Stop frigate and delete the db file. You can also delete everything in the recordings folder. There is likely a message at the start of the logs you posted with an error that caused the follow on errors you are seeing.
Like I said @tmjpugh clips are captured and played nicely with Frigate UI and also this one camera clips are visible in Lovelace frigate card. Here is my config.yml and docker-compose.
detectors:
coral:
type: edgetpu
device: usb
mqtt:
host: 192.168.1.60
port: 1883
topic_prefix: frigate
client_id: frigate
user: mqtt
password: xxx
birdseye:
enabled: True
width: 1280
height: 720
quality: 8
mode: objects
ffmpeg:
hwaccel_args:
- -hwaccel
- vaapi
- -hwaccel_device
- /dev/dri/renderD128
- -hwaccel_output_format
- yuv420p
record:
enabled: true
retain_days: 10
events:
retain:
default: 14
snapshots:
enabled: True
bounding_box: True
crop: false
retain:
default: 14
cameras:
etupiha:
ffmpeg:
inputs:
- path: rtsp://admin:[email protected]:554/Streaming/Channels/1
roles:
- rtmp
- detect
- record
detect:
width: 1920
height: 1080
fps: 5
motion:
mask:
- 357,387,179,0,659,0,673,128
rtmp:
enabled: True
objects:
track:
- person
- dog
- cat
- car
filters:
car:
mask:
- 197,698,57,1080,421,1080,530,1016,714,743,718,596,640,526,489,482,385,469,308,558
Takapiha2:
ffmpeg:
inputs:
- path: rtsp://admin:[email protected]:554/cam/realmonitor?channel=1&subtype=0
roles:
- rtmp
- detect
- record
detect:
width: 1920
height: 1080
fps: 5
rtmp:
enabled: True
objects:
track:
- person
- dog
- cat
Mokkitienpuoli:
ffmpeg:
inputs:
- path: rtsp://admin:xxx@xxx:1111/cam/realmonitor?channel=1&subtype=0
roles:
- rtmp
- detect
- record
detect:
width: 1920
height: 1080
fps: 5
motion:
mask:
- 1237,537,1550,559,1567,465,1246,430
- 1141,429,1337,447,1349,357,1130,352
rtmp:
enabled: True
objects:
track:
- person
- dog
- cat
- car
- bird
Mokkiranta:
ffmpeg:
inputs:
- path: rtsp://admin:xxx@xxx:554//h264Preview_01_main
roles:
- rtmp
- detect
- record
detect:
width: 640
height: 480
fps: 5
rtmp:
enabled: True
objects:
track:
- person
- dog
- cat
version: '3.9'
services:
frigate:
shm_size: '128m'
container_name: frigate
privileged: true # this may not be necessary for all setups
restart: unless-stopped
image: blakeblackshear/frigate:0.9.1-amd64
devices:
- /dev/bus/usb:/dev/bus/usb
volumes:
- /etc/localtime:/etc/localtime:ro
- /home/docker/hassio/homeassistant/config.yml:/config/config.yml:ro
- /mnt/videovalvonta:/media/frigate
- type: tmpfs # Optional: 1GB of memory, reduces SSD/SD Card wear
# target: /mnt/ramdisk
# tmpfs:
# size: 1000000000
ports:
- '5000:5000'
- '1935:1935' # RTMP feeds
environment:
FRIGATE_RTSP_PASSWORD: 'xxx'
Never mind. Solved.
Hi, it seems to have something to do with time? Some recordings just do not play. I have recording glabally enabled, not per cam. Some play, some donāt (from same cam).
Copy your whole config here, blakeblackshear helped me with pointers and i have been able to figure it out.
Let me help you
Hi Ryan, Iām trying to set up my frigate docker instance inside a VirtualBox Ubuntu VM, Could you tell me which hardware acceleterators have you set up in your frigate yaml file?.
Iām trying to configure six cameras and lag is horrible!!. And I think itās because Iām not using any hardware accelerator.
For anybody here struggling with lag, Iām on a RPi 4B with a Coral with 4 cameras and my performance is pretty darn good. I can tell sometimes that Iām right up against the systemās limits, but I generally have smooth capture and playback. Any choppiness generally seems to be related to the platform Iām viewing on, because watching a camera from my PC is completely smooth.
On another note, Iād like to start fresh with my Frigate recordings/clips because Iāve restructured my detection quite a bit in the past couple of days after upgrading. If I just shutdown Frigate, delete the contents of the media folder and the db, and then start back up will that work?
I havenāt been very active with this lately, but I see some newer releases are coming out.
Iām a bit confused when I go to look at the addon Iām using now and donāt see any updates available.
Did the addon support get dropped?
I sure hope not, but Iām not seeing any mention of it anywhere anymore so Iām thinking I may have missed something.
----------------------------EDIT--------------------------------------------------
It seems that somewhere along the upgrading path the URL for the addons (ALL of the non official ones) got deleted from my install. After adding it back it now shows an update available.
birdseye:
enabled: True
width: 1280
height: 720
quality: 8
mode: objects
database:
path: /media/frigate/db/frigate.db
ffmpeg:
hwaccel_args:
- -hwaccel
- vaapi
- -hwaccel_device
- yuv420p
record:
enabled: true
retain_days: 10
events:
retain:
default: 14
# MQTT Config ##########################################################################################################
mqtt:
host: 192.168.1.142
port: 1883
topic_prefix: frigate112
client_id: frigate112
user: mqtt
password: mqtt
stats_interval: 60
# Cameras Config ######################################################################################################
cameras:
# FRONT Camera ########################################################################################################
front:
ffmpeg:
inputs:
- path: rtsp://admin:[email protected]:554/Streaming/Channels/101/
roles:
- detect
- record
detect:
enabled: True
max_disappeared: 2
width: 2560
height: 1440
fps: 6
snapshots:
enabled: true
crop: false
bounding_box: True
objects:
track:
- person
- dog
- cat
motion:
mask:
- '1090,81,1216,0,1382,34,1532,99,1518,259,1426,363,1123,247'
- '1766,498,1753,669,1778,722,1829,773,1863,825,1906,884,1924,955,1953,1065,2237,1169,2255,1128,2295,1046,2338,946,2378,841,2410,743,2215,647,2190,582,2138,512,2010,402,1859,351'
# Back Camera ########################################################################################################
back:
ffmpeg:
inputs:
roles:
- detect
- record
detect:
enabled: True
max_disappeared: 2
width: 2048
height: 1536
fps: 4
snapshots:
enabled: true
crop: false
bounding_box: True
objects:
track:
- person
- car
- dog
- bicycle
- cat
filters:
car:
min_score: 0.5
threshold: 0.7
mask:
- '276,374,440,126,467,0,808,0,781,103,697,367'
- '1723,199,2048,354,2048,585,1128,396,1086,128,1115,27'
# PARKING Camera ########################################################################################################
parkeing:
ffmpeg:
inputs:
roles:
- detect
- record
detect:
enabled: True
max_disappeared: 2
width: 3840
height: 2160
fps: 6
snapshots:
enabled: true
crop: false
bounding_box: True
objects:
track:
- person
- car
- dog
- bicycle
motion:
mask:
- '2868,0,2839,240,2812,276,2775,329,2740,783,3840,1037,3840,0'
- '2261,174,2190,154,2140,142,2096,133,2053,124,2002,122,1968,101,1914,71,1868,58,1817,56,1768,58,1716,69,1689,99,1642,100,1596,117,1566,137,1471,135,1419,162,1378,217,1364,278,1402,344,1474,393,1582,391,1652,347,1710,350,1786,361,1879,347,1991,328,2022,307,2046,289,2046,205,2074,189,2157,201,2154,330,2249,282'
- '0,1896,153,2081,298,2049,403,1941,436,1839,439,1685,326,1492,142,1419,0,1531'
- '1130,217,1265,271,519,597,1122,744,1104,990,1016,1049,464,838,426,620,415,564,412,494'
- '398,490,483,455,605,416,730,372,754,339,751,233,744,167,695,122,645,105,569,99,497,110,441,119,365,189'
zones:
parkeerplaats_voortuin_zone:
coordinates: 297,2160,3840,2160,3840,1074,2754,786,2768,451,2128,325,1298,258,428,614,515,1002,620,1335,372,1573
# FRONT2 Camera ########################################################################################################
front2:
ffmpeg:
inputs:
roles:
- detect
- record
detect:
enabled: True
max_disappeared: 25
width: 3840
height: 2160
fps: 6
snapshots:
enabled: true
crop: false
bounding_box: True
objects:
track:
- person
- car
- dog
- bicycle
- cat
- truck
motion:
mask:
- '3840,751,3840,386,3560,283,3482,341,3275,293,3150,302,3102,481,2948,460,2937,541,2978,714,3306,1422,3714,1413,3840,1647'
- '1961,892,1907,871,1876,878,1844,867,1787,874,1689,914,1569,896,1486,881,1417,829,1413,736,1374,606,1345,415,1456,293,2344,337,2319,507,2199,499,2194,610,2244,655,2249,786,2213,881,2160,900,2111,921,2024,928'
- '553,1714,670,1791,726,1866,747,1950,1879,2160,548,2160,466,1880'
- '265,1437,428,1486,496,1568,426,1728,351,1672,190,1571,222,1502'
- '1508,0,1586,77,1587,194,1561,229,1493,268,1416,312,1342,304,1225,276,1182,201,1196,86,1274,0'
- '560,1410,658,1426,739,1490,832,1590,872,1716,879,1823,839,1901,726,1889,661,1816,588,1744,510,1691,506,1539'
- '499,1508,584,1357,683,1222,682,1155,665,1066,627,987,566,889,491,821,389,803,270,829,176,872,64,966,0,1055,21,1190,63,1323,151,1413,194,1449'
# TERRAS Camera ########################################################################################################
terras:
ffmpeg:
inputs:
roles:
- detect
- record
detect:
enabled: True
max_disappeared: 25
width: 3840
height: 2160
fps: 4
snapshots:
timestamp: False
bounding_box: True
enabled: true
crop: false
objects:
track:
- bird
- dog
- cat
motion:
mask:
- '3840,0,3840,1295,3138,1412,3034,769,2958,382,2622,0'
- '0,652,178,384,444,137,598,303,416,496,104,819,25,777'
- '0,161,64,242,180,248,248,264,354,178,455,92,532,0,0,0'
threshold: 25
detectors:
coral:
type: edgetpu
device: usb
Can anyone tell me how I know if hardware accelerator is working?.
I have an i5 8269U (8th generation) and I wrote this configuration for QuickSync:
ffmpeg:
hwaccel_args:
- -hwaccel
- vaapi
- -hwaccel_device
- yuv420p
It didnāt work. Camera was green.
Then I put this one:
ffmpeg:
hwaccel_args:
- -hwaccel
- qsv
- -qsv_device
And it worked, but neither my processor is 10th generation nor my log shows anything related to hardware acceleration.
about my config:
cameras:
test_camera:
ffmpeg:
hwaccel_args:
- -hwaccel
- qsv
- -qsv_device
inputs:
- path: <RTSP_STREAM_PATH>
roles:
- detect
- rtmp
detect:
width: 1920
height: 1080
fps: 5
As you see is quite simple, due to Iām testing frigate.
Thanks in advance.
So turn off frigate addon.
remove all db files of frigate, should be 2-3 files.
Remove all files from recording and clips.
Start addon and check logs if no errors.
And should work.Let me know
Please, I have no addon! :-).
The problem is recordings not all availabe.
I donāt check this thread often and itās nearly impossible to provide support in this mega thread. I would suggest opening an issue on github if you want my help.
Great update! Iāve upgraded and everything appears to be working like I had it before. Only question that I feel dumb about asking: What the heck is Birdseye? Sometimes I see just a black screen with a white bird thingy. Sometimes itās a camera with motion. What is going on in Birdseye?
A question for all you out thereā¦
Would it be possible to make a telegram notification with a interaction so that it can play the related video clip inside telegram? As it is today im sending a https link to my frigate and open the clip in a new web pageā¦ Would like to skip that and show the video clip inside telegramā¦
Is this doable?
My inference times were off until I realised I needed and actual USB 3.1 USB-A to USB-C cable
Maybe useful for someone who is looking for coral
Bought this combo PCIe M.2 Coral + PCI-E x1 adapter for my hp prodesk 800 g1 ubuntu server, works great with frigate docker.
coral Mini PCIe M.2
https://lv.rsdelivers.com/product/coral/g650-04527-01/coral-google-mini-pcie-m2-accelerator-a-e/2017825
international site:
https://export.rsdelivers.com/product/coral/g650-04527-01/coral-google-mini-pcie-m2-accelerator-a/e-development-kit-g650-04527-01/2017825
Adapter M.2 NGFF Key A A+E (PCENGFF-NA1)
https://capital.lv/Produkti/Katalogs/Datoru-komponentes/Citas-komponentes/Adaptera-karte-PCI-E-for-Intel-AX200-M.2-NGFF-Key-A-AE-to-Mini-PCI-E-Adapter-Wireless-WiFi-Bluetooth-Network-Card-Converter-PCI-Express-1X-M2-NGFF-Support-2230-2242?
international site: https://www.amazon.com/Adapter-PCENGFF-NA1-Wireless-Network-Expansion/dp/B087RDYYBW
I was having the same issues so I deleted the files you suggested. On restart I have the same two errors for each of my cameras. I had the same errors before deleting files.
WARNING : Camera back_yard has record enabled, but record is not assigned to an input.
WARNING : Camera back_yard has rtmp enabled, but rtmp is not assigned to an input.
Clips are being saved but not recordings.
I have the following in my config.
record:
enabled: True
retain_days: 0
events:
retain:
default: 10
I removed the clips: and record: section for the individual cameras.
I clearly screwed something up with what to add and what to remove from where. Any direction would be appreciated.
