I installed for the first time the localtuya third party integration.
But 8 days ago there was a new release where the config.yaml is ignored, see docs on https://github.com/rospogrigio/localtuya
I don’t find already how to show and use the current, power and voltage in dashboard. Before you could easy adapt the config.yaml but now this is not possible anymore.
Some older let see power consumption in time.
Any help would be appreciated.
BTW: The reading from the sensors itself works fine and if I click on the sensor the value are showed correctly.
