Oh yes, I’m really blind. Before I could only see the timestamp_style setting , but now I see it under ui block as well. Thank you.
I keep getting cameras with this displayed:
When I click into the camera, the stream is working, but it breaks everywhere else (such as on Area cards) until I restart Frigate.
I have some errors in the go2rtc logs:
[INFO] Starting go2rtc...
2023-05-02 16:06:49.290807176 curl: (7) Failed to connect to 127.0.0.1 port 1984: Connection refused
2023-05-02 16:06:49.294740120 [ERROR] The go2rtc service is not responding to ping, restarting...
2023-05-02 16:06:49.424492204 [INFO] The go2rtc service exited with code 256 (by signal 15)
But I can’t find any errors specific to the camera(s) that are failing like this.
Share your config (but mask passwords) please
I made a quick and dirty script to restart frigate when a camera is down. Or actually when there is no ffmpeg process associated with the camera. It is best to solve the issue when it happens, but I also do not want my camera not recording anymore. More then once I found that my camera was showing “No frames have been received, check error logs”. Restarting frigate solved the issue.
mqtt:
host: REDACTED
port: 1883
user: REDACTED
password: REDACTED
detectors:
coral:
type: edgetpu
database:
path: /config/frigate.db
detect:
width: 1280
height: 720
fps: 5
enabled: True
max_disappeared: 25
stationary:
interval: 0
threshold: 50
max_frames:
default: 3000
objects:
person: 1000
objects:
track:
- person
filters:
person:
min_area: 5000
max_area: 100000
min_score: 0.5
threshold: 0.75
motion:
threshold: 25
contour_area: 50
delta_alpha: 0.2
frame_alpha: 0.2
frame_height: 50
improve_contrast: False
record:
enabled: True
events:
pre_capture: 5
post_capture: 10
objects:
- person
- dog
- car
required_zones: []
retain:
default: 30
mode: active_objects
objects:
dog: 3
car: 3
snapshots:
enabled: False
timestamp: False
bounding_box: False
crop: False
required_zones: []
retain:
default: 30
objects:
dog: 3
car: 7
live:
height: 720
quality: 31
timestamp_style:
position: "tl"
format: "%m/%d/%Y %H:%M:%S"
color:
red: 255
green: 255
blue: 255
thickness: 2
effect: solid
go2rtc:
streams:
drive:
- rtsp://REDACTED:REDACTED@REDACTED:554/Preview_01_sub
front_door:
- rtsp://REDACTED:REDACTED@REDACTED/cam/realmonitor?channel=1&subtype=0
front_yard:
- rtsp://REDACTED:REDACTED@REDACTED:554/cam/realmonitor?channel=1&subtype=0&unicast=true&proto=Onvif
back_yard:
- rtsp://REDACTED:REDACTED@REDACTED:554/h264Preview_01_main
patio:
atrium:
- rtsp://REDACTED:REDACTED@REDACTED:554/ISAPI/Streaming/channels/102
playroom:
living:
dining:
cameras:
drive:
ffmpeg:
inputs:
- path: rtsp://127.0.0.1:8554/drive
input_args: preset-rtsp-restream
roles:
- record
- detect
input_args:
- '-avoid_negative_ts'
- make_zero
- '-fflags'
- nobuffer
- '-flags'
- low_delay
- '-strict'
- experimental
- '-fflags'
- +genpts+discardcorrupt
- '-use_wallclock_as_timestamps'
- '1'
detect:
width: 1536
height: 576
front_door:
ffmpeg:
inputs:
- path: rtsp://127.0.0.1:8554/front_door
roles:
- detect
- record
detect:
width: 1920
height: 1080
front_yard:
ffmpeg:
inputs:
- path: rtsp://127.0.0.1:8554/front_yard
roles:
- record
- detect
input_args:
- make_zero
- '-fflags'
- nobuffer
- '-flags'
- low_delay
- '-strict'
- experimental
- '-fflags'
- '1'
detect:
width: 1920
height: 1088
back_yard:
ffmpeg:
inputs:
- path: rtsp://127.0.0.1:8554/back_yard
roles:
- record
- detect
input_args:
- make_zero
- '-fflags'
- nobuffer
- '-flags'
- low_delay
- '-strict'
- experimental
- '-fflags'
- '1'
detect:
width: 2560
height: 1920
patio:
ffmpeg:
inputs:
- path: rtsp://127.0.0.1:8554/patio
roles:
- record
- detect
input_args:
- make_zero
- '-fflags'
- nobuffer
- '-flags'
- low_delay
- '-strict'
- experimental
- '-fflags'
- '1'
detect:
width: 640
height: 480
atrium:
ffmpeg:
inputs:
- path: rtsp://127.0.0.1:8554/atrium
roles:
- record
- detect
output_args:
record: -f segment -segment_time 10 -segment_format ts -reset_timestamps 1 -strftime 1 -c:v libx264
detect:
width: 2688
height: 1520
playroom:
ffmpeg:
inputs:
- path: rtsp://127.0.0.1:8554/playroom
roles:
- record
- detect
detect:
width: 640
height: 480
living:
ffmpeg:
inputs:
- path: rtsp://127.0.0.1:8554/living
roles:
- record
- detect
input_args:
- make_zero
- '-fflags'
- nobuffer
- '-flags'
- low_delay
- '-strict'
- experimental
- '-fflags'
- '1'
detect:
width: 2560
height: 1440
dining:
ffmpeg:
inputs:
- path: rtsp://127.0.0.1:8554/dining
roles:
- record
- detect
detect:
width: 640
height: 352
Small update in regards to this script, it can now copy a log file before restart. This way the log can be reviewed later while frigate, hopefully, comes back online with a fresh connection to your camera(s)
Anybody? I’m about to dump go2rtc because of this.
usually this happens because you are also running HA with the webrtc integration. You need to disable the webrtc integration, get frigate running, then re set up the webrtc integration pointing to frigate_ip:1984 (if you are running the integration, the webrtc integration will find it automatically)
Don’t believe I’m using that, absolutely no other camera stuff setup on my config. Gotta be done with go2rtc for now. Seems buggy as heck.
only thing standing out as different to mine is the extra input args you put in some cameras
Unfortunately, one camera that suffers this problem frequently has no input args at all (front_door).
It does appear that those that have intermittent network interruptions are the most prone to this occurring. Though I’ve removed all the input args, and continue to suffer this problem on more unreliable (wifi) cameras. I’m having to do away with go2rtc for these, disappointingly.
Hi, i want to detect person that come in the specific zone that i have defined. but the zone is not working the camera is detecting everything. can someone help me?
this is my config:
required_zones:
- oprit_huis
enabled: true
timestamp: true
bounding_box: true
objects:
track:
- car
- person
zones:
oprit_huis:
coordinates: 65,421,186,720,1053,720,1215,279,1203,223,771,99
zones:
oprit_huis:
objects:
- person
I started out with 2, then 4, then 6 (!) cameras on an HAOS raspberry-4, which was understandably struggling at 85% CPU… Working, but struggling all the same, it was an interesting learning curve. Mostly it was detecting movement well with some masks to reduce the load from wavy trees.
I’m now running an HAOS mini-PC with a coral stick and an SSD. It’s blistering along at 25% CPU with 6 cams and detecting people, dogs, cats, umbrellas and all sorts. Wonderful!
Don’t get me wrong, I love the raspberry, and I’ve another providing excellent service as a home security system with little or no video. Also, to clarify, the raspberry did well with a couple of cameras, no complaints, but with 6 I needed to move up a shelf.
Just fyi. here.
Hey boyz & grilz,
need assistance. I have a remote camera that sometimes glitches due to communication.
I have seen that when it glitches frigate see 0fps. Is it possible somehow to read the fps, so i can send some notification?
yes, just use the camera_fps sensor (it needs to be enabled)
Awesome, can you be so kind and provide me any link? <3 * i am not using integration just Addon
So i need the integration?
