Local Voice Commands with ESP32s3 Dev Module
The Espressif ESP32-S3-Korvo-1 developer module comes with all the hardware features expected for a smart speaker but in a DIY format: mic array, speaker output, addressable leds, push buttons, sd card, battery charger. Espressif provides example software that implements the necessary audio processing, wakeword detection, and voice command identification. I merged the voice command example with the source files resulting from an ESPHome configuration for the dev module to create a usable voice command interface for HA. The example software provides up to 200 preprogrammed voice command phrases. Automations related to each phrase must be configured in HA.
Wakeword detection seems to be on par with existing commercial smart speakers. The voice command recognition is usable but way more sensitive to ambient noise and distance to speaker. Steps to setup build environment and configure the software are posted in this github repository:
Very interesting! Would this be the simplest way to achieve local voice command on HA?
I’m not really familiar with any of the other methods for a good comparison. I had started out to add support for this dev board to the ESP32 Rhasspy Satellite project but got sidetracked a bit. My current implementation is not the most user friendly but should not be much trouble for users with linux / programing experience to get working. It has benefit that all the audio processing is done right on the device so good for users with HA running on a system with less resources.
Hello, nice work!
now we have voice-assist with 2023.5.0 core of HA, there is a much simple way to use a Atom Echo for Speech-to-text and let your HA hardware make the work of recognition.
But there is no more Atom Echo available now.
I search a way to use a standard ESP32 with inmp441 to do the job, is someone has succeed in please?
ESPHome 2023.4 added microphone support, I was looking into using onboard wakeword detection that that then feeds the processed audio to the HA once activated.
which hardware do you use please? PDM, ADC or I2S microphone? and which one ESP32?
thanks
@Olivier974 as example this one:
https://www.aliexpress.com/item/1005002803964499.html
I got mine today and it is the original Espressif:
Thanks!
nice board, very complete.
I am very interested in your project.
“Mixing” ESPHome with sample code couldn’t have ben easy! Great work.
I’d like to make something like a wearable Star Trek badge, with a Push-Button or Touch Sensor as I don’t really trust wake words, plus it must use a lot of battery.
One mic pointing “up” towards the mouth might be enough as I think the array would point “away”.
If I were to do that I would also have to “mess” with the mic array code and I’m afraid :crazy_face:
I appreciate the building instructions on your Github page but for now I don’t trust myself to make the mods.
Anyway, I’ll follow your project with much interest; thank you
Have you had any luck getting yours to work with HA / ESPHome? I’ve been able to get the default Chinese language firmware working, but everything audio related I try to do with ESPHome has not worked. I’ve got the buttons and the LEDs working, but no audio in or out.
Could you share your pin configuration? I’m not sure I haev mine correct.
It works but needs some attention to detail like the S3 Box variants
substitutions:
#  name: korvo
  friendly_name: korvo
esphome:
  friendly_name: ${friendly_name}
  name_add_mac_suffix: true
  platformio_options:
    board_build.flash_mode: dio
    upload_speed: 460800
  project:
    version: "1.0"
  min_version: 2023.11.1
  on_boot:
    - priority: 600
      then:
        - light.turn_on:
            brightness: 70%
            effect: connecting
esp32:
  board: esp32-s3-devkitc-1
  framework:
    type: esp-idf
    sdkconfig_options:
      CONFIG_ESP32S3_DEFAULT_CPU_FREQ_240: "y"
      CONFIG_ESP32S3_DATA_CACHE_64KB: "y"
      CONFIG_ESP32S3_DATA_CACHE_LINE_64B: "y"
      CONFIG_AUDIO_BOARD_CUSTOM: "y"
      CONFIG_ESP32_S3_KORVO1_BOARD: "y"
    components:
      - name: esp32_s3_korvo1_board
        source: github://abmantis/esphome_custom_audio_boards@main
        refresh: 0s
psram:
  mode: octal
  speed: 80MHz
external_components:
  - source: github://pr#5230
    components: esp_adf
    refresh: 0s
ota:
logger:
api:
  on_client_connected:
    then:
      - if:
          condition:
            switch.is_on: use_wake_word
          then:
            - delay: 1s
            - voice_assistant.start_continuous:
            - delay: 1s
            - voice_assistant.stop:
            - delay: 2s
            - script.execute: reset_led
  on_client_disconnected:
    then:
      - light.turn_on:
          blue: 0%
          red: 100%
          green: 100%
          brightness: 50%
          effect: connecting
dashboard_import:
  package_import_url: github://esphome/firmware/voice-assistant/esp32-s3-korvo1.yaml@main
wifi:
  use_address: 192.168.0.xx
  ap:
  on_connect:
    then:
      - delay: 5s # Gives time for improv results to be transmitted
      - ble.disable:
  on_disconnect:
    then:
      - ble.enable:
improv_serial:
esp32_improv:
  authorizer: none
button:
  - platform: factory_reset
esp_adf:
  board: esp32s3korvo1
microphone:
  - platform: esp_adf
speaker:
  - platform: esp_adf
voice_assistant:
  microphone: korvo_mic
  speaker: korvo_speaker
  noise_suppression_level: 4
  auto_gain: 10dBFS
  volume_multiplier: 1
  use_wake_word: false
  on_listening:
    - light.turn_on:
        blue: 100%
        red: 0%
        green: 0%
        brightness: 100%
        effect: wakeword
  on_tts_start:
    - light.turn_on:
        blue: 0%
        red: 0%
        green: 100%
        brightness: 50%
        effect: pulse
  on_end:
    - delay: 100ms
    - wait_until:
        not:
          speaker.is_playing:
  on_error:
    - light.turn_on:
        blue: 0%
        red: 100%
        green: 0%
        brightness: 100%
        effect: none
    - delay: 1s
    - script.wait: reset_led
    - lambda: |-
        if (code == "wake-provider-missing" || code == "wake-engine-missing") {
          id(use_wake_word).turn_off();
script:
  - id: reset_led
    then:
      - if:
          condition:
          then:
            - light.turn_on:
                blue: 100%
                red: 0%
                green: 0%
                brightness: 30%
                effect: none
          else:
            - light.turn_off: led_ring
switch:
  - platform: gpio
    pin: GPIO38
    name: "${friendly_name} Speaker Mute"
    restore_mode: ALWAYS_ON
    name: Use wake word
    optimistic: true
    restore_mode: RESTORE_DEFAULT_ON
    entity_category: config
    on_turn_on:
      - lambda: id(voice_asst).set_use_wake_word(true);
      - if:
          condition:
            not:
              - voice_assistant.is_running
          then:
    on_turn_off:
light:
  - platform: esp32_rmt_led_strip
    pin: GPIO19
    num_leds: 12
    rmt_channel: 0
    rgb_order: GRB
    chipset: ws2812
    default_transition_length: 0s
    effects:
      - pulse:
          transition_length: 0.5s
          update_interval: 0.5s
      - addressable_twinkle:
          twinkle_probability: 5%
          progress_interval: 4ms
      - addressable_color_wipe:
          colors:
            - red: 0%
              green: 50%
              blue: 0%
              num_leds: 12
          add_led_interval: 20ms
          reverse: false
          colors:
            - red: 60%
              green: 60%
              blue: 60%
              num_leds: 12
            - red: 60%
              green: 60%
              blue: 0%
              num_leds: 12
          add_led_interval: 100ms
          reverse: true
binary_sensor:
    name: "${friendly_name} Volume Up"
    name: "${friendly_name} Volume Down"
    on_multi_click:
      - timing:
          - ON for at least 10s
        then:
          - button.press: factory_reset_btn
    on_press:
      - voice_assistant.start:
      - light.turn_on:
          brightness: 100%
          effect: "Wakeword"
    on_release:
      - light.turn_off:
  - id: button_adc
    platform: adc
    internal: true
    pin: 8
    attenuation: 11db
    update_interval: 15ms
    filters:
      - median:
          window_size: 5
          send_every: 5
          send_first_at: 1
      - delta: 0.1
    on_value_range:
      - below: 0.55
        then:
          - binary_sensor.template.publish:
              state: ON
      - above: 0.65
        below: 0.92
        then:
              state: ON
      - above: 1.02
        below: 1.33
        then:
              state: ON
      - above: 1.43
        below: 1.77
        then:
              state: ON
      - above: 1.87
        below: 2.15
        then:
              state: ON
      - above: 2.25
        below: 2.56
        then:
              state: ON
      - above: 2.8
        then:
              state: OFF
              state: OFF
              state: OFF
              state: OFF
              state: OFF
              state: OFF
This take advantage of all microphones? I’ve tried manny setup versions, but none of them are closer to Alexa or Google Nest at detecting wake word (with or without microwakeword). TTS aparently works well. But detecting wakeword works only if i am next to korvo or speak verry loud. Can we use audio drivers and wake word engine from skainet? I’m not good with pyton programing but i can work with yaml
