden_cat') not in ('unknown', 'unavailable') }}"
value_template: "{{states('sensor.garden_cat')|float > 0}}"
Thanks a lot for your reply but my sensors sensor.xxx_person is always unavailable.
But I get Vdeos / Clips when motion detected.
This is my config:
detectors:
coral:
type: edgetpu
device: 'usb:0'
mqtt:
host: 192.168.1.41
ffmpeg:
global_args:
- '-hide_banner'
- '-loglevel'
- panic
hwaccel_args:
- '-hwaccel'
- vaapi
- '-hwaccel_device'
- /dev/dri/renderD128
- '-hwaccel_output_format'
- yuv420p
input_args:
- '-avoid_negative_ts'
- make_zero
- '-fflags'
- nobuffer
- '-flags'
- low_delay
- '-strict'
- experimental
- '-fflags'
- +genpts+discardcorrupt
- '-rtsp_transport'
- tcp
- '-stimeout'
- '5000000'
- '-use_wallclock_as_timestamps'
- '1'
cameras:
front_door:
save_clips:
enabled: true
pre_capture: 30
ffmpeg:
inputs:
- path: 'rtsp://hass:[email protected]:88/videoMain'
roles:
- detect
- rtmp
- clips
- record
width: 1280
height: 720
fps: 5
record:
enabled: true
retain_days: 1
porch:
save_clips:
enabled: true
pre_capture: 30
ffmpeg:
inputs:
- path: 'rtsp://hassio:[email protected]:554/stream2'
roles:
- detect
- rtmp
- clips
- record
width: 1280
height: 720
fps: 5
record:
enabled: true
retain_days: 1
garage:
save_clips:
enabled: true
pre_capture: 30
ffmpeg:
inputs:
- path: 'rtsp://40.40.40.220:554/media/stream1'
roles:
- detect
- rtmp
- clips
- record
width: 1280
height: 720
fps: 5
record:
enabled: true
retain_days: 1
garden:
save_clips:
enabled: true
pre_capture: 30
ffmpeg:
inputs:
- path: 'rtsp://40.40.40.14:554/media/stream1'
roles:
- detect
- rtmp
- clips
- record
width: 1280
height: 720
fps: 5
record:
enabled: true
retain_days: 1
any idea?
Make a username and password for mqtt would be my suggestion.
THAT! indeed worked!! great thanks! Another āissueā is that I cannot make any modifications to the MQTT part for my cams like:
# Optional: Configuration for the jpg snapshots published via MQTT
mqtt:
# Optional: Enable publishing snapshot via mqtt for camera (default: shown below)
# NOTE: Only applies to publishing image data to MQTT via 'frigate/<camera_name>/<object_name>/snapshot'.
# All other messages will still be published.
enabled: True
# Optional: print a timestamp on the snapshots (default: shown below)
timestamp: True
# Optional: draw bounding box on the snapshots (default: shown below)
bounding_box: True
# Optional: crop the snapshot (default: shown below)
crop: True
# Optional: height to resize the snapshot to (default: shown below)
height: 270
config tells me that mqtt is not valid. I am using beta and hassio addon and it seems that this config is not valid?
where did you got that example? i think those are configured under the snapshot section:
# Optional: Configuration for the snapshots in the debug view and mqtt
snapshots:
show_timestamp: True
# Optional: draw zones on the debug mjpeg feed (default: shown below)
draw_zones: False
# Optional: draw bounding boxes on the mqtt snapshots (default: shown below)
draw_bounding_boxes: True
I had the same thought at first, but they are there in the readme for the beta.
I tried to add them in and just got:
ERROR : Error parsing config: extra keys not allowed
I have also the full size frame using camera.snapshot on the cameras created by the custom component, however, only on the MQTT cameras created for each object (camera.<camera_name>_person, camera.<camera_name>_dog, etc.) but not on the RTMP cameras created by the custom component (camera.<camera_name>).
You can see the difference using HA Developers Tools -> Services:
camera.snapshot
entity_id: camera.<camera_name>_person
filename: '/config/www/test_person.jpg'
and then:
camera.snapshot
filename: '/config/www/test_view.jpg'
You should get different frame size.
exactly! I used this docs⦠well then i would like to know where to configure the snapshot⦠my resolution is too small ⦠i donāt recognise anything on it
antoher issue is that it will not create other sensors camera etc than person⦠thozght by standard it will have object for person vehicle and animals ? who has other than person up and running?
again my config:
http://pastebin.ddns.me/qobareduya.bash
if spmeone culd point me to the right docs / running config
Now I see where we differ. I donāt use the other cameras generated by frigate. I only use the ones for object detection.
I donāt recall where I read it, but I think Blake mentioned having snapshots saved to the media folders as something on the roadmap so there could be changes to come.
You could probably make an issue on github for this to get his attention.
I added some zones on some of my cameras so i could use the sensors provided just to turn on lights. But the parent camera setting are tracking different objects (person, cat). Is it possible to exlude detenction for cat in a zone but keep traked for the parent camera?
Can you not just use a condition in your automation Iād it detects a person @Melkor82
I can but i got saved pics for cats in that zone too, flooding my media folder
How did u get cats detection working? I only get person.
Cat and dog detection is highly dependent on your cameraās position. The models used a trained from straight on, rather than typical security camera position of being above. This makes mine miss quite a few and often mis-categorizes people as dogs.
Haha⦠well that explains why my wife (nearly) always is recognized as a dog⦠Couldnāt explain it to her.
