Local realtime person detection for RTSP cameras
Neofetch is the name of the app
can you point me to some explanation what is inference?
Can anyone offer advice to get the USB TPU working on a synology DiskStation when utilizing docker? I am a real linux novice so I am not sure if the diskstation has ā€˜driversā€™ for it and what I would need to do to pass it through to the docker instance.
If the diskstation is under linux,no drivers should be needed i think
What do you see here on your debug page? I also have 11 cameras running.
I installed the runtime software and udev rules on host mentioned in ā€œsetupā€ page at coral.ai
From the docs:
Time spent running object detection in milliseconds.
ā€œinference_speedā€: 10.48,
So basically how long until an object is identified by mobilenet or whatever frigate is using for image processing/ object detection these days.
I tried to follow the guide and got message any suggestions:
tee: /etc/apt/sources.list.d/coral-edgetpu.list: No such file or directory
deb https://packages.cloud.google.com/apt coral-edgetpu-stable main
EIDT: got this done by making the directory first. which i needed to do using ā€˜sudo mkdirā€™
Did you add coral library to apt sources list?
echo "deb https://packages.cloud.google.com/apt coral-edgetpu-stable main" | sudo tee /etc/apt/sources.list.d/coral-edgetpu.list
curl https://packages.cloud.google.com/apt/doc/apt-key.gpg | sudo apt-key add -
sudo apt-get update
EDIT
Since it is synology Iā€™m not sure if this apply since I know some things donā€™t follow Linux way exactly
it turns out synology does not have ā€˜aptā€™
Im not sure but Inference has something to do with picture processing, if you have Coral the inference could be below 10ms
Raspberry pi 4 - im getting 180ms with 3 full hd cameras without hw acceleration
T420 HP with N4000 and 600 GPU - 1200ms with the same 3 cameras.
Both without Coral
For some reason the Raspberry pi 4 appears to be working better than the HP Thin Client.
I have t420 thin Client which comes with M.2 wifi this one. Would anyone be able to confirm if Coral M.2 A+E work?
Wireless-AC Intel 9260 9260NGW Adapter For M.2 Key E NGFF Wifi Network Card 9260AC, Wi-Fi + Bluetooth 5.0, Up to 1730Mbps-5G, 300Mbps-2.4G, Dual Band, IEEE 802.11ac, MU-MIMO, Windows 10 for Laptop
Thank you,now i get it
Iā€™m also running frigate in a docker container in a proxmox LXC. See if this helps. I could not get QSV working on my 10th gen intel, but vaapi will work. My CPU idles at ~9%. Also note I did a lot of messing around, so some of these settings may not be doing anything useful.
Proxmox container config (file 105.conf in my case). lxc.cgroup and lxc.mount are used to pass GPU device and USB for a coral stick"
arch: amd64
cores: 2
features: nesting=1
hostname: Docker
memory: 4096
mp0: /shared,mp=/shared,size=0
net0: name=eth0,bridge=vmbr0,firewall=1,hwaddr=00:00:00:00:00:00,ip=dhcp,type=veth
onboot: 1
ostype: debian
rootfs: local-lvm:vm-105-disk-0,size=115G
startup: order=2
swap: 512
lxc.cgroup.devices.allow: c 226:0 rwm
lxc.cgroup.devices.allow: c 226:128 rwm
lxc.cgroup.devices.allow: c 29:0 rwm
lxc.cgroup.devices.allow: c 189:* rwm
lxc.apparmor.profile: unconfined
lxc.cgroup.devices.allow: a
lxc.mount.entry: /dev/dri/renderD128 dev/dri/renderD128 none bind,optional,create=file 0, 0
lxc.mount.entry: /dev/bus/usb/002/ dev/bus/usb/002/ none bind,optional,create=dir 0, 0
lxc.cap.drop:
frigate config:
hwaccel_args:
   #Optional: global input args (default: shown below)
    - -hwaccel
    - vaapi
    - -hwaccel_device
    - /dev/dri/renderD128
Docker run command passing USB and GPU devices:
docker run --name frigate --privileged --shm-size=1g --mount type=tmpfs,target=/tmp/cache,tmpfs-size=1000000000 -v /shared/frigate/config:/config:ro -v /shared/frigate/clips:/clips:rw -v /etc/localtime:/etc/localtime:ro -v /dev/bus/usb:/dev/bus/usb --device-cgroup-rule="c 189:* rmw" --device=/dev/dri/renderD128 -d -p 5000:5000 -e FRIGATE_RTSP_PASSWORD='password' blakeblackshear/frigate:0.8.4-amd64
Also, a useful container to see if your hardware accel is working:
https://hub.docker.com/r/djaydev/intel-gpu-tools
Which CT Template did you use?
You donā€™t need Coral drivers for the USB version if you are using Docker. But on the Synology you either need to Start the container from the command line so you can pass through the USB or take a look at Using Google Coral on Synology Docker without starting from CLI Ā· Discussion #364 Ā· blakeblackshear/frigate Ā· GitHub
This did the trick. Took a little bit of interpretation but it worked. Thank you.
I wonder if frigate is ok for the hard drives. I know it quite intensive.
I wouldnā€™t exactly call Frigate intensive?
Itā€™s going to be recording a lot less than a normal NVR as itā€™s only recording clips of actual people (or whatever trackers you have set). With a normal NVR it will be recording every time the sun moves or a leaf blows on a tree.
Debian Turnkey Core I believe. Watch the first part of this where he sets up the LXC and docker. You donā€™t need any of the NGNIX stuff he installs towards the end
