This would be nice to have but very hard to answer i would say, looking forward to hear more
Well that was awkward⌠Turned out to be just needing a power reset on the tuya deviceâŚ
I started using localtuya a few months ago. But I am confused about the âlocalâ of itâŚ
After a month my tuya IOT api trial expired and my devices stopped working in HAâŚ
After renewing the trial it worked again. So how can I prevent this from happening in a few months again when the extended trail expires?
What is making this âlocalâ?
I really donât know about upstream localtuya
whether it has issue that causing it to crash if cloud failed. as far as I know localtuya
shouldnât stop working only cloud features to stops, Tho I canât be so sure your case api expires never happened to me. localtuya
has no interactions with cloud at all other then get devices data.
I havenât tested BLE Devices I only tested ZigBee
, but this might due to your curtain has an issues updating to the gateway or the gateway updates is slow, If Smart Life APP
updated and localtuya
didnât this is something else.
I have this mentioned in 1st the post.
This from my understanding and tests.
The major difference Is probably localtuya
work as HUB
mean all devices can be managed from one account or entry
and Tuya Local
works as Device
Integrations type
More details
localtuya
Core is built-in pytuya
but it also uses TinyTuya
codes as references.
Tuya Local
Core is TinyTuya which is an amazing and active project.
localtuya
is fully customizable and easier to manage devices through UI
Tuya Local
Has a hundreds of yaml
files that contains Tuya Devices data loads with Home Assistant don't know if this is heavy on HA
But This is two-edged sword
in some scenarios you might need to change a values on device config file but the affect will apply after HA restart and changes wonât survive integration updates, but this also the key feature of Tuya Local.
Because localtuya
works as HUB
it can be easier to relay on cloud
and to get devices data to help add device steps and supports discovery
, localtuya
has built with HA in mind so itâs more friendly to Home Assistant at least after I started to understand how pytuya
works.
Tuya Local
is slow when it comes to send multi commands like script or automation I donât know whatâs the specific reason for this but I remember the dev mentioned something for stability commands has delay between each other.
^ For me I didn't like this because the speed difference between running the same script that turn off all switches and close my curtain was really obvious compare to localtuya speed.
This is an example as you can see, this happen when I send commands
to the same device quickly. for example If I turn off my light then turn it on quickly ON
command has delay.
Same test for localtuya
Again this is my using experience, whatever anyone use as long it works fine i think this is good enough.
Thanks for keeping localtuya going like this, that is why I love this community!
I do have one Tuya device I am struggiling to get on HA, I have an EG4 solar heat pump/ac that I found could connect with Tuya. It works good in the smart life app but have no idea how to get this over to HA in any fashion.
In fact my UniFi setup thinks itâs a lightbulb! Any help or a point in the right direction would be greatly appreciated.
I checked both the gateway and the tent: they are up to date. the awning does not respond to commands. How can we verify the functioning and thus improve the fork?
I might misunderstood your issue.
If it only the commands
that are slow and states updates normally, Is this issue also happen if you control your curtain through smart life app
or only on localtuya
If you mean states not update or updates slow
What I mean by update not the firmware.
If there an action happened to your curtain update
Your curtain should reports to your gateway new states like position, open or close
So my guess either your device is slow on reports or the gateway reports to localtuya
is slow. however to make sure. Starts Smart Life
on your phone then use the remote to control your curtain. at the same time check the states of your curtain on smart life
If the states updated on smart life
and not updated on localtuya
this an integration issue, but if smart life
also slow at update this probably gateway
or curtain
issue.
Maybe try testing the integrations and if there is an issues or error post it.
If already have Tuya account everything should works easy for you : )
sorry, my first message was wrong or imprecise. I have to test the functionality better and more calmly. Thank you
Sorry I missed that! This is a good explanation, thank you! I only have one Tuya device, a ceiling fan. (I couldnât find a fan with the combination of features I wanted without Tuya, unfortunately.)
I avoid Tuya by rule. I used to have a bunch of Tuya-based Wifi plugs that we just unreliable because of internet and/or cloud issues. (I replaced them all with Z-Wave ones, and wish I had used Zigbee instead, but thatâs a different subject.) This project probably would have been a good fit then, if I had known about it!
Can you show me your entry diagnostics
check the chat if you want to send it there.
bw_lt11 devices can be inserted manually using data obtained from iot with firmware 3.1
Youâre the man @umu_ugg!!
Lack of support for Protocol Version 3.5 is exactly the problem I had identified, googled it, found this thread, installed your fork â et voila!
All devices found and working.
Many thanks for this!!
Thx for this Fork, seems to work fine, thou i couldnât find a âstep by stepâ instructions howto âmergeâ with âupstreamâ , so what i did was
- installed the integration
- Restarted and verified in Devices/Integrations that it had âChanged Ownerâ
- Deleted the âoldâ Integration in HACS, Kept Settings ! Restarted ( Scaring , as nothing worked then ! )
- Re-downloaded this Fork, and everything worked Great again !
Seems like i even got rid of alot Errors in my Log, the âoldâ was spewing constantly , so for about a year ago i changed Logging to âCriticalâ for LocalTuya , now iâve changed it back to Default
I donât know how well the merging from upstream to the fork will still work, at least for everyoneâs cases Thanks for pointing that out
What I did to test the merging before is 1. Delete the integration from HACS ignore
the message HACS popup 2. I installed the fork 3. Restart HA.
Yeah i was afraid i would loose all my Devices, ( been a year since ive been into tuya.iot, hope i have the password somewhere
Anyways i tried what i thought was the âsafeâ way
Would be nice to be able to control Tuya devices over Cloud
Does anyone know if this fixes the bug in localtuya that prevents devices with non-alphanumeric characters in their local key being registered? Iâm snookered with a Tuya thermostat which doesnât display correct values using the Tuya integration and wonât register with the localtuya integration because of the (newly introduced) non-alpha local keys.
