Here is what I’m getting in home_assistant.log - just the last parts of it as this pattern repeats A LOT and then finally ends with the event loop close statement. The funny thing is is that I can get to the configurator UI if I type in that URL but the actual HA UI and and obviously any HA actions/functions do not work.
Anyone else have any ideas?
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 292, in _async_add_entity
await entity.async_device_update(warning=False)
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 425, in async_device_update
await self.parallel_updates.acquire()
File "/usr/local/lib/python3.7/asyncio/locks.py", line 474, in acquire
await fut
concurrent.futures._base.CancelledError
2019-10-23 13:13:30 ERROR (MainThread) [homeassistant.components.camera] Error while setting up platform mjpeg
File "/usr/local/lib/python3.7/asyncio/runners.py", line 43, in run
return loop.run_until_complete(main)
File "/usr/local/lib/python3.7/asyncio/base_events.py", line 579, in run_until_complete
return future.result()
File "/usr/src/homeassistant/homeassistant/setup.py", line 52, in async_setup_component
return await task # type: ignore
File "/usr/src/homeassistant/homeassistant/setup.py", line 131, in _async_setup_component
await async_process_deps_reqs(hass, config, integration)
File "/usr/src/homeassistant/homeassistant/setup.py", line 282, in async_process_deps_reqs
hass, config, integration.domain, integration.dependencies
File "/usr/src/homeassistant/homeassistant/setup.py", line 75, in _async_process_dependencies
results = await asyncio.gather(*tasks)
File "/usr/src/homeassistant/homeassistant/__main__.py", line 304, in setup_and_run_hass
log_no_color=args.log_no_color,
File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 150, in async_from_config_file
config_dict, hass, enable_log=False, skip_pip=skip_pip
File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 95, in async_from_config_dict
await _async_set_up_integrations(hass, config)
File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 376, in _async_set_up_integrations
*(async_setup_component(hass, domain, config) for domain in domains_to_load)
File "/usr/src/homeassistant/homeassistant/setup.py", line 46, in async_setup_component
return await setup_tasks[domain] # type: ignore
File "/usr/src/homeassistant/homeassistant/setup.py", line 137, in _async_setup_component
File "/usr/src/homeassistant/homeassistant/config.py", line 738, in async_process_component_config
p_validated = component_platform_schema(p_config)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 272, in __call__
return self._compiled([], data)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 594, in validate_dict
return base_validate(path, iteritems(data), out)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 386, in validate_mapping
cval = cvalue(key_path, value)
File "/usr/local/lib/python3.7/site-packages/voluptuous/validators.py", line 205, in _run
return self._exec(self._compiled, value, path)
File "/usr/local/lib/python3.7/site-packages/voluptuous/validators.py", line 285, in _exec
v = func(path, v)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 635, in validate_sequence
cval = validate(index_path, value)
File "/usr/local/lib/python3.7/site-packages/voluptuous/validators.py", line 250, in _exec
return func(path, v)
v = func(path, v)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 817, in validate_callable
return schema(data)
return schema(data)
File "/usr/src/homeassistant/homeassistant/helpers/config_validation.py", line 385, in service
if valid_entity_id(value):
File "/usr/src/homeassistant/homeassistant/core.py", line 120, in valid_entity_id
return "." in entity_id and slugify(entity_id) == entity_id.replace(".", "_", 1)
TypeError: argument of type 'NoneType' is not iterable
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 150, in _async_setup_platform
await asyncio.wait_for(asyncio.shield(task), SLOW_SETUP_MAX_WAIT)
File "/usr/local/lib/python3.7/asyncio/tasks.py", line 435, in wait_for
await waiter
2019-10-23 13:13:39 ERROR (SyncWorker_6) [concurrent.futures] exception calling callback for <Future at 0x7fda8d7d4950 state=finished raised APIConnectionError>
File "/usr/local/lib/python3.7/site-packages/aioesphomeapi/host_resolver.py", line 72, in resolve_host
raise APIConnectionError("Error resolving address with mDNS: Did not respond. "
aioesphomeapi.core.APIConnectionError: Error resolving address with mDNS: Did not respond. Maybe the device is offline.
File "/usr/local/lib/python3.7/concurrent/futures/_base.py", line 324, in _invoke_callbacks
callback(self)
File "/usr/local/lib/python3.7/asyncio/futures.py", line 362, in _call_set_state
dest_loop.call_soon_threadsafe(_set_state, destination, source)
File "/usr/local/lib/python3.7/asyncio/base_events.py", line 728, in call_soon_threadsafe
self._check_closed()
File "/usr/local/lib/python3.7/asyncio/base_events.py", line 475, in _check_closed
raise RuntimeError('Event loop is closed')
RuntimeError: Event loop is closed
