Local realtime person detection for RTSP cameras
I have just discovered that the snapshots taken by Frigate, are easily accessible without authentication via a simple link. This means that anyone with the link can access the images from my camera.
https://HOMEASSISTANT.URL/api/hassio_ingress/HASH//api/events/ID-NUM/snapshot.jpg
I am concerned about the security of my data and would like to disable this feature. I do not want my snapshots to be shared on the internet, as I fear that an error could lead to unintended access to my data.
unfortunately I found nothing in this direction is there really no option to do this?
There are settings for this directly in the integration. Unauthenticated endpoints are the only way to make it possible to include snapshots in notifications for most users.
You would have to know the event id, which is randomly generated and not easily guessed. You can use the setting to only allow the requests for events within the last X seconds, so now you have to guess it within a small window of time before it expires.
You can also just disable the unauthenticated proxy and use a different notification service than the home assistant app.
Out of curiosity what benefits would i get switching to or adding webRTC/Go2RTC for restreaming?
I am using the Frigate lovelace card which i assume takes the feed from Frigate directly and not from the camera? I tend to view cameras through the HA app on my iOS device.
I very rarely use the frigate web interface unless im looking at historic stuff.
I have updated to 0.12 and havent changed any configs and things appear to be working as before. However dont want to miss out on any enhancements or performance improvements by not switching to the new stuff.
I have just updated my HACS integration (v4.0.0) and unRAID frigate docker ( 0.12.0-da3e197) to the newer versions, switched over to go2rtc, and removed rtmp entries from my config.
Everything seems OK.
However, I note in my HA logs I am still seeing attempts to connect to rtmp ports which are failing ?
well, RTMP has deprecated so using go2rtc will be required for the camera stream in HA once RTMP is removed.
Lower latency. For me HA had at least 5 second delay, really more. Webrtc is realtime, maybe .5 second lag but it was too short to care or notice.
Less connections to camera. Single connection to camera and all others connections are from go2rtc. Helps if you have bad connections to camera or multiple connections needed.
2way audio support.
I guess at this point i am poorly repeating the readme for the project
I just wondering is there no possibility to import and use own environment variables?
2023-04-14 15:21:04.116940913  [2023-04-14 15:21:04] frigate.detectors.plugins.edgetpu_tfl INFO    : TPU found
  File "/usr/local/go2rtc/create_config.py", line 90, in <module>
    go2rtc_config["streams"][name][i] = stream.format(**FRIGATE_ENV_VARS)
KeyError: 'AICAM_PASSWORD'
Env vars need to start with FRIGATE and I think it only works for mqtt password and camera inputs.
Eg my reolinks password is used like so {FRIGATE_REOLINK_PASSWORD}
The current list is:
Does it work fast like that if you use the HA mobile app?
Yes it can
I’m running Frigate on a Raspi4 with 8Gb
and I’m streaming the video from a camera with a main and a sub stream
do you have any suggestions to reduce the inference speed?
what should be the best resolution for detection?
this is my config.yaml
detectors:
  coral:
     type: edgetpu
     device: usb
go2rtc:
  streams:
    videoSub:
      - rtsp://user:[email protected]:XX/videoSub
      #- "ffmpeg:rtsp_cam#audio=opus"
    videoMain:
      - rtsp://user:[email protected]:XX/videoMain
      #- "ffmpeg:rtsp_cam_sub#audio=opus"
  webrtc:
    candidates:
      - X.X.X.X:8555
      - stun:8555
birdseye:
  enabled: True
  mode: continuous
  #restream: True
objects:
 track:
   - person
#   - car
   - bicycle
   - motorcycle
   - bird
   - cat
   - dog
cameras:
 camera1:
  enabled: True
  ffmpeg:
    inputs:
    - path: rtsp://user:[email protected]:XX/videoMain
      hwaccel_args: preset-rpi-64-h264
      #input_args: preset-rtsp-generic
      input_args: preset-rtsp-restream
      roles:
       - record
    - path: rtsp://user:[email protected]:XX/videoSub
      roles:
       - detect
    output_args:
      record: preset-record-generic
  detect:
    enabled: True
    width: 1280
    height: 720
    fps: 5
    #width: 2304
    #height: 1536
    #fps: 5
  record:
   enabled: True
   retain:
     days: 7
     mode: motion
   events:
     pre_capture: 15
     post_capture: 15
     retain:
       default: 5
       mode: active_objects
       objects:
        person: 5
     objects:
      - person
  snapshots:
    enabled: True
    timestamp: True
    bounding_box: True
    retain:
      default: 5
      objects:
        person: 5
  rtmp:
    enabled: False
Not sure if related but you can reduce the fps on the sub stream. you have it set to 5 in the config but 15 on the camera.
Also you are not using your gortc streams, is that intentional?
i expected:
  ffmpeg:
    inputs:
    - path: rtsp://127.0.0.1:8554/videoMain?video=copy&audio=aac
      roles:
       - record
    - path: rtsp://127.0.0.1:8554/videoSub?video=copy
      roles:
       - detect
Did you ever find anything on this? I have some cameras do the same thing when I enable detect.
Thank you, I am now using CPU acceleration for ffmpeg decoding which helped quite a bit.
Hi @SgtBatten,
thank you.
I’m not getting what you mean with “you are not using gortc stream”, can you help me to understand what I should do?
Note the difference between your config and the ffmpeg section I posted. (which is under your camera1: key. )
In your config your camera inputs is a direct connection to the camera. If you word for word copy what I gave you it will instead have just gortc connect to the camera and then frigate will connect to the gortc restream.
Does any way exists to change timestamp format in Events page?
In HA Settings I have 24h format selected:
frigate does not consider HA settings of course. You need to configure that in the frigate config
Oh yes, I’m really blind. Before I could only see the timestamp_style setting , but now I see it under ui block as well. Thank you.
