after migrating all of my lights from Tuya Cloud to Local Tuya, this morning I made a test disconnecting the internet connection.
I sadly found out that only 3 of my 21 Local Tuya lights were really working without internet connection.
Following some suggestions I found on the web I removed from Local Tuya configuration the
Cloud API details:
Nothing changed, the 3 working lights keep working, the others were still unavailable.
Looking around in the forum I found a link to Local Tuya readme file stating this:
NOTE - Nov 2020: If you plan on integrating these devices on a network that has internet and blocking their internet access, you must block DNS requests too (to the local DNS server eg 192.168.1.1). If you only block outbound internet then the device will sit in zombie state, it will refuse / not respond to any connections with the localkey. Connect the devices first with an active internet connection, grab each device localkey and then implement the block .
This is something I do not understand, how should I block internet access only to those lights and DNS ? I looked into my router setting and I cannot understand how to do this.
