So similar to these threads:
Local Tuya Unavailable - #5 by Webon, (local)Tuya Smart Plug goes 'unavailable' for 7min once or twice a day - #26 by Istria1704, Local Tuya Becomes Unavailable - #4 by banderson1311
The device in question is a Wi-fi plug which I have 4 around the house. One is plugged into the freezer in the back. You could say it is the furthest device from the Wi-fi router.
It tends to work but every now and then I get this
meanwhile It is fine on the normal integration
If I redo it
It seems to have the settings & values
These are live power values. So why is it the device is unavailable? I would assume there’s something to do with the Wi-fi, Since the other three identical plugs do not seem to have this problem.
I don’t want to try to delete the device and start again because sometimes I don’t get the key Because the tuya dev login etc.
But what can I do to make this a lot more reliable?
