Ok, got it now in an LXC container with docker and TPU (usb coral) passthrough… will monitor the behaviour…
*** Fingers Crossed ***
Edit: OMG, memory & CPU is almost nothing
Oh my, I am just increasing all my 4 cams back to full res… This is amazing… (resource wise)!
One option, create zones, specify the min_area and max_area for objects - i.e a person couldn’t be 9252 in that zone/that close to the camera.
Got it, thank you will go through the documentation to set it up, Much appreciated !
Must object be fully in zone to be considered as “in the zone”?
Makes complete sense. I do watch a grid view but I am also someone that is not using frigate for NVR duty. It’s purely notifications. The solution for those that do what a grid view may be doing what I am doing. I have frigate pulling video feeds from my NVR and integrating the notifications to home assistant. If I want the grid view I just load up my NVR and have access to them.
Ok, major problems again… on the proxmox side now. 32GB was full in a day… tried to grow to 64GB then docker in LXC didn’t start… All kinds of errors… made me decide to start over… but now I cant get it running anymore… not with a new LXC id as well…
Can’t sart it:
106.conf:
arch: amd64
cores: 4
features: nesting=1
hostname: frigatelxc
memory: 8192
mp0: /shared,mp=/shared,size=0
nameserver: 192.168.1.90 192.168.1.91
net0: name=eth0,bridge=vmbr0,firewall=1,hwaddr=B2:72:05:93:9E:23,ip=dhcp,type=veth
onboot: 1
ostype: debian
rootfs: local-lvm:vm-106-disk-0,size=128G
swap: 512
lxc.cgroup.devices.allow: c 226:0 rwm
lxc.cgroup.devices.allow: c 226:128 rwm
lxc.cgroup.devices.allow: c 29:0 rwm
lxc.cgroup.devices.allow: c 189:* rwm
lxc.apparmor.profile: unconfined
lxc.cgroup.devices.allow: a
lxc.mount.entry: /dev/dri/renderD128 dev/dri/renderD128 none bind,optional,create=file 0, 0
lxc.mount.entry: /dev/bus/usb/002/ dev/bus/usb/002/ none bind,optional,create=dir 0, 0
lxc.cap.drop:
help :-)?
when I grey out
it starts… whats that for?
EDIT: I am back up and running… next/new quiestions will come
Running Frigate on Home Assistant as addon, NUC with Ubuntu 20.04.
Could someone please share a working automation where I send image and video to Telegram? The example in section Home Assistant do not work and generate
Error sending photo: Can't parse entities: can't find end of the entity starting at byte offset 28. Args: (), kwargs: {'chat_id': xxxxxxxxx, 'photo': <_io.BytesIO object at 0x7f0ae8a29b30>, 'caption': 'A person was detected on hik_kontor camera', 'disable_notification': False, 'reply_markup': None, 'timeout': None, 'parse_mode': 'Markdown'}
Current automation:
automation:
- alias: Notify of events
platform: mqtt
topic: frigate/events
- service: notify.xxxxxxxxx
message: 'A {{trigger.payload_json["after"]["label"]}} was detected.'
photo:
# this url should work for addon users
- url: 'http://ccab4aaf-frigate:5000/api/events/{{trigger.payload_json["after"]["id"]}}/thumbnail.jpg'
caption: 'A {{trigger.payload_json["after"]["label"]}} was detected on {{ trigger.payload_json["after"]["camera"] }} camera'
The issue are the caption
which gives a markdown error. If I replace the templates and use static text, it works for sending an image via Telegram.
It’s actually based on the bottom center of the bounding box. Not any part.
is it possible to show bounding boxes when playback clips?
If I run frigate separately and if I connect the (hacs installed) integration to that frigate.
I see all “entities”, but I have loads of questions:
What can be the issue?
terras:
ffmpeg:
inputs:
- path: rtsp://admin:[email protected]:554/Streaming/Channels/101/
roles:
- detect
- clips
- rtmp
width: 3840
height: 2160
fps: 4
snapshots:
enabled: true
crop: false
objects:
track:
- bird
- dog
- cat
motion:
mask:
- '3840,0,3840,1295,3138,1412,3034,769,2958,382,2622,0'
- '0,652,178,384,444,137,598,303,416,496,104,819,25,777'
- '0,161,64,242,180,248,248,264,354,178,455,92,532,0,0,0'
threshold: 25
clips:
# Required: enables clips for the camera (default: shown below)
# This value can be set via MQTT and will be updated in startup based on retained value
enabled: True
# Optional: Number of seconds before the event to include in the clips (default: shown below)
pre_capture: 2
# Optional: Number of seconds after the event to include in the clips (default: shown below)
post_capture: 2
# Optional: Objects to save clips for. (default: all tracked objects)
objects:
- bird
- dog
- cat
# Optional: Restrict clips to objects that entered any of the listed zones (default: no required zones)
required_zones: []
# Optional: Camera override for retention settings (default: global values)
retain:
# Required: Default retention days (default: shown below)
default: 10
# Optional: Per object retention days
objects:
bird: 200
dog: 3
cat: 200
Edit:
the entities do work on another instance of home assistant with the addon running…
I can acces the rtmp stream via vlc in the frigate instance:
rtmp://192.168.1.112/live/terras
Edit: the issue was wrongly configured mqtt server. It needs to be the one on the same homeassistant.
I get multiple events/notifications when a car is parked in frame. Is there some way to have it not be triggered multiple times until it leaves frame? or another object comes in to frame?
Or sometimes a person stays in frame but is moving around and it triggers multiple events. Sometimes the times of the events overlap ie. event 1 ~ 1:30:29-1:30:50 ; event 2 ~ 1:30:40-1:30:55
Hi @mate
EDIT: Seems both photo and video now works fine on Telegram
Though, still can’t use templates in caption.
Here’s my automation (HA on Ubuntu, running Frigate as addon):
- alias: 32 - Frigate
description: Person/car detection in cameras from Frigate
- platform: mqtt
condition:
- '{{ trigger.payload_json["type"] == "end" }}'
- '{{ trigger.payload_json["after"]["label"] == "person" }}'
- service: notify.my_telegram
message: ''
photo:
- url: 'http://192.168.0.10:5000/api/events/{{trigger.payload_json["after"]["id"]}}/snapshot.jpg'
caption: 'A snapshot'
- delay:
hours: 0
minutes: 0
seconds: 45
milliseconds: 0
message: ''
video:
- url: 'https://XYZ.ui.nabu.casa/api/frigate/notifications/{{trigger.payload_json["after"]["id"]}}/{{trigger.payload_json["after"]["camera"]}}/clip.mp4'
timeout: 1000
caption: 'A video clip'
mode: single
Here are my kinda hackey work arounds to multiple notifications. Basically, the automation needs 5min without an object detected before it will send a notification. In theory, for a car sitting in the driveway you would get one notification on first detection and then no more until there was no car for 5min.
It wouldn’t tell you if another car showed up. Not sure if frigate reports the number of detected objects or not. If it did I guess it’d be possible to add that logic. There might be more sophisticated ways to do this by event type. Instead of timer maybe just ignore any events that are “type : update”. Its possible that’d detect a new car in the scene? not sure…
alias: Frigate Car Notification
description: ''
- platform: mqtt
condition:
- condition: state
entity_id: binary_sensor.front_car_motion
state: 'off'
for: '00:05:00'
- condition: and
conditions:
- condition: template
value_template: '{{trigger.payload_json["after"]["label"] == "car"}}'
- service: notify.mobile_app_XXXXX_iphone
url: >-
https://XXXXXXXXXXX.ui.nabu.casa/api/frigate/notifications/{{trigger.payload_json["after"]["id"]}}/thumbnail.jpg?format=android
hide-thumbnail: false
apns_headers:
apns-collapse-id: '{{trigger.payload_json["after"]["id"]}}'
mode: single
alias: Frigate Person Notification
description: ''
- platform: mqtt
condition:
- condition: state
entity_id: binary_sensor.front_person_motion
state: 'off'
for: '00:05:00'
- condition: and
conditions:
value_template: '{{trigger.payload_json["after"]["label"] == "person"}}'
- service: notify.mobile_app_XXXXXX_iphone
url: >-
https://XXXXXXXXXXXXXXX.ui.nabu.casa/api/frigate/notifications/{{trigger.payload_json["after"]["id"]}}/thumbnail.jpg?format=android
apns_headers:
mode: single
@blakeblackshear is there a way to have the 24/7 recording be a toggle so that I can have it active at specified times? Basically I want the cameras to only save clips on person detection but when my babysitter is in the house I want there to be 24/7 recording.
Looks like maybe you can set that with a MQTT message?
frigate/<camera_name>/clips/set
Topic to turn clips for a camera on and off. Expected values are ON
and OFF
Adding another. If I add - rtmp to the cams I get:
frigate.video INFO : terras: ffmpeg sent a broken frame. memoryview assignment: lvalue and rvalue have different structures
frigate.video INFO : terras: ffmpeg process is not running. exiting capture thread...
frigate.video INFO : voortuin: ffmpeg sent a broken frame. memoryview assignment: lvalue and rvalue have different structures
frigate.video INFO : voortuin: ffmpeg process is not running. exiting capture thread...
frigate.events INFO : Exiting event processor...
frigate.video INFO : parkeerplaats: ffmpeg sent a broken frame. memoryview assignment: lvalue and rvalue have different structures
frigate.video INFO : parkeerplaats: ffmpeg process is not running. exiting capture thread...
frigate.video INFO : schuurachter: ffmpeg sent a broken frame. memoryview assignment: lvalue and rvalue have different structures
frigate.video INFO : schuurachter: ffmpeg process is not running. exiting capture thread...
frigate.watchdog INFO : Exiting watchdog...
I’m not 100% that it will fit as I bought a 180 degree usb-c cable from AliExpress but haven’t tried it as I realised the Pi4 doesn’t supply enough power for the coral and the Argon M.2 case. Looking at the pic I took at the time it might be slightly too big.
I will give it a go out of curiosity at some point.
