Is something else is triggering motion detection?
Every 10 seconds, definetly no. It was consistent over 6hours until car drive away.
Is it possible that the timestamp is triggering it?
As the timestamp is not from frigateā¦
I removed the timestamp, will see in the future if it was it
But i think you were right
thx
Yes. I believe that can trigger motion detection but I have not had that issue.
You should be able to see motion in live view by enabling bounding boxes. If time stamp is triggering it you will see it detect that. I believe some people had to mask out time stamp to prevent detection
@DrSpaldo, did you ever get Authelia to work with HA? I decided to try to tackle that tonight and failed, HA seems like a challenge since I want it to work with the Android mobile app.
Hi @SpikeyGG , unfortunately I didnāt. I had a few hours spare, so I tried and failed
I may give it another go if these kids ever give me a break!
I have been a little hesitant/cautious as I didnāt want to break my current install.
We can move the discussion over to your other thread for when I try again
what does the following show for you?
choose you camera
click Debug at the top right
then under the image, click
SHOW OPTIONS
toggle
Bounding box
Motion boxes
Does it show a clean image or do you see a bunch of boxes popping up.
When Iām viewing an image, I get constant boxes appearing.
It just so happens that I increased camera resolution on two cams me immediately after the time stamp from cameras begin trigger motion detect
As i removed the timestamp from the camera setup, now its definetly okay.So that was the problem
For anyone interested, I have posted in @SpikeyGG 's thread :
It is how I got Home Assistant working with Authelia. I used pretty much the same method for Frigate to be authenticated with Authelia (and Cloudflare, Nginx, etc) on Unraid
Yup, I have this issue too. It seems to get worse with time. After restarting the docker instance for Frigate, the system will record clips about 50-60% of the time⦠after a week of running it seems to completely stop recording clips altogether.
I still get the notifications from Home Assistant and it includes a picture from the incident but thereās no clip of it and the messages in the log file just say things like this:
frigate.events WARNING : Unable to create clip for out_the_back and event 1626012762.663106-3yhjy7. There were no cache files for this event.,
frigate.events WARNING : Unable to create clip for out_the_back and event 1626012747.026751-lxw7w8. There were no cache files for this event.,
frigate.events WARNING : Unable to create clip for out_the_back and event 1626012754.493196-3tgtmd. There were no cache files for this event.,
frigate.events WARNING : Unable to create clip for out_the_back and event 1626012741.619668-bl96jq. There were no cache files for this event.,
frigate.events WARNING : Unable to create clip for out_the_back and event 1626012741.619668-e9tvqg. There were no cache files for this event.,
frigate.events WARNING : Unable to create clip for east_yard and event 1626012631.266207-fhlgin. There were no cache files for this event.,
frigate.events WARNING : Unable to create clip for out_the_back and event 1626012484.739979-6djz75. There were no cache files for this event.,
frigate.events WARNING : Unable to create clip for east_yard and event 1626011021.167499-mhvsl6. There were no cache files for this event.,
frigate.events WARNING : Unable to create clip for east_yard and event 1626010396.646361-c2u3a7. There were no cache files for this event.
All my cameras are Reolink, the clips role is assigned to the rtmp sub channel. Like this:
rtmp://{OUT_THE_BACK_CAMERA_IP}/bcs/channel0_main.bcs?channel=0&stream=0&user={FRIGATE_RTSP_USERNAME}&password={FRIGATE_RTSP_PASSWORD}
This is the biggest thing bugging me about Frigate right now because itās completely inconsistent on when it decides to record a clip and when it doesnāt. I have not been able to find any way to increase the logging in order to debug the problem.
Actualy for me everything sorted out, the problem was with config.
What did you change? I still cannot seem to get mine to function properly.
Hi all.
I donāt seem unable to save clips. In the āmedia/clipsā directory I just see snapshot png/jpgs. But no videos.
I am running Frigate in a container on my NAS using a Coral USB
I think I have enabled the role for clips?
Any Ideas?
config.yml
mqtt:
host: <MQTT server on the HA Sever>
topic_prefix: frigate
client_id: frigate
user: <USER>
password: <PASSWORD>
stats_interval: 60
logger:
default: debug
detectors:
coral:
type: edgetpu
device: usb
clips:
enabled: True
pre_capture: 5
post_capture: 5
objects:
- person
- cat
- dog
cameras:
back:
#save_clips:
# enabled: true
# pre_capture: 10
ffmpeg:
inputs:
- path: rtsp://viewer:<PASSWORD>@<CAMIP>:554/Streaming/Channels/1
roles:
- detect
- rtmp
- clips
- record
objects:
track:
- person
- car
- dog
- cat
- bird
clips:
enabled: True
pre_capture: 5
post_capture: 5
objects:
- person
- cat
- dog
retain:
default: 10
objects:
person: 15
dog: 15
cat: 15
snapshots:
enabled: True
timestamp: True
bounding_box: False
crop: False
required_zones: []
retain:
default: 10
objects:
person: 15
dog: 15
cat: 15
bird: 2
width: 2688
height: 1520
fps: 20
Possible relevant debug?
[2021-07-12 11:46:15] frigate.events ERROR : ffmpeg version 4.3.2 Copyright (c) 2000-2021 the FFmpeg developers
built with gcc 9 (Ubuntu 9.3.0-17ubuntu1~20.04)
configuration: --disable-debug --disable-doc --disable-ffplay --enable-shared --enable-avresample --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-gpl --enable-libfreetype --enable-libvidstab --enable-libmfx --enable-libmp3lame --enable-libopus --enable-libtheora --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libxcb --enable-libx265 --enable-libxvid --enable-libx264 --enable-nonfree --enable-openssl --enable-libfdk_aac --enable-postproc --enable-small --enable-version3 --enable-libzmq --extra-libs=-ldl --prefix=/opt/ffmpeg --enable-libopenjpeg --enable-libkvazaar --enable-libaom --extra-libs=-lpthread --enable-vaapi --extra-cflags=-I/opt/ffmpeg/include --extra-ldflags=-L/opt/ffmpeg/lib
libavutil 56. 51.100 / 56. 51.100
libavcodec 58. 91.100 / 58. 91.100
libavformat 58. 45.100 / 58. 45.100
libavdevice 58. 10.100 / 58. 10.100
libavfilter 7. 85.100 / 7. 85.100
libavresample 4. 0. 0 / 4. 0. 0
libswscale 5. 7.100 / 5. 7.100
libswresample 3. 7.100 / 3. 7.100
libpostproc 55. 7.100 / 55. 7.100
[mov,mp4,m4a,3gp,3g2,mj2 @ 0x565091caa500] Format mov,mp4,m4a,3gp,3g2,mj2 detected only with low score of 1, misdetection possible!
[mov,mp4,m4a,3gp,3g2,mj2 @ 0x565091caa500] moov atom not found
[concat @ 0x565091ca8740] Impossible to open 'pipe:/tmp/cache/back-20210712114542.mp4'
pipe:: Invalid data found when processing input
[2021-07-12 11:46:15] peewee.sqliteq DEBUG : received query INSERT INTO "event" ("id", "label", "camera", "start_time", "end_time", "top_score", "false_positive", "zones", "thumbnail", "has_clip", "has_snapshot") VALUES (?, ?, ?, ?, ?, ?, ?, json(?), ?, ?, ?)
[2021-07-12 11:46:15] peewee DEBUG : ('INSERT INTO "event" ("id", "label", "camera", "start_time", "end_time", "top_score", "false_positive", "zones", "thumbnail", "has_clip", "has_snapshot") VALUES (?, ?, ?, ?, ?, ?, ?, json(?), ?, ?, ?)', ['1626086755.710832-p6iufx', 'person', 'back', 1626086755.710832, 1626086764.66152, 0.8046875, False, '[]', '****************** LOTS of DATA************=', False, True])
[2021-07-12 11:46:15] frigate.events DEBUG : Event received: end back 1626086755.930308-qzich6
[2021-07-12 11:46:15] frigate.events DEBUG : Event received: start back 1626086771.795203-qsbmar
[2021-07-12 11:46:15] frigate.events DEBUG : Cleaning up cached file back-20210712114422.mp4
[2021-07-12 11:46:15] frigate.events DEBUG : Cleaning up cached file back-20210712114432.mp4
[2021-07-12 11:46:15] frigate.mqtt DEBUG : Received mqtt message on frigate/back/person.
[2021-07-12 11:46:15] frigate.mqtt DEBUG : Received mqtt message on frigate/back/person/snapshot.
Is there any way to configure frigate to use external USB mounted storage for recordings?
Hello together,
because of zmNinja - Support ends by end of 2021 i looked for alternativesā¦
Here i found Frigate.
I startet configuring frigate on my Unraidserver.
iām using the frigate-nvidia docker containerā¦
For some reasons i canāt get my Reolink RLC520 Cameraās to work properlyā¦
Here is my Configuration:
ffmpeg:
hwaccel_args:
- -hwaccel
- cuda
- -c:v
- h264_cuvid
input_args: -avoid_negative_ts make_zero -fflags +genpts+discardcorrupt -rtsp_transport tcp -stimeout 5000000 -use_wallclock_as_timestamps 1 -c:v h264_cuvid
output_args:
detect: -f rawvideo -pix_fmt yuv420p -filter:v fps=fps=5
record: -f segment -segment_time 60 -segment_format mp4 -reset_timestamps 1 -strftime 1 -c copy -an
clips: -f segment -segment_time 10 -segment_format mp4 -reset_timestamps 1 -strftime 1 -c copy -an
rtmp: -c copy -map 0 -f flv
- -filter:v
- fps=fps=5
mqtt:
host: 10.0.0.65
port: 1883
client_id: frigate
stats_interval: 60
cameras:
Front:
ffmpeg:
output_args:
inputs:
- path: rtsp://admin:[email protected]/Streaming/Channels/1
roles:
- detect
- rtmp
- clips
width: 2560
height: 1440
fps: 5
clips:
enabled: false
pre_capture: 5
post_capture: 5
objects:
- person
required_zones: []
retain:
default: 10
objects:
person: 15
motion:
mask:
- 0,0,1769,0,1885,0,1897,152,1669,165,1457,255,989,485,529,740,0,1083
zones:
Vorgarten:
coordinates: 0,1440,1737,1440,2560,1440,2560,0,1870,0,1878,163,1664,173,1555,219,1395,288,1156,411,788,609,704,650,63,1046,0,1079
Garten:
ffmpeg:
global_args:
- '-hide_banner'
- '-loglevel'
- info
input_args:
- -avoid_negative_ts
- make_zero
- -fflags
- nobuffer
- -flags
- low_delay
- -strict
- experimental
- -fflags
- +genpts+discardcorrupt
- -rw_timeout
- "5000000"
- -use_wallclock_as_timestamps
- "1"
output_args:
# rtmp: -c:v libx264 -an -f flv -an
inputs:
- path: rtmp://10.0.0.17/bcs/channel0_main.bcs?channel=0&stream=0&user=admin&password=xxxx
roles:
- detect
- rtmp
- clips
width: 2560
height: 1920
fps: 5
rtmp:
enabled: True
clips:
enabled: true
pre_capture: 5
post_capture: 5
objects:
- person
required_zones: []
retain:
default: 10
objects:
person: 15
motion:
mask:
- 1836,44,2441,346,2389,339,2378,404,2560,426,2560,0,0,0,0,347,113,368,79,293,563,54,1124,62,1598,73
zones:
hinten_links:
coordinates: 2560,1920,2560,418,2375,407,2378,347,2441,338,1824,49,1557,65,1125,52,1095,62,550,57,94,296,111,380,0,304,0,1920
Gartenhaus:
ffmpeg:
global_args:
- '-hide_banner'
- '-loglevel'
- info
input_args:
- make_zero
- -fflags
- nobuffer
- -flags
- low_delay
- -strict
- experimental
- -fflags
- -rw_timeout
- "5000000"
- "1"
output_args:
inputs:
- path: rtmp://10.0.0.19/bcs/channel0_main.bcs?channel=0&stream=0&user=admin&password=xxxx
roles:
- detect
- rtmp
- clips
width: 2560
height: 1920
fps: 5
rtmp:
enabled: True
clips:
enabled: true
pre_capture: 5
post_capture: 5
objects:
- person
required_zones: []
retain:
default: 10
objects:
person: 15
motion:
mask:
- 89,490,135,466,496,409,444,382,539,342,542,296,1446,32,1921,252,2132,409,2088,431,2086,623,2560,701,2560,0,0,0,0,509
zones:
hinten_rechts:
coordinates: 2560,1920,2560,1920,2560,705,2081,609,2096,415,2148,415,1918,249,1436,32,946,166,537,296,539,339,491,384,488,428,144,474,0,485,0,1920
objects:
track:
- person
- cat
- dog
- car
filters:
person:
#min_area: 5000
#max_area: 100000
#min_score: 0.6
threshold: 0.7
detectors:
cpu1:
type: cpu
cpu2:
type: cpu
First error ist the followingā¦
frigate.video INFO : Garten: ffmpeg sent a broken frame. memoryview assignment: lvalue and rvalue have different structures
frigate.video INFO : Garten: ffmpeg process is not running. exiting capture thread...
ffmpeg.Garten.detect ERROR : Input #0, flv, from 'rtmp://10.0.0.17/bcs/channel0_main.bcs?channel=0&stream=0&user=admin&password=27021986':
ffmpeg.Garten.detect ERROR : Metadata:
ffmpeg.Garten.detect ERROR : displayWidth : 2560
ffmpeg.Garten.detect ERROR : displayHeight : 1920
ffmpeg.Garten.detect ERROR : Duration: 00:00:00.00, start: 1626091836.851000, bitrate: N/A
ffmpeg.Garten.detect ERROR : Stream #0:0: Data: none
ffmpeg.Garten.detect ERROR : Stream #0:1: Video: h264, yuv420p(progressive), 2560x1920, 30 fps, 1k tbr, 1k tbn
ffmpeg.Garten.detect ERROR : Stream #0:2: Audio: aac, 16000 Hz, mono, fltp
ffmpeg.Garten.detect ERROR : [segment @ 0x55d799e3f340] Opening '/tmp/cache/Garten-20210712141038.mp4' for writing
ffmpeg.Garten.detect ERROR : Output #0, segment, to '/tmp/cache/Garten-%Y%m%d%H%M%S.mp4':
ffmpeg.Garten.detect ERROR : encoder : Lavf58.45.100
ffmpeg.Garten.detect ERROR : Stream #0:0: Video: h264, yuv420p(progressive), 2560x1920, q=2-31, 30 fps, 1k tbr, 16k tbn, 1k tbc
ffmpeg.Garten.detect ERROR : Stream #0:1: Audio: aac, 16000 Hz, mono, fltp
ffmpeg.Garten.detect ERROR : Output #1, flv, to 'rtmp://127.0.0.1/live/Garten':
ffmpeg.Garten.detect ERROR : Stream #1:0: Video: h264 ([7][0][0][0] / 0x0007), yuv420p(progressive), 2560x1920, q=2-31, 30 fps, 1k tbr, 1k tbn, 1k tbc
ffmpeg.Garten.detect ERROR : Stream #1:1: Audio: aac ([10][0][0][0] / 0x000A), 16000 Hz, mono, fltp
ffmpeg.Garten.detect ERROR : Stream mapping:
ffmpeg.Garten.detect ERROR : Stream #0:1 -> #0:0 (copy)
ffmpeg.Garten.detect ERROR : Stream #0:2 -> #0:1 (copy)
ffmpeg.Garten.detect ERROR : Stream #0:1 -> #1:0 (copy)
ffmpeg.Garten.detect ERROR : Stream #0:2 -> #1:1 (copy)
ffmpeg.Garten.detect ERROR : Stream #0:1 -> #2:0 (h264 (h264_cuvid) -> rawvideo (native))
ffmpeg.Garten.detect ERROR : Press [q] to stop, [?] for help
ffmpeg.Garten.detect ERROR : frame= 2 fps=0.0 q=-1.0 q=-1.0 q=0.0 size=N/A time=00:00:02.02 bitrate=N/A speed=3.57x
ffmpeg.Garten.detect ERROR : av_interleaved_write_frame(): Connection reset by peer
ffmpeg.Garten.detect ERROR : Finishing stream 2:0 without any data written to it.
ffmpeg.Garten.detect ERROR : Output #2, rawvideo, to 'pipe:':
ffmpeg.Garten.detect ERROR : Stream #2:0: Video: rawvideo (I420 / 0x30323449), yuv420p, 2560x1920 [SAR 1:1 DAR 4:3], q=2-31, 294912 kb/s, 5 fps, 5 tbn, 5 tbc
ffmpeg.Garten.detect ERROR : encoder : Lavc58.91.100 rawvideo
ffmpeg.Garten.detect ERROR : [flv @ 0x55d799ed9700] Failed to update header with correct duration.
ffmpeg.Garten.detect ERROR : [flv @ 0x55d799ed9700] Failed to update header with correct filesize.
ffmpeg.Garten.detect ERROR : Error writing trailer of rtmp://127.0.0.1/live/Garten: Connection reset by peer
ffmpeg.Garten.detect ERROR : frame= 2 fps=0.0 q=-1.0 Lq=-1.0 q=0.0 size=N/A time=00:00:02.02 bitrate=N/A speed=3.39x
ffmpeg.Garten.detect ERROR : video:2409kB audio:4kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown
ffmpeg.Garten.detect ERROR : Conversion failed!
But the Camera livestream is comming up correctly in frigate ā¦
I have looked into the setting but the resolution is configured correctlyā¦
Are there any errors in my config with RTMP?!
thanks in advance
chris
I am not sure what the difference between the Reolink RLC520 and my Reolink RLC-410-5MP is. However, I could only get it working reliably with RTMP not RTSP. Here is how I did my config if this helps:
frontdriveway:
ffmpeg:
input_args: #Use for RTMP
- make_zero
- -fflags
- nobuffer
- -flags
- low_delay
- -strict
- experimental
- -fflags
- -rw_timeout
- '5000000'
- '1'
hwaccel_args:
- -hwaccel
- qsv
- -qsv_device
- /dev/dri/renderD128
output_args:
inputs:
- path: rtmp://192.168.1.105/bcs/channel0_sub.bcs?channel=0&stream=1&user=USERNAME&password=PASSWORD
roles:
- detect
- rtmp
- record
- path: rtmp://192.168.1.105/bcs/channel0_main.bcs?channel=0&stream=0&user=USERNAME&password=PASSWORD
roles:
- clips
width: 640
height: 480
fps: 5
record:
enabled: true
retain_days: 10
rtmp:
enabled: true
detect:
enabled: true
max_disappeared: 60
clips:
enabled: true
pre_capture: 10
post_capture: 10
objects:
- person
required_zones: []
retain:
default: 7
objects:
person: 30
snapshots:
enabled: true
timestamp: false
bounding_box: true
crop: false
retain:
default: 7
objects:
person: 60
objects:
track:
- person
Nice i just played a bit with the resolution and set it to 2048x1536 and now it working properlyā¦
Yes i made a tutorial:
https://community.home-assistant.io/t/solved-hassos-mount-nas-network-share/
