I’ve added my LEDVANCE SMART+ ORBIS ULS235W via the LocalTuya integration.
Unfortunately, I can only turn the light on or off. However, I would like to control the individual lights (main light and background light) separately. How can I achieve this? Unfortunately,
If you have a problem with a specific custom integration, your first step should be to check the original GitHub post where you found it. The people there know the product and use the software, so they can give you better help with your issue. You might find someone here who can help, but it’s not guaranteed.
Hi
I’m using a Ledvance Smart+ Orbis UL Slim BL 235RGBTW WT
I got my first of these working today.
I added this HACS integration Tuya Local, https://github.com/make-all/tuya-local
This gave me both the Backlight, the Panel Light, a Switch, and the Timer.
I made two discoveries, firstly when using and automation I need to turn on the Panel Switch then the light, Panel or Backlight.
If I want to change the brightness or colour I need a second turn on action with the changes.
Secondly, I need to turn off the light and then the switch, otherwise turning on the swich again will turn on the last on light with the settings it had.
For example, I want the Panel Light during the day and the Backlight at night, if I do not turn off the Panel Light and then the Switch, the activation at night will turn on the Switch and with it the Panel Light.
If you use the Ledvance Smart+ app you can get the LocalKey as well the device ID.
