Hi
I’m currently using tuya plugs and tuya wifi blind motor with localtuya, and they work great.
But whenever I plugged out and re-plug in the blind motor, the blind stops working.
And if I try to reconfigure the blind motor, the entity id 1(which must be selected to make it work) doesn’t show up on the configuration panel.
What would be the problem?
I tried reinstalling localtuya through HACS and manual, restarted my HA and NAS, replug the blind motor several times, configuring through yaml. nothing helps
Actually I experienced this problem months ago, and for no reason it fixed by itself while I was trying numerous methods. But I don’t know the solution for sure…
