Hi together,
I‘m pretty new to HomeAssistant. I have the problem, that if I change the color of a lightgroup (only this specific group and only with localtuya) and then turning it off, the button for this group is still turned on.
I also noticed, that if I wanted to use my „IKEA E2002“ (Zigbee2Mqtt) to cycle the colors of this light group, one lamp would never change its color.
Could you help me to solve this issue with the lightgroup? I believe that both problems are connected somehow.
If I should provide further information, please let me know.
Here is the log:
Logger: homeassistant.components.websocket_api.http.connection
Source: custom_components/localtuya/light.py:345
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 21:05:04 (9 occurrences)
Last logged: 21:51:08
[140237799741840] 'NoneType' object is not subscriptable
[140239236485648] 'NoneType' object is not subscriptable
[140235072545856] 'NoneType' object is not subscriptable
[140239683173200] 'NoneType' object is not subscriptable
[140239267004720] 'NoneType' object is not subscriptable
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 198, in handle_call_service
await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 1808, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1845, in _execute_service
await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 213, in handle_service
await service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 686, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 961, in async_request_call
await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 726, in _handle_entity_call
await result
File "/usr/src/homeassistant/homeassistant/components/light/__init__.py", line 572, in async_handle_light_on_service
await light.async_turn_on(**filter_turn_on_params(light, params))
File "/usr/src/homeassistant/homeassistant/components/group/light.py", line 179, in async_turn_on
await self.hass.services.async_call(
task.result()
await coro
await result
File "/config/custom_components/localtuya/light.py", line 345, in async_turn_on
round(self._hs[0]), round(self._hs[1] * 10.0), brightness
TypeError: 'NoneType' object is not subscriptable
All the Best,
Thomas
