Location of downloaded HACs cards
Hello.
So I downloaded this card:
using HACS.
It downloaded it to www/community or at least that is where I can see it when I go to file editor to find it.
the documentation says add the following:
resources:
  • url: /local/vacuum-card.js
    type: module
but this did not work, while adding
  • url: /hacsfiles/vacuum-card/vacuum-card.js
    type: module
did work. I got this code from a previous card I had downloaded that was in the same folder.
Am I downloading them wrong? Do not think I can be as I use HACs to download.
If not should local work or is that just how the documentation for card works and I need to put the right file path?
Also, how does “hacsfiles” even work as a file path?
Thank you!
I believe the HACS integration maps www/community to /hacsfiles/ for you, but only the developer can confirm that as I’ve not looked at the source personally.
