Can someone explain to me why my video is shown with 5 pics /s? this si my config:
running on intel NUC i5 with coral but the camera stream is NEVER fluent
If I activate the stream compoennt i get the whole speed BUT delayed like hell.
detectors:
coral:
type: edgetpu
device: pci
mqtt:
host: 192.168.1.41
port: 1883
topic_prefix: frigate
client_id: frigate
user: hass
password: hass
ffmpeg:
global_args:
- "-hide_banner"
- "-loglevel"
- panic
hwaccel_args:
- -hwaccel
- vaapi
- -hwaccel_device
- /dev/dri/renderD128
- -hwaccel_output_format
- yuv420p
input_args:
- -avoid_negative_ts
- make_zero
- -fflags
- nobuffer
- -flags
- low_delay
- -strict
- experimental
- -fflags
- +genpts+discardcorrupt
- -use_wallclock_as_timestamps
- '1'
output_args:
# Optional: output args for detect streams (default: shown below)
detect: -f rawvideo -pix_fmt yuv420p
# Optional: output args for record streams (default: shown below)
record: -f segment -segment_time 60 -segment_format mp4 -reset_timestamps 1 -strftime 1 -c copy -an
# Optional: output args for clips streams (default: shown below)
clips: -f segment -segment_time 10 -segment_format mp4 -reset_timestamps 1 -strftime 1 -c copy -an
# Optional: output args for rtmp streams (default: shown below)
rtmp: -c copy -f flv
objects:
# Optional: list of objects to track from labelmap.txt (default: shown below)
track:
- person
# - cat
# - dog
- car
- bicycle
# - bird
cameras:
front_door:
ffmpeg:
inputs:
- path: rtsp://hass:[email protected]:88/videoMain
roles:
- detect
- rtmp
- clips
- record
width: 1280
height: 720
fps: 23
record:
enabled: true
retain_days: 7
# Optional: Configuration for the jpg snapshots written to the clips directory for each event
snapshots:
# Optional: Enable writing jpg snapshot to /media/frigate/clips (default: shown below)
# This value can be set via MQTT and will be updated in startup based on retained value
enabled: true
# Optional: print a timestamp on the snapshots (default: shown below)
timestamp: true
# Optional: draw bounding box on the snapshots (default: shown below)
bounding_box: true
# Optional: crop the snapshot (default: shown below)
crop: False
# Optional: height to resize the snapshot to (default: original size)
# height: 175
# Optional: Camera override for retention settings (default: global values)
retain:
# Required: Default retention days (default: shown below)
default: 7
# Optional: Per object retention days
objects:
person: 7
clips:
# Required: enables clips for the camera (default: shown below)
enabled: true
# Optional: Number of seconds before the event to include in the clips (default: shown below)
pre_capture: 5
# Optional: Number of seconds after the event to include in the clips (default: shown below)
post_capture: 5
# Optional: Objects to save clips for. (default: all tracked objects)
objects:
- person
retain:
default: 7
objects:
person: 7
zones:
parking:
coordinates: '554,333,611,274,708,281,763,265,823,260,948,285,1021,341,1078,359,1102,387,1137,381,1154,417,1120,596,760,504,754,318'
mailbox:
coordinates: '416,454,434,401,387,346,336,395,337,446'
main_door:
coordinates: '1200,697,1159,699,1071,699,936,695,553,663,530,449,1280,420'
porch:
ffmpeg:
inputs:
- path: rtsp://hassio:[email protected]:554/stream1
roles:
- detect
- rtmp
- clips
- record
width: 1920
height: 1080
fps: 23
record:
enabled: true
retain_days: 7
snapshots:
enabled: true
timestamp: true
bounding_box: true
crop: False
# height: 175
retain:
default: 7
objects:
person: 7
clips:
enabled: true
pre_capture: 5
post_capture: 5
objects:
- person
retain:
default: 7
objects:
person: 7
zones:
door_porch_dining_room:
coordinates: '1243,1080,1292,85,961,162,929,1080'
garage:
ffmpeg:
inputs:
- path: rtsp://40.40.40.220:554/media/stream1
roles:
- detect
- rtmp
- clips
- record
width: 1280
height: 720
fps: 23
record:
enabled: true
retain_days: 7
zones:
garage_door:
coordinates: 0,158,0,504,383,493,397,213
refrigiator:
coordinates: '1186,259,1159,665,1038,646,1070,259'
table:
coordinates: '269,486,0,486,0,720,142,720,592,720,256,482,145,720,376,720,588,720'
window_front_house:
coordinates: '599,265,605,419,507,418,514,250'
snapshots:
enabled: true
timestamp: true
bounding_box: true
crop: False
# height: 175
retain:
default: 7
objects:
person: 7
clips:
enabled: true
pre_capture: 5
post_capture: 5
objects:
- person
retain:
default: 7
objects:
person: 7
garden:
ffmpeg:
inputs:
- path: rtsp://40.40.40.14:554/media/stream1
roles:
- detect
- rtmp
- clips
- record
width: 1280
height: 720
fps: 23
record:
enabled: true
retain_days: 7
snapshots:
enabled: true
timestamp: true
bounding_box: true
crop: False
# height: 175
retain:
default: 7
objects:
person: 7
clips:
enabled: true
pre_capture: 5
post_capture: 5
objects:
- person
retain:
default: 7
objects:
person: 7
