OK, I got the RTMP stream working for my sub stream, but do I have to add the main stream as a different camera? They obviously have different heights and widths and FPS, as well as different roles
Do I need to do something like front_door_sub and fill that out and another one named front_door_main?
yes, thats where I am basing all of my work on, trust me, Id much rather have this working on my own instead of asking for help on the forum.
however, my substream has a different height/width/fps from my main stream, when inputting two paths like the example, and input a height/width/fps for either one of my streams, I get a broken frame error.
If I remove one input for example the main stream, and give it the correct width/height/fps it works, however, I want to set it up as in the example with each cam having a sub/main stream.
The fps and resolution only applies to the detect input. Everything else is pass-through from the camera. Check the comments in the full example config.
Also, if youāre getting a broken frame error, you can enable debugging to see exactly whatās going wrong.
Well, iāve been using it on my ZoneMinder setup with various results.
I finally made shut down on that system and handed over the surveillance work to Frigate!
With that said⦠i now have a free Coral laying around.
Iāve just had a look through the documentation again and couldnāt find it. Is it possible to change the date format to day/month/year ? Also how do i show the media browser in the sidebar as shown in some of the examples in the documentation?
Absolutely. You can add a second coral in the detector config. Both will process the detection queue in parallel, so your max fps will be over 200fps if you are getting <10ms inference times.
If we up the fps does this affect CPU? What are the advantages of a higher detect fps? Iāve got a nuc style mini pc which has a slow Intel n4000 CPU but itās cheap and has 2 x m.2 PCIe slots and Sata! So naturally Iāve got both slots with corals in now
From what I can tell, from my experiments with Frigate, Coral and docker is that the M.2 versions need the driver installing. HassOS doesnāt have this afaik. The USB version however, doesnāt need the driver. Iām now running on Openmediavault which is Debian but I had to install the proxmox kernel to get the Coral drivers to compile correctly. OMV is pretty nice though, most things are one click install and my Frigate box now doubles up as a file server!
I have built locally amd64nvidia and it is running well, each ffmpeg consumes 4% cpu, this is on an old quad core haswell with nvidia GT640.
I want to run this as an addon to get the ingress functionality. While looking for a solution I see that the amd64nvidia build is on docker hub. So I thought it may be easier to try to get home assistant pull that instead, so I changed Dockerfile in addons/git/ccab4aaf to reference that. Then I guess there are other options needed, like the NVIDIA* environment variables, also runtime=nvidia. I am having trouble mapping the docker run command I use to config.json - Is that the best way?
edit: adding nvidia on the end the the line on Dockerfile causes home assistant to pull that image from the docker hub. However ffmpeg will not run with -c:v h264_cuvid because it wants libncuvid. I think this is to do with passing the gpu into dockerā¦
edit2: Got it working by adding the NVIDIA env stuff to config.json and adding a default runtime of nvidia in /etc/docker/daemon.json as documented in this thread.
Hello.
I want my clip recordings to be longer, I am finding one event gets spread over two or three clips.
Part of the problem may be that the object (such as a delivery person) walks into the front gate up to the door and then disappears when they are immediately under the porch. They then ring the bell and leave the package, and even though itās only a few seconds this whole sequence gets cut into two or three clips.
Iāve tried playing with min_score and thresholds, max_disappeared, and max_seconds. But I am not having much success so far. I have max_disappeared set to 5fps x 10s = 50, and I thought that was the key but I have not seen a difference.
Can I do what I am looking for and what are the key parameters I should be using?
Hereās my config?
# Detector configuration and hardware acceleration flags for RPi4 64-bit
detectors:
cpu1:
type: cpu
cpu2:
type: cpu
ffmpeg:
hwaccel_args:
- -c:v
- h264_v4l2m2m
# What to look for and how much confidence to require
objects:
track:
- person
- dog
- car
filters:
person:
min_score: 0.5
threshold: 0.7
dog:
min_score: 0.4
threshold: 0.6
car:
min_score: 0.5
threshold: 0.7
cameras:
front:
ffmpeg:
inputs:
- path: rtsp://192.168.50.135:554/12
roles:
- detect
- rtmp
- path: rtsp://192.168.50.135:554/11
roles:
- record
- clips
width: 640
height: 352
motion:
mask:
- 640,0,640,80,0,82,0,0
clips:
enabled: true
snapshots:
enabled: true
fps: 5
detect:
# Number of frames without detection to consider object gone 10s x 5fps = 50
max_disappeared: 50
clips:
max_seconds: 300
retain:
default: 10
side note - Raspberry Pi 4, running only CPU detectors and the ffmpeg acceleration options. One camera at 5fps and the baseload is sitting on about 0.6 (Homeassistant has a bunch of other appdaemon automation too).
This might be useful to others. Its an IOS notification to the HA app, where the notification action opens the application to frigate. It uses the single mode and a delay to prevent rapid retriggers which is simpler to get working than a templat condition. I wasnāt able to get notifications with embedded working when remote from my home network, but this is a good workaround. It would be nice if I could give the URL the event ID too, but the events page does not seem to be URL addressable.
- id: "1616359370503"
alias: Notify of frigate object detection and send clip
description: ""
- platform: mqtt
topic: frigate/events
condition:
- "{{ trigger.payload_json['type'] == 'new' }}"
- service: notify.mobile_app_jason_s_iphone
message: "A {{trigger.payload_json['after']['label']}} ({{ (trigger.payload_json['after']['top_score']| float * 100) | round(0) }}%) was detected on the {{trigger.payload_json['after']['camera']}} camera"
url: /xxxxxxxx_frigate/dashboard
- service: notify.mobile_app_leonas_iphone
- delay: 180
mode: single
max_exceeded: silent
Hi @jasebob,
if i properly understand you are running Frigate on a Rasperry pi 4, thatās correct?
itās the raspi4 dedicate and doesnāt host the HA, correct?
if thatās true, what raspi OS are you running? and what docker image are you using?
So you open Frigate from HASS itself? Now that is amazing, would you mind share config where exactly it is set and how does it show? In sidebar also? much
