Local Voice Control
Ran a test today to see just what works when the router is disconnected from the internet. Was pleasantly surprised to learn that Alexa was able to control the Zigbee lights paired directly to the Echo hub, as well as the multitude of lights and switches that are visible to Alexa through the emulated Hue bridge.
I have an Echo Plus 1st gen as well as an RPi 3+ fitted with a HUSBZB1 running Home Assistant. A half dozen CCT EcoSmart Zigbee bulbs are still paired to the Echo, and two Merkury A21 RGB WiFi bulbs are linked to Alexa via the SmartLife app. This allows me to have CCT or RGB voice control of those bulbs without allowing Alexa to my HA setup via the cloud. Home Assistant consists of Belkin and TP-Link integrations for some in-wall dimmers and smart plugs, and LocalTuya for a couple of smart plugs as well as the afore-mentioned RGB bulbs linked to SmartLife. 15 additional Zigbee bulbs and outlets are paired through ZHA. All of the above are made available to Alexa for voice control of on/off/dimming by the Emulated Hue feature of Home Assistant. Again, the setup does not use Hue, Home Assistant, Nabu, skills or subscriptions or cloud access to my HA setup.
Even though the Zigbee hub is somewhat redundant as I have mostly migrated away from the Echo Plus, its local voice control feature works for lighting and switch devices that belong to my HA hub. Only the 1st & 2nd gen Echo Plus and original Show 10 feature local voice control, though all Echo devices have access to the emulated Hue feature when connected to the internet.
thank you, that was exactly the information I was looking for. Can I control the devices connected via emulated_hue offline via echo dot plus. YOU say yes, great.
i don’t want to connect the alexa to the internet and still use local voice control. will test this and buy an echo plus.
does this work reliably for you?
Haven’t experienced any issues, though my internet is pretty reliable so I don’t have a lot of experience with Echo Plus local voice control, as that feature is only available when Alexa cannot reach the internet.
On the other hand, I have been using the Emulated Hue feature in Alexa to reliably control dozens of devices for several years.
Hello, I also have an Echo Plus (2nd gen) and I am trying to get local voice Control running, but it seems it doesn’t work anymore. I activated local voice control in the Alexa app and bulbs are connected via emulated hue to Echo Plus, but unfortunately it doesn’t work without internet connection. Any ideas? Is it only working for specific countries or did Amazon deactivate the feature?
Thanks for your help!
Not much help here. I added an Echo Show (2nd gen 10.1) to my system and replaced it as the Zigbee hub for Alexa instead of the Echo Plus. Not sure if it ever did the local behavior correctly. Again, my internet has been rather steady for several years, and I haven’t made the effort to test this in a couple of years. I also added an Echo Studio, which also has the zigbee hub feature.
According to an archived Amazon page:
Actions Available with Local Voice Control
If your Echo with a built-in smart home hub is not connected to the Internet, you can use your voice to:
Control compatible smart home devices, including switches, lights, and plugs, that are connected directly to your Echo device.
Ask for the time or date.
Stop or cancel alarms, reminders, and timers that were set before your Echo device went offline.
Control the device's volume.
Alexa also responds to the inquiry, “What can you do offline?”
