Hi to all, I successfully installed some smartplugs (Teckin SP22) with localtuya. All is working as expected. Now I tried to remove internet access to the smartplugs, via a simple firewall rule. As soon as the plugs did not get access to internet I loose the Watt and Voltage readings in homeassistant. I can switch them on and off in any case.
Is it “by design” or can I do something?
Probably best asked to the manufacturers of your plugs.
I’m pretty sure the integration just reports what is available and surely do not need internet access.
Tuya, otoh, is 100% cloud based, so it wouldn’t surprise me that the plug doesn’t bother with the energy side if it cannot report it to the cloud.
EDIT: Or just a plain bug in the plug fiirmware in the case of unavailable cloud connection.
