Local Tuya: Action LSC Smart Neon LED Strip - datapoints for setup needed 💡
I‘m trying to setup this Smart Neon LED Strip from LSC that was purchased at Action in August 2024 and don‘t know what datapoints to select to make it work locally with the Local Tuya Integration.
Can anyone help me to find the right setup for the datapoints for Local Tuya for these configurations?
Brightness
Color Temperature
Color Mode
Color
Scene
Here are the datapoints that are selectable:
Here is the configuration menue from Local Tuya:
Many thx in advance!
I’ve the same problem only with this model (model: LSC Outdoor Neon Strip 3M)
with an other model It works without any issue (model: Outsmart RGBIC LED)
If I user the tuya integration it’s working but impossible to have the scene.
I found the solution.
First I set all colors via the remote and put it in white so all the ID will appaer in the list
You must configure again everything. Fill in info and you must check the “Do not configure a Cloud API account”
then configure - add new device
fill the friendly name and local key
Choose light and you will be on this page
I set the first option on 20 so I can turn on and off
brightness on the 22 ID
color on 21
with that it will works with the basics
For the others option you must click on configure and edit then try and find with the id’s
finally these settings work form me (i try to have the scene also)
Can you share the configuration of The Outsmart RGBIC LED because i have one and i a unable to make it working. It is detected and i can configure the strp but it stays grey.
Thank you
Edit: i have found the correct configuration.
