Localtuya - integrate climate - SIRO WLAN Smart room thermostat
I have the following room thermostat:
SIRO WLAN Smart Raumthermostat
Which I would like to integrate via the localtuya integration.
localtuya has been set up and I can also find my thermostat.
However, if I now want to integrate it as the “climate” type, I have to configure many values ​​for which I have not been able to figure out what to enter here.
According to the Tuya Cloud Platform, this is the product:
WBR3-HYWE
WBR3 Module Datasheet-Tuya IoT Development Platform-Tuya Developer
in Home Assistant I have to define the following values:
Available Values:
      "dps_strings": [
        "1 (value: True)",
        "2 (value: 290)",
        "3 (value: 195)",
        "4 (value: Manual)",
        "6 (value: False)",
        "12 (value: 0)",
        "101 (value: False)",
        "102 (value: True)",
        "103 (value: 0)",
        "104 (value: 1)",
        "105 (value: 15)",
        "106 (value: True)",
        "107 (value: True)",
        "108 (value: False)",
        "109 (value: -10)",
        "110 (value: 10)",
        "111 (value: 2)",
        "112 (value: 45)",
        "113 (value: 5)",
        "114 (value: 35)",
        "115 (value: 5)",
        "116 (value: in)",
        "117 (value: keep)",
        "118 (value: 2 days)"
Can you help me to do the right assignment?
Thanks very much!
Max
Hello all together,
does anybody has an idea how to configure the thermostat? I have also tried to intergrate the SIRO-WLAN-Raum-Thermostat, without success. The temp_set and the temp_current are shown as 190.0°C instead of 19.0°C and changing the set-temp results in 5°C shown at the display of the device.
Also no sensors are shown under this device. Is this correct?
Best regards,
chrclaus
Hi Max, nachdem Dein Thermostat “Raumthermostat EG” heißt, schreibe ich Dir in Deutsch.
Hast Du das denn inzwischen hinbekommen mit dem SIRO Thermostat und der local Tuya integration? Es gibt ja inzwischen eine direkt in HA verfügbare Tuya Integration. Leider kann ich den Thermostat dort zwar steuern aber nicht programmieren, also meine Urlaubstage einstellen etc.
Geht das bei der local Tuya? weißt Du das und wenn ja, was hast Du denn alles eingestellt?
Schönes Wochenende
Rainer
Ich stehe vor dem gleichen Problem. Unter der normalen Tuya Integration kann ich nur Schalten und hab keine Temperatur. Tuya.local hab ich gerade probiert, allerdings kein Plan was ist einstellen muss. Vielleicht könnt ihr mir helfen?
