LocalTuya - confused when adding entities for a RGB(W) light
I have attempted adding my first LocalTuya device. The RGB light device was found and the Local Key worked. I then got to the addition of entities. The DPIds available were 20 through to 26.
I found the following list of DPIDs for Tuya lights and progressed through associating each of these devices in line with the DPIDs available:
I am not sure I did this correctly and need help:
  1. Should every entity be added as a type of device domain of “light”, even if it acts like another type (such as Switch which is basically an on/off action)? I did add the DPID for switch as a Switch.
  2. I really was unsure about Mode and added this as a number, as I was fooled by the enum type. How should this have been added and what selected as an attribute?
  3. Is there any way of deleting an entity in LocalTuya so that I can then re-add it correctly? It appears to me that I have to delete the whole device if I make a mistake with the entity domain type. If it can be done away from the UI, I am happy to edit whatever files support this.
  4. Once added, icon changes within the HA entity appeared to make no difference e.g. changing a light icon to palette, for the colour DP, made no difference and it was still a lightbulb icon.
If anyone has examples of how they have set up DPIDs 20-26 for a light, I would be grateful to know.
Ok. Moved on a bit myself thanks to Adding Local Tuya Devices (Dekala Arkenstone Lamp).
However, my attempt is still behaving strangely. I have added a basic switch and 6 sensors for my light (switch/work mode/brightness/colour temp/colour data/scene data/countdown). These were all picked up from scanning for the device.
I expected to be able to do 2 things:
  1. For my added entities above, change these to meaningful values, including setting max/mins for brightness. However in Edit, I get the following window, which looks nothing like the windows I see in How To videos online. They all seem to have a number of fields representing colour temperatures/brightness/etc.
2022-10-28
  1. I was also under the impression that I could add entities by adding another LocalTuya integration and selecting the light just added. What actually happens is I have to enter the api details a second time, I get a “Failed to retrieve a Device List” message, The only way it does is if I tick the “Do not configure Cloud API account” and that reconfigure Tuya entirely, removing the device I have added previously. I have clearly not set this up correctly but have no idea what I have missed. Tuya IOT platform seems ok but I am sure I must have messed up somewhere.
With the way things are working for me now, I can only have one LocalTuya device and that is really only partially added as entities are not complete.
Add your comments here about reconfigure devices. Has been an issue for some time.
