I use Owntracks to update positioning throughout a couple of zones, which works well enough. Is it possible to set the location value of someone who is actively moving to something like “en route”? Like if longitude/lattitude has changed by X amount (distance) over time between updates, status is en route?
Any other way y’all could think of that would allow me to trigger things when someone is on the move?
I have not tested it as vac only appears when there is movement. The sensor might fail at first as there wont be a value to show. it should just say unknown though.
The owntrack website states the following: The acc, alt, cog, vac, vel elements are only added if they are not zero vel velocity (iOS/integer/kmh/optional)
If its optional it need to be activated by creating a settings file for owntracks. I have done this when I first set it up but it was a real pain and I cant remember how I got it to work.
