After updating to 0.86.x and using the URL on the integration page (with external IP instead of internal) Locative does not Work anymore. Nothing happens when sending a test request. Anyone have the same experience?
I had locative working before the update so the only thing i have done is to replace the existing url with the new one and in configuration.yaml replaced
Ok, found that after 0.86 it should be configured via integrations:
To configure Locative, you must set it up via the integrations panel in the configuration screen. You must set up the app to send a POST request to your Home Assistant server at the webhook URL provided by the integration during setup. When you enter or exit a geofence, Locative will send the appropriate request to that URL, updating Home Assistant.
I have tried to configure it as described in the documents via integrations (several times), but it still does not Work. Instead it now Works with geofency.
What did you do exactly?
I never had something in my configuration. Directly add the locative web hook in integration. Got the http link and put this in locative. At settings page you can add this as well and send a test request.
