Oh (light bulb turns on between my ears). All i need to do is add my second camera to my existing config.yml and it will utilize the coral tpu already configured for that container. I was certainly over thinking this. Thanks for the quick response!
Hey what is the best order of operations for this update? I read about the breaking changes and changed my config, but how should I be updating each part of an HA install. Iām thinking Iād:
- Stop the Frigate Add-on
- Update the addon
- Update & save the Config file
- Update the Integration via HACS
- Restart Home Assistant and start the Addon back up
Does that sound right?
EDIT: Everything worked perfectly after these steps, expect the Coral TPU doesnāt seem to auto-detect anymore so I had to add that default config entry to my setup as well. Everything else worked great
I donāt have HACS, since I have an installation under proxmox, not sure how to install it ā¦ so which is the version of the custom_component 2.1.0?
I just happen to use HACS, which has itās own updater for integrations. I believe this is a required step for this update though. Youād have to just pull the latest changes from the repo in your setup I think?
Not sure if this is right thread but wasnāt able to find correct thread for lovelace frigate cardā¦
Any idea why only one camera clips are visible?
For anyone trying to migrate over to the new formatting, here is my working config with a lot of the settings moved to global defaults as all six cameras have the same stream settings. I have listed the config for one Hikvision camera and one Dahua one; both utilising the 3rd stream and 1280 x 720, h.264, 6fps. HA is running on an i7 NUC as is Frigate (HA add-on). Not an expert but working for me. FYI, CPU is averaging 33% with this 6 camera config. With only 4 cameras, it was sitting at about 21%.
mqtt:
host: <nasip)
detectors:
coral:
type: edgetpu
device: usb
birdseye:
enabled: True
width: 1280
height: 720
quality: 8
mode: objects
ffmpeg:
hwaccel_args: #Intel NUC < v10
- -hwaccel
- vaapi
- -hwaccel_device
- /dev/dri/renderD128
- -hwaccel_output_format
- yuv420p
detect:
width: 1280 # <---- update for your camera's resolution
height: 720 # <---- update for your camera's resolution
fps: 6
objects:
# Optional: list of objects to track from labelmap.txt (default: shown below)
track:
- person
record: # <----- Enable recording
enabled: True
retain_days: 0
events:
max_seconds: 300 # default value
pre_capture: 2 # default = 5
post_capture: 5
objects:
- person
required_zones: []
retain:
default: 5 # default = 10
snapshots: # <----- Enable snapshots
enabled: True
bounding_box: True
# Optional: crop the snapshot (default: shown below)
crop: False
# Optional: height to resize the snapshot to (default: original size)
#height:
cameras:
driveway_frigate: # <------ Name the camera
ffmpeg:
inputs:
- path: rtsp://username:password@<hikvisionip>:554/Streaming/Channels/103 #(3rd stream h.264, 720p, 6fps)
roles:
- detect
- rtmp
- record
motion:
mask:
- 1280,282,1219,234,1144,210,982,159,886,117,819,132,592,720,1280,720
- 601,0,510,73,0,103,0,0
path_frigate: # <------ Name the camera
ffmpeg:
inputs:
- path: rtsp://username:password@<dahuaip>:554/cam/realmonitor?channel=1&subtype=02 #(3rd stream h.264, 720p, 6fps)
roles:
- detect
- rtmp
- record
motion:
mask:
- 1035,0,985,569,617,687,385,291,369,0
What are the record settings for the camera with the missing clips?
Default settings that every camera detect, record, rtmp. And I see with Frigate UI all the cameras events & clips. Thatās why I am asking this because I donāt get it that only one camera clips are visible in home assistantā¦
Since the latest changes to Frigate NVR in Home assistant the Frigate NVR not working
s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[2021-10-10 11:27:02] frigate.app INFO : Starting Frigate (0.9.1-800f33e)
Error parsing config: 6 validation errors for FrigateConfig
cameras -> garden-cam -> ffmpeg -> inputs -> 0 -> roles -> 2
value is not a valid enumeration member; permitted: 'record', 'rtmp', 'detect' (type=type_error.enum; enum_values=[<CameraRoleEnum.record: 'record'>, <CameraRoleEnum.rtmp: 'rtmp'>, <CameraRoleEnum.detect: 'detect'>])
cameras -> garden-cam -> clips
extra fields not permitted (type=value_error.extra)
cameras -> garden-cam -> fps
cameras -> garden-cam -> height
cameras -> garden-cam -> width
etectors
[cmd] python3 exited 1
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
The errors indicate that your config is now broken. This happened to me too, I was using the clips option which is deprecated in the newer versions. Check out the master documentation site in the config sections and examples -
Switching from the native Frigate integration on HASS, because performance was awful on a RPi4 without a Coral tpu, using the Frigate NVR Proxy integration, all my lovelace frigate cards can not now display clips or snapshots. Anyone worked out how to fix this?
Did the camera capture any clips?
What are record settings/retain settings? (Post config)
I am seeing about the same performance on a NUC8i5BEH with a Coral processing six cameras. With the new version of Frigate I actually enabled three days of retention. Hoping to stay around ~60% utilization of my 1TB SSD. I have longer retention on my Ubiquiti UDMP.
So since last update a lot of this changed and indeed a lot of them are breaking.
Speaking about breaking. My āclipsā which are still called clips in the UI, do not play anymore on pressing them. I have recording configured and it seems there is given the fact there is a ātileā. Just donāt play anymore
Same here, waiting for balckbear to help.Maybe will report github issue
If they are new events, you most likely never added the record role to an input. See if you have a warning in the logs on startup.
I am sorry,i think its my fault somewhere.
Its working.
I donāt know what i didā¦
So now there will be no clips? It will be saved in recordings?
So as i can see it is not cached in ram to create clips,it is going directly to recodings.
Now if i have 11cameras, they will be constantly writing to the NAS?
I have tidied up my config moving common ffmpeg options to global config. Made adjustments for new config requirements. At the same time I got ffmpeg to resize output down to 1280x720 for detector and drop fps to 5. I am running 3 cams at 1600x900 10fps decoding on nvidia gt640 with an 8yr old Haswell i5-4670. This resulted in CPU use dropping from 11.5% to 6.4% as reported by HA Supervisor. I believe the resize is being done by GPU decoder so no need for separate streams. I wonder if the fps change could be done on input too further lowering CPU?
mqtt:
host: 192.168.50.191
user: *******
password: **********
ffmpeg:
input_args:
- -vsync
- 0
- -c:v
- h264_cuvid
- -resize
- 1280x720
output_args:
detect: -f rawvideo -pix_fmt yuv420p -vf fps=5
detect:
width: 1280
height: 720
fps: 5
objects:
track:
- person
- car
- truck
- bicycle
- dog
- cat
detectors:
coral:
type: edgetpu
device: usb
detect:
enabled: True
snapshots:
enabled: True
record:
enabled: True
retain_days: 0
events:
max_seconds: 300
pre_capture: 5
post_capture: 5
retain:
default: 10
objects:
person: 30
cameras:
back:
ffmpeg:
inputs:
- path: rtsp://192.168.50.144:8554/unicast
roles:
- detect
- rtmp
- record
motion:
mask:
- 0,179,531,109,577,0,0,0
zones:
door:
coordinates: 1051,179,780,720,1068,720,1241,141
mqtt:
enabled: False
side:
ffmpeg:
inputs:
- path: rtsp://192.168.50.215:8554/unicast
roles:
- detect
- rtmp
- record
motion:
mask:
- 845,529,875,663,963,672,1004,574,1600,683,1600,0,113,0,157,630
snapshots:
enabled: False
mqtt:
enabled: False
garden:
ffmpeg:
inputs:
- path: rtsp://192.168.50.133:8554/unicast
roles:
- detect
- rtmp
- record
mqtt:
enabled: False
I think I did?
cameras:
# FRONT Camera ########################################################################################################
voordeur:
ffmpeg:
inputs:
- path: rtsp://admin:[email protected]:554/Streaming/Channels/101/
roles:
- detect
- record
detect:
enabled: True
max_disappeared: 2
width: 2560
height: 1440
fps: 6
record:
enabled: False
retain_days: 0
events:
post_capture: 10
pre_capture: 5
objects:
- person
- dog
- cat
retain:
default: 10
snapshots:
enabled: true
crop: false
bounding_box: True
objects:
track:
- person
- dog
- cat
motion:
mask:
- '1090,81,1216,0,1382,34,1532,99,1518,259,1426,363,1123,247'
- '1766,498,1753,669,1778,722,1829,773,1863,825,1906,884,1924,955,1953,1065,2237,1169,2255,1128,2295,1046,2338,946,2378,841,2410,743,2215,647,2190,582,2138,512,2010,402,1859,351'
And I do not see anything in the log except after a while (dont know how long):
2021-10-10 18:21:54] frigate.object_processing WARNING : Unable to save snapshot for 1633882905.655275-6lyobp.
[2021-10-10 18:21:54] frigate.object_processing WARNING : Unable to create clean png because frame 1633882908.033336 is not in the cache
[2021-10-10 18:21:54] frigate.object_processing WARNING : Unable to save clean snapshot for 1633882905.655275-6lyobp.
[2021-10-10 18:21:54] frigate.object_processing WARNING : Unable to create jpg because frame 1633882908.033336 is not in the cache
[2021-10-10 18:22:48] frigate.object_processing WARNING : Unable to create jpg because frame 1633882963.404733 is not in the cache
[2021-10-10 18:22:48] frigate.object_processing WARNING : Unable to save snapshot for 1633882961.399878-ot2xpx.
[2021-10-10 18:22:48] frigate.object_processing WARNING : Unable to create clean png because frame 1633882963.404733 is not in the cache
[2021-10-10 18:22:48] frigate.object_processing WARNING : Unable to save clean snapshot for 1633882961.399878-ot2xpx.
[2021-10-10 18:23:35] frigate.object_processing WARNING : Unable to create jpg because frame 1633883010.038617 is not in the cache
[2021-10-10 18:23:35] frigate.object_processing WARNING : Unable to save snapshot for 1633883007.885112-n15t09.
[2021-10-10 18:23:35] frigate.object_processing WARNING : Unable to create clean png because frame 1633883010.038617 is not in the cache
[2021-10-10 18:23:35] frigate.object_processing WARNING : Unable to save clean snapshot for 1633883007.885112-n15t09.
[2021-10-10 18:23:35] frigate.object_processing WARNING : Unable to send mqtt snapshot for 1633883007.885112-n15t09.
[2021-10-10 18:28:32] frigate.object_processing WARNING : Unable to create jpg because frame 1633883306.875549 is not in the cache
[2021-10-10 18:28:32] frigate.object_processing WARNING : Unable to save snapshot for 1633883304.396746-x48343.
[2021-10-10 18:28:32] frigate.object_processing WARNING : Unable to create clean png because frame 1633883306.875549 is not in the cache
[2021-10-10 18:28:32] frigate.object_processing WARNING : Unable to save clean snapshot for 1633883304.396746-x48343.
[2021-10-10 18:36:46] frigate.object_processing WARNING : Unable to create jpg because frame 1633883801.721082 is not in the cache
[2021-10-10 18:36:46] frigate.object_processing WARNING : Unable to save snapshot for 1633883800.617849-u5z8n1.
[2021-10-10 18:36:46] frigate.object_processing WARNING : Unable to create clean png because frame 1633883801.721082 is not in the cache
[2021-10-10 18:36:46] frigate.object_processing WARNING : Unable to save clean snapshot for 1633883800.617849-u5z8n1.
[2021-10-10 18:41:59] frigate.object_processing WARNING : Unable to create jpg because frame 1633884109.39016 is not in the cache
[2021-10-10 18:41:59] frigate.object_processing WARNING : Unable to save snapshot for 1633884107.864138-4qufnf.
[2021-10-10 18:41:59] frigate.object_processing WARNING : Unable to create clean png because frame 1633884109.39016 is not in the cache
[2021-10-10 18:41:59] frigate.object_processing WARNING : Unable to save clean snapshot for 1633884107.864138-4qufnf.
[2021-10-10 18:45:26] frigate.object_processing WARNING : Unable to create jpg because frame 1633884321.581425 is not in the cache
[2021-10-10 18:45:26] frigate.object_processing WARNING : Unable to save snapshot for 1633884320.011118-9mf083.
[2021-10-10 18:45:26] frigate.object_processing WARNING : Unable to create clean png because frame 1633884321.581425 is not in the cache
[2021-10-10 18:45:26] frigate.object_processing WARNING : Unable to save clean snapshot for 1633884320.011118-9mf083.
Hence me asking to "how to delete the database other than just delete the file below, or is that teh way and will it be recreated after I restart the container?
database:
path: /media/frigate/db/frigate.db
