Location permission issues
Hello all,
I recently swap my preiovus phone for Pixel 7 Pro. Installed HA and discovered that my local instance is not working when I don’t grant high accuracy permission. Is it normal thing?
When I disable location I got a monit about not trusted certificate… but I don’t have a one on local instance (just using http). When I turn off WiFi and set mobile network It was working with cloudflared tunnel. Any advice?
@Update
Okay, previously on other phone there was an option to identify home network and forward to local instance or just try local instance first. Now if location is turned off it’s trying to reach my remote instance and Cloudflared tunnel is not working locally.
I’m not sure if I want to share my location constantly to HA and drain battery but do I have any choice now?
In order to read the connected WiFi SSID the app needs location permissions and location to remain enabled on the device. That’s a Google requirement.
