I have flashed a tasmota plug with esphome (minimal) to install the https://github.com/JamesSwift/localbytes-plug-pm firmware. So currently it simply has minimal esphome. It is connected to my wifi and, in HA Integrations, I added this device to ESPHOME using the ip address.
It is in HA but is not showing in the actual Esphome web page.
The project has the following statement:
At this point you can use the “dashboard import” feature of esphome to take ownership of the device. The next time you hit install/update via the dashboard, the full firmware will be uploaded to the plug.
So this would suggest that “import” would automatically add an entry to EspHome where I can do whatever is required with Yaml code. First I would install the full firmware but this suggests it would do that there.
I have only done initial installs of devices that I can attach to my laptop and this allows me to pick up the appropriate api and ota details so that I can ensure any new yaml has this info.
Not sure what I have to do now to get this properly into Esphome. If I simply add a new device in ESPHOME, I will end up overwriting the Yaml with code that does not reflect the firmware required.
I did get a copy of the yaml from the project and created a tailored copy of it for a new Esphome device, with a manual ip of the minimal esphome plug. That has updated and started the plug correctly but I don’t think this is the correct way. It meant I had to comment out the dashboard_import as I expect this will overwrite my yaml if an update is detected and applied. This would clear out my wifi, ota, encryption details.
I also see in some online conversations that Esphome should actually give an option in the Esphome web page to “Adopt” a “Discovered” Esphome device. I don’t think I ever get that in my HA Esphome. I have to add esphome flashed devices in the Integrations page using the ip address.
This is another project waiting for me get round to it! I have a few of these, ALL with Tasmota and I have one that I “freed” ready for the change over.
I’ve converted a few other devices from Tasmota to ESPHome and I’m realitively happy with the process now. I found that it is MUCH easier if you name the device in ESPHome rather than use the generic naming. It could just be me, but I found the whole conversion process was smoother when doing this, no issues with keys and passwords and joining to HA/ESPHome.
So I’ve always created a new ESPHome device with a new name and minimal configuration. Once that’s working pasted in the new code, or used a package.
So far I’ve converted Sonoff Mini R2s and TCPSmart Plugs(UK) and (touch wood) all are absolutely fine. My ESPhome page is now getting a bit unwieldy now though. Hey, another project!!!
I am having the same issue. I did flash the Local Bytes smart plug with the minimal ESPhome image and now I don’t know how how to upload the full image in Home Assistant…
I haven’t been through the process on the LocalBytes plugs, but I’ve been through a similar process converting my TCPSmart plugs from Tasmota to ESPHome.
Sorry, re-reading the minimal code, there isn’t a webserver!
That implies that once you’ve adopted the device in the ESPHome dashboard, if you hit update, it loads the new code!? From the minimal yaml file,
I’m very interested in how this goes, as I’m about to do this to my existing LocalBytes Tasmota plugs. So I’ll do my best with what I’ve learned so far… I’m no expert!
I think it’s talking about the Update when the code is outdated? So if you used a downloaded file, it should be outdated and needs updating?
Nothing happened to my smart plug yet. I have delete it from the ESPhome integration, added back, nothing.
I wonder if there is any way to do a hard reset on the smart plug, so I force it into forgetting my Wi-Fi network. Then I could access it via the web UI on the “Localbytes Plug PM” SSID and push the “full” image.
I put both, the minimal and full configuration YAML files in the ESPHome folder.
Trying to upgrade the firmware using the “Install” feature in ESPHome Dashboard , I get the “ERROR Error receiving acknowledge version: timed out” error and the installation stops.
Here is the log:
INFO ESPHome 2023.11.6
INFO Reading configuration /config/esphome/localbytes-plug-pm.yaml...
INFO Generating C++ source...
INFO Compiling app...
Processing localbytes-plug-pm (board: esp01_1m; framework: arduino; platform: platformio/[email protected])
HARDWARE: ESP8266 80MHz, 80KB RAM, 1MB Flash
Dependency Graph
|-- ESPAsyncTCP-esphome @ 2.0.0
|-- ESPAsyncWebServer-esphome @ 3.1.0
|-- DNSServer @ 1.1.1
|-- ESP8266WiFi @ 1.0
|-- ESP8266mDNS @ 1.2
|-- ArduinoJson @ 6.18.5
Compiling .pioenvs/localbytes-plug-pm/src/esphome/components/api/api_connection.cpp.o
Compiling .pioenvs/localbytes-plug-pm/src/esphome/components/api/api_frame_helper.cpp.o
Compiling .pioenvs/localbytes-plug-pm/FrameworkArduino/umm_malloc/umm_poison.c.o
Archiving .pioenvs/localbytes-plug-pm/libFrameworkArduino.a
Linking .pioenvs/localbytes-plug-pm/firmware.elf
RAM: [==== ] 43.1% (used 35320 bytes from 81920 bytes)
Flash: [===== ] 48.6% (used 498005 bytes from 1023984 bytes)
Building .pioenvs/localbytes-plug-pm/firmware.bin
esp8266_copy_factory_bin([".pioenvs/localbytes-plug-pm/firmware.bin"], [".pioenvs/localbytes-plug-pm/firmware.elf"])
======================== [SUCCESS] Took 228.03 seconds ========================
INFO Successfully compiled program.
INFO Connecting to 10.1.20.22
INFO Uploading /data/build/localbytes-plug-pm/.pioenvs/localbytes-plug-pm/firmware.bin (502160 bytes)
I gave up. I may be an idiot, but this plug is crap - I resorted to ESPHome because there was no power coming out of the plug and I assumed this was due to the latest Tasmota firmware I upgrade it to.
I don’t have the spare time to waste on this plug any longer - I’ll put it into the WEEE bin and look for an alternative.
