my partners logg
--------- beginning of system
09-16 11:51:42.715 14854 14854 W Activity: PerfMonitor: Slow Operation: Activity io.homeassistant.companion.android/.webview.WebViewActivity onCreate took 1348ms
09-16 11:51:42.995 14854 14854 W Activity: PerfMonitor: Slow Operation: Activity io.homeassistant.companion.android/.webview.WebViewActivity onResume took 274ms
09-16 11:51:43.020 14854 14854 W Looper : PerfMonitor longMsg : seq=3 plan=11:51:40.684 late=606ms wall=1729ms h=android.app.ActivityThread$H w=159 procState=-1
09-16 11:51:43.020 14854 14854 W Looper : PerfMonitor looperActivity : package=io.homeassistant.companion.android/.webview.WebViewActivity time=1729ms latency=606ms procState=-1 historyMsgCount=2 (msgIndex=2 wall=594ms seq=2 late=52ms h=android.app.ActivityThread$H w=110)
09-16 11:51:43.035 14854 14854 W Looper : PerfMonitor looperActivity : package=io.homeassistant.companion.android/.webview.WebViewActivity time=0ms latency=2346ms procState=-1 historyMsgCount=3 (msgIndex=2 wall=594ms seq=2 late=52ms h=android.app.ActivityThread$H w=110) (msgIndex=3 wall=1729ms seq=3 late=606ms h=android.app.ActivityThread$H w=159)
09-16 11:51:43.046 14854 14854 D FramePredict: FramePredict init: false
09-16 11:51:43.219 14854 14854 W Looper : PerfMonitor doFrame : time=174ms vsyncFrame=0 latency=1872ms procState=-1 historyMsgCount=6 (msgIndex=1 wall=594ms seq=2 late=52ms h=android.app.ActivityThread$H w=110) (msgIndex=2 wall=1729ms seq=3 late=606ms h=android.app.ActivityThread$H w=159)
09-16 11:51:43.439 14854 15064 W Looper : PerfMonitor longMsg : seq=1 plan=11:51:42.160 late=1ms wall=1277ms h=android.os.Handler c=WV.V80 procState=-1
--------- beginning of main
09-16 11:51:44.363 14854 14854 D DecorView[]: getWindowModeFromSystem windowmode is 1
09-16 11:51:44.363 14854 14854 D DecorView[]: updateDecorCaptionStatus windowMode is 1
09-16 11:51:44.377 14854 15297 D TrafficStats: tagSocket(271) with statsTag=0xffffffff, statsUid=-1
09-16 11:51:44.379 14854 15300 D TrafficStats: tagSocket(273) with statsTag=0xffffffff, statsUid=-1
09-16 11:51:44.394 14854 15296 D TrafficStats: tagSocket(272) with statsTag=0xffffffff, statsUid=-1
09-16 11:51:44.425 14854 15298 D TrafficStats: tagSocket(274) with statsTag=0xffffffff, statsUid=-1
09-16 11:51:44.454 14854 14923 W mpanion.android: Long monitor contention with owner DefaultDispatcher-worker-5 (14928) at retrofit2.ServiceMethod retrofit2.Retrofit.loadServiceMethod(java.lang.reflect.Method)(Retrofit.java:205) waiters=4 in retrofit2.ServiceMethod retrofit2.Retrofit.loadServiceMethod(java.lang.reflect.Method) for 242ms
09-16 11:51:44.464 14854 15325 D TrafficStats: tagSocket(275) with statsTag=0xffffffff, statsUid=-1
09-16 11:51:44.470 14854 15326 D TrafficStats: tagSocket(278) with statsTag=0xffffffff, statsUid=-1
09-16 11:51:44.658 14854 14934 W RenderInspector: DequeueBuffer time out on io.homeassistant.companion.android/io.homeassistant.companion.android.webview.WebViewActivity, count=3, avg=30 ms, max=41 ms.
09-16 11:51:44.876 14854 14926 D LocBroadcastReceiver: Registering for location updates.
09-16 11:51:44.907 14854 14923 D LocBroadcastReceiver: High accuracy mode geo parameters changed. Reconfigure zones.
09-16 11:51:44.907 14854 14923 D LocBroadcastReceiver: Removing geofence location requests.
09-16 11:51:44.920 14854 14922 D LocBroadcastReceiver: Background location updates appear to have stopped, restarting location updates
09-16 11:51:44.920 14854 14922 D LocBroadcastReceiver: Removing background location requests.
09-16 11:51:44.933 14854 14923 W LocBroadcastReceiver: Not registering for zones as we already have / haven't
09-16 11:51:44.986 14854 14922 D LocBroadcastReceiver: Registering for location updates.
09-16 11:51:45.520 14854 15288 D WebviewActivity: External bus {"type":"connection-status","payload":{"event":"connected"},"id":2}
09-16 11:51:45.531 14854 14854 D ServerConnectionInfo: localUrl is: false, usesInternalSsid is: false, usesWifi is: true
09-16 11:51:45.877 14854 14925 D ServerConnectionInfo: localUrl is: false, usesInternalSsid is: false, usesWifi is: true
09-16 11:51:45.922 14854 15209 D ServerConnectionInfo: localUrl is: false, usesInternalSsid is: false, usesWifi is: true
09-16 11:51:45.937 14854 14928 D ServerConnectionInfo: localUrl is: false, usesInternalSsid is: false, usesWifi is: true
09-16 11:51:46.133 14854 15288 D WebviewActivity: External bus {"type":"theme-update","id":3}
09-16 11:51:46.144 14854 14854 D WebviewActivity: Color from webview is "#03a9f4-SPACER-#fafafa"
09-16 11:51:46.145 14854 14854 D WebviewActivity: Color from webview is "#03a9f4-SPACER-#fafafa"
09-16 11:51:46.145 14854 14928 D WebViewPresenterImpl: Try getting color from webview color "#03a9f4".
09-16 11:51:46.145 14854 14928 I WebViewPresenterImpl: Found color -16537100.
09-16 11:51:46.146 14854 14928 D WebViewPresenterImpl: Try getting color from webview color "#fafafa".
09-16 11:51:46.146 14854 14928 I WebViewPresenterImpl: Found color -328966.
09-16 11:51:46.175 14854 14854 D LocBroadcastReceiver: Received geofence update.
09-16 11:51:46.181 14854 14928 D ServerConnectionInfo: localUrl is: false, usesInternalSsid is: false, usesWifi is: true
09-16 11:51:46.188 14854 15209 D LocBroadcastReceiver: Last Location:
09-16 11:51:46.188 14854 15209 D LocBroadcastReceiver: Coords:(XX.1127127, XX1713105)
09-16 11:51:46.188 14854 15209 D LocBroadcastReceiver: Accuracy: 159.161
09-16 11:51:46.188 14854 15209 D LocBroadcastReceiver: Bearing: 183.25404
09-16 11:51:46.191 14854 15209 D LocBroadcastReceiver: Begin evaluating if location update should be skipped
09-16 11:51:46.191 14854 15209 D LocBroadcastReceiver: Received location that is 5286 milliseconds old, 1694857900905 compared to 1694857906191 with source fused
09-16 11:51:46.232 14854 14923 D ServerConnectionInfo: localUrl is: false, usesInternalSsid is: false, usesWifi is: true
09-16 11:51:46.240 14854 14925 D ServerConnectionInfo: localUrl is: false, usesInternalSsid is: false, usesWifi is: true
09-16 11:51:46.320 14854 14925 I SensorReceiver: Sensor updates and sync completed
09-16 11:51:46.340 14854 15209 I SensorReceiver: Sensor updates and sync completed
09-16 11:51:46.342 14854 14913 I WM-WorkerWrapper: Worker result SUCCESS for Work [ id=15b37d58-2368-4b83-8c9c-35a5e81218e6, tags={ io.homeassistant.companion.android.sensors.SensorWorker } ]
09-16 11:51:46.345 14854 14926 I SensorReceiver: Sensor updates and sync completed
09-16 11:51:46.362 14854 14854 I WM-SystemFgDispatcher: Stopping foreground service
09-16 11:51:46.392 14854 15209 D LocBroadcastReceiver: Event sent to Home Assistant
09-16 11:51:46.394 14854 14922 D LocBroadcastReceiver: Event sent to Home Assistant
09-16 11:51:46.635 14854 14923 D LocBroadcastReceiver: Location update sent successfully for 4 as exact
09-16 11:51:46.651 14854 14854 D LocBroadcastReceiver: Received location update.
09-16 11:51:46.655 14854 14854 D ForegrndServiceLauncher: Check if service HighAccuracyLocationService is running. Service running = false
09-16 11:51:46.662 14854 14923 D LocBroadcastReceiver: Last Location:
09-16 11:51:46.662 14854 14923 D LocBroadcastReceiver: Coords:(XX.1127127, XX1713105)
09-16 11:51:46.662 14854 14923 D LocBroadcastReceiver: Accuracy: 159.161
09-16 11:51:46.662 14854 14923 D LocBroadcastReceiver: Bearing: 183.25404
09-16 11:51:46.664 14854 14923 D LocBroadcastReceiver: Begin evaluating if location update should be skipped
09-16 11:51:46.664 14854 14923 D LocBroadcastReceiver: Skipping old location update since time is before the last one we sent, received: 1694857900905 last sent: {4=1694857906191}
09-16 11:51:48.254 14854 15614 D ProfileInstaller: Skipping profile installation for io.homeassistant.companion.android
09-16 11:51:48.814 14854 14854 D DecorView[]: onWindowFocusChanged hasWindowFocus false
09-16 11:51:50.627 14854 14867 I mpanion.android: Background concurrent copying GC freed 487434(19MB) AllocSpace objects, 46(1684KB) LOS objects, 49% free, 9194KB/17MB, paused 119us,61us total 131.042ms
09-16 11:51:54.937 14854 14854 D SensorReceiver: Received intent: android.net.wifi.STATE_CHANGE
09-16 11:51:54.940 14854 14926 D ServerConnectionInfo: localUrl is: false, usesInternalSsid is: false, usesWifi is: true
09-16 11:51:55.029 14854 14923 D ServerConnectionInfo: localUrl is: false, usesInternalSsid is: false, usesWifi is: true
09-16 11:51:55.031 14854 14929 I WM-WorkerWrapper: Worker result SUCCESS for Work [ id=c917eda2-cedc-4d7c-b38a-ba996667f8b4, tags={ io.homeassistant.companion.android.websocket.WebsocketManager } ]
09-16 11:51:55.203 14854 14926 D NextAlarm: Next alarm is scheduled by com.android.deskclock with trigger time 1695010800000
09-16 11:51:55.252 14854 14926 D ProximitySensor: Proximity sensor listener registered
09-16 11:51:55.280 14854 14926 D ServerConnectionInfo: localUrl is: false, usesInternalSsid is: false, usesWifi is: true
09-16 11:51:55.283 14854 14926 D ServerConnectionInfo: localUrl is: false, usesInternalSsid is: false, usesWifi is: true
09-16 11:51:55.852 14854 14854 D ProximitySensor: Proximity sensor listener unregistered
09-16 11:52:02.109 14854 14854 D ServerConnectionInfo: localUrl is: false, usesInternalSsid is: false, usesWifi is: false
09-16 11:52:02.111 14854 14854 D IntegrationRepository: isAppLocked(): false. (LockEnabled: false, appActive: false, expireMillis: 1694803686897, currentMillis: 1694857922111)
09-16 11:52:02.112 14854 14854 D DecorView[]: onWindowFocusChanged hasWindowFocus true
09-16 11:52:02.116 14854 14854 I HandWritingStubImpl: refreshLastKeyboardType: 1
09-16 11:52:02.116 14854 14854 I HandWritingStubImpl: getCurrentKeyboardType: 1
09-16 11:52:02.123 14854 14854 D ServerConnectionInfo: localUrl is: false, usesInternalSsid is: false, usesWifi is: false
09-16 11:52:02.123 14854 14854 D ServerConnectionInfo: Using external URL
09-16 11:52:02.125 14854 14854 D ServerConnectionInfo: localUrl is: false, usesInternalSsid is: false, usesWifi is: false
09-16 11:52:02.125 14854 14854 D ServerConnectionInfo: Using external URL
09-16 11:52:09.775 14854 14854 W MirrorManager: this model don't Support
09-16 11:52:09.856 14854 14854 I HandWritingStubImpl: refreshLastKeyboardType: 1
09-16 11:52:09.856 14854 14854 I HandWritingStubImpl: getCurrentKeyboardType: 1
09-16 11:52:11.325 14854 15288 D WebviewActivity: External bus {"type":"config_screen/show","id":4}
09-16 11:52:11.389 14854 14854 D IntegrationRepository: setAppActive(): false
09-16 11:52:11.394 14854 14854 D IntegrationRepository: setAppActive(): false
09-16 11:52:11.419 14854 14854 D MiuiMultiWindowAdapter: MiuiMultiWindowAdapter::getFreeformVideoWhiteListInSystem::LIST_ABOUT_SUPPORT_LANDSCAPE_VIDEO = [com.hunantv.imgo.activity, com.tencent.qqlive, com.qiyi.video, com.hunantv.imgo.activity.inter, com.tencent.qqlivei18n, com.iqiyi.i18n, tv.danmaku.bili]
09-16 11:52:11.442 14854 14854 D IS_CTS_MODE: false
09-16 11:52:11.442 14854 14854 D MULTI_WINDOW_ENABLED: false
09-16 11:52:11.443 14854 14854 D DecorView[]: getWindowModeFromSystem windowmode is 1
09-16 11:52:11.581 14854 14854 W Activity: PerfMonitor: Slow Operation: Activity io.homeassistant.companion.android/.settings.SettingsActivity onStart took 104ms
09-16 11:52:11.584 14854 14854 D IntegrationRepository: isAppLocked(): false. (LockEnabled: false, appActive: false, expireMillis: 1694803686897, currentMillis: 1694857931584)
09-16 11:52:11.590 14854 14854 D DecorView[]: getWindowModeFromSystem windowmode is 1
09-16 11:52:11.590 14854 14854 D DecorView[]: updateDecorCaptionStatus windowMode is 1
09-16 11:52:11.596 14854 14854 D SensorReceiver: Received intent: io.homeassistant.companion.android.UPDATE_SENSORS
09-16 11:52:11.600 14854 14926 D ServerConnectionInfo: localUrl is: false, usesInternalSsid is: false, usesWifi is: true
09-16 11:52:11.715 14854 14926 D NextAlarm: Next alarm is scheduled by com.android.deskclock with trigger time 1695010800000
09-16 11:52:11.759 14854 14926 D ProximitySensor: Proximity sensor listener registered
09-16 11:52:11.770 14854 14926 D ServerConnectionInfo: localUrl is: false, usesInternalSsid is: false, usesWifi is: true
09-16 11:52:11.773 14854 14926 D ServerConnectionInfo: localUrl is: false, usesInternalSsid is: false, usesWifi is: true
09-16 11:52:11.778 14854 14854 D VRI[SettingsActivity]: vri.reportNextDraw android.view.ViewRootImpl.performTraversals:3876 android.view.ViewRootImpl.doTraversal:2608 android.view.ViewRootImpl$TraversalRunnable.run:9617 android.view.Choreographer$CallbackRecord.run:1491 android.view.Choreographer$CallbackRecord.run:1499
09-16 11:52:11.778 14854 14854 D VRI[SettingsActivity]: vri.Setup new sync id=0 syncSeqId=0
09-16 11:52:11.817 14854 14934 E perf_hint: Session creation failed, mPreferredRateNanos: -1
09-16 11:52:11.820 14854 14854 D VRI[SettingsActivity]: vri.reportDrawFinished syncSeqId=0 android.view.ViewRootImpl.lambda$createSyncIfNeeded$4$android-view-ViewRootImpl:3944 android.view.ViewRootImpl$$ExternalSyntheticLambda1.run:6 android.os.Handler.handleCallback:942 android.os.Handler.dispatchMessage:99 android.os.Looper.loopOnce:211
09-16 11:52:11.824 14854 14926 D ServerConnectionInfo: localUrl is: false, usesInternalSsid is: false, usesWifi is: true
09-16 11:52:11.830 14854 14854 D DecorView[]: onWindowFocusChanged hasWindowFocus false
09-16 11:52:11.898 14854 14854 D SettingsWearDetection: API unavailable for discovering nodes (no Wear)
09-16 11:52:11.947 14854 14854 D IntegrationRepository: isAppLocked(): false. (LockEnabled: false, appActive: false, expireMillis: 1694803686897, currentMillis: 1694857931947)
09-16 11:52:11.947 14854 14854 D IntegrationRepository: setAppActive(): true
09-16 11:52:11.947 14854 14854 D DecorView[]: onWindowFocusChanged hasWindowFocus true
09-16 11:52:11.948 14854 14854 I HandWritingStubImpl: refreshLastKeyboardType: 1
09-16 11:52:11.948 14854 14854 I HandWritingStubImpl: getCurrentKeyboardType: 1
09-16 11:52:11.997 14854 15298 D TrafficStats: tagSocket(279) with statsTag=0xffffffff, statsUid=-1
09-16 11:52:12.325 14854 14854 D ProximitySensor: Proximity sensor listener unregistered
09-16 11:52:18.230 14854 14854 D SensorReceiver: Received intent: android.net.wifi.STATE_CHANGE
09-16 11:52:18.233 14854 14923 D ServerConnectionInfo: localUrl is: false, usesInternalSsid is: false, usesWifi is: true
09-16 11:52:18.310 14854 14926 D ServerConnectionInfo: localUrl is: false, usesInternalSsid is: false, usesWifi is: true
09-16 11:52:18.313 14854 15192 I WM-WorkerWrapper: Worker result SUCCESS for Work [ id=2512a12e-b292-47bf-babd-2956c178c1b0, tags={ io.homeassistant.companion.android.websocket.WebsocketManager } ]
09-16 11:52:18.393 14854 14923 D NextAlarm: Next alarm is scheduled by com.android.deskclock with trigger time 1695010800000
09-16 11:52:18.407 14854 14923 D ProximitySensor: Proximity sensor listener registered
09-16 11:52:18.415 14854 14922 D ServerConnectionInfo: localUrl is: false, usesInternalSsid is: false, usesWifi is: true
09-16 11:52:18.417 14854 14922 D ServerConnectionInfo: localUrl is: false, usesInternalSsid is: false, usesWifi is: true
09-16 11:52:18.940 14854 14854 D ProximitySensor: Proximity sensor listener unregistered
09-16 11:52:21.385 14854 14934 W RenderInspector: DequeueBuffer time out on io.homeassistant.companion.android/io.homeassistant.companion.android.settings.SettingsActivity, count=1, avg=12 ms, max=12 ms.
09-16 11:52:25.319 14854 14922 E SensorReceiver: Error while getting core config to sync sensor status
09-16 11:52:25.319 14854 14922 E SensorReceiver: io.homeassistant.companion.android.common.data.integration.IntegrationException: java.io.InterruptedIOException: timeout
09-16 11:52:25.319 14854 14922 E SensorReceiver: at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl.getConfig(IntegrationRepositoryImpl.kt:512)
09-16 11:52:25.319 14854 14922 E SensorReceiver: at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl$getConfig$1.invokeSuspend(Unknown Source:14)
09-16 11:52:25.319 14854 14922 E SensorReceiver: at kotlin.coroutines.jvm.internal.BaseContinuationImpl.resumeWith(ContinuationImpl.kt:33)
09-16 11:52:25.319 14854 14922 E SensorReceiver: at kotlinx.coroutines.DispatchedTask.run(DispatchedTask.kt:106)
09-16 11:52:25.319 14854 14922 E SensorReceiver: at kotlinx.coroutines.internal.LimitedDispatcher$Worker.run(LimitedDispatcher.kt:115)
09-16 11:52:25.319 14854 14922 E SensorReceiver: at kotlinx.coroutines.scheduling.TaskImpl.run(Tasks.kt:103)
09-16 11:52:25.319 14854 14922 E SensorReceiver: at kotlinx.coroutines.scheduling.CoroutineScheduler.runSafely(CoroutineScheduler.kt:584)
09-16 11:52:25.319 14854 14922 E SensorReceiver: at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.executeTask(CoroutineScheduler.kt:793)
09-16 11:52:25.319 14854 14922 E SensorReceiver: at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.runWorker(CoroutineScheduler.kt:697)
09-16 11:52:25.319 14854 14922 E SensorReceiver: at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.run(CoroutineScheduler.kt:684)
09-16 11:52:25.319 14854 14922 E SensorReceiver: Caused by: java.io.InterruptedIOException: timeout
09-16 11:52:25.319 14854 14922 E SensorReceiver: at okhttp3.internal.connection.RealCall.timeoutExit(RealCall.kt:398)
09-16 11:52:25.319 14854 14922 E SensorReceiver: at okhttp3.internal.connection.RealCall.callDone(RealCall.kt:360)
09-16 11:52:25.319 14854 14922 E SensorReceiver: at okhttp3.internal.connection.RealCall.noMoreExchanges$okhttp(RealCall.kt:325)
09-16 11:52:25.319 14854 14922 E SensorReceiver: at okhttp3.internal.connection.RealCall.getResponseWithInterceptorChain$okhttp(RealCall.kt:209)
09-16 11:52:25.319 14854 14922 E SensorReceiver: at okhttp3.internal.connection.RealCall$AsyncCall.run(RealCall.kt:517)
09-16 11:52:25.319 14854 14922 E SensorReceiver: at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1137)
09-16 11:52:25.319 14854 14922 E SensorReceiver: at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:637)
09-16 11:52:25.319 14854 14922 E SensorReceiver: at java.lang.Thread.run(Thread.java:1012)
09-16 11:52:25.319 14854 14922 E SensorReceiver: Caused by: java.io.IOException: Canceled
09-16 11:52:25.319 14854 14922 E SensorReceiver: at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(RetryAndFollowUpInterceptor.kt:72)
09-16 11:52:25.319 14854 14922 E SensorReceiver: at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.kt:109)
09-16 11:52:25.319 14854 14922 E SensorReceiver: at okhttp3.internal.connection.RealCall.getResponseWithInterceptorChain$okhttp(RealCall.kt:201)
09-16 11:52:25.319 14854 14922 E SensorReceiver: ... 4 more
09-16 11:52:25.439 14854 14922 D ServerConnectionInfo: localUrl is: false, usesInternalSsid is: false, usesWifi is: true
09-16 11:52:25.491 14854 14854 D SensorReceiver: Received intent: android.bluetooth.device.action.ACL_DISCONNECTED
09-16 11:52:25.494 14854 14854 D SensorReceiver: Sensor bluetooth_connection corresponding to received event android.bluetooth.device.action.ACL_DISCONNECTED is disabled, skipping sensors update
09-16 11:52:25.557 14854 14922 D ServerConnectionInfo: localUrl is: false, usesInternalSsid is: false, usesWifi is: true
09-16 11:52:25.558 14854 14929 I WM-WorkerWrapper: Worker result SUCCESS for Work [ id=36214674-15ce-4369-9578-a2b73738abce, tags={ io.homeassistant.companion.android.websocket.WebsocketManager } ]
09-16 11:52:26.132 14854 14926 D LogcatReader: Read logcat for pid 14854
My logg was to big to post
What I can see now is that she only has a log from 11:51-11:52 while mine has a log from 11:20 to 11:52
