winter
July 26, 2017, 10:56pm
1
At the moment, my mqtt lock shows up as a slider control:
I find this visualisation a little confusing (I get the switch on, means its locked, but I don’t like how it shares the same template as a switch), was wondering if there had been any thought to change this to something that included a locked and unlocked padlock icon.
Maybe like so:
Looks like a bug in the mqtt lock, wink locks show a lock/unlocked icon.
Sorry for the poor color, have flux on my phone.
luma
July 27, 2017, 2:50am
3
As mentioned, standard lock device integrations via ZWave etc will set the icon on the left to a locked or unlocked state. You can accomplish the same thing with an MQTT device using icon_template. If you can post the relevant parts from your configuration.yaml maybe we can put something together that’ll work for you.
edit: after further research it looks like the lock component doesn’t appear to support icon_template. No idea why it’s not switching the icon for you unfortunately.
winter
July 27, 2017, 3:32am
4
Hi Luma,
I just checked and the icon to the left is switching, its just so subtle that I never even noticed. I always thought those icons where just static.
I would prefer a more obvious lock/unlock icons associated with the slider itself.
syphernl
(Frank)
July 27, 2017, 6:44am
5
Perhaps Custom UI can help you here so you can customize the card to suit your needs
winter
July 27, 2017, 9:21pm
6
I’ll look into this, thanks @syphernl . This thread was more to understand whether a change to the default template could be beneficial to everyone.
Looking at the screenshot by @w1ll1am23 above, I can see that the power card doesn’t use the switch widget. I feel like this is more like a switch that a door lock.
Adding 2 more locks - looks ugly.
If it is hard to read the state from default visual - it’s quite easy to add a template sensor beneath which will state in text “locked” “unlocked” or show any icon necessary
I’ve implemented Custom UI and the approach described here with a custom state-card-custom_lock.html
file:
<dom-module id="state-card-custom_lock">
<template>
<style is="custom-style" include="iron-flex iron-flex-alignment"></style>
<style>
:host {
line-height: 1.5;
paper-button {
min-width: 30px;
height: 30px;
margin: 5px 0px;
padding: 5px 0px;
font-size: 12px;
.info {
font-family: var(--paper-font-body1_-_font-family); -webkit-font-smoothing: var(--paper-font-body1_-_-webkit-font-smoothing); font-size: var(--paper-font-body1_-_font-size); font-weight: var(--paper-font-body1_-_font-weight); line-height: var(--paper-font-body1_-_line-height);min-width:10px;white-space:nowrap;float:left
.info {
margin-left:16px
.name {
white-space: var(--paper-font-common-nowrap_-_white-space); overflow: var(--paper-font-common-nowrap_-_overflow); text-overflow: var(--paper-font-common-nowrap_-_text-overflow);color:var(--primary-text-color);line-height:40px
.name[in-dialog],:host([secondary-line]) .name {
line-height:20px
.time-ago,::content> * {
white-space: var(--paper-font-common-nowrap_-_white-space); overflow: var(--paper-font-common-nowrap_-_overflow); text-overflow: var(--paper-font-common-nowrap_-_text-overflow);color:var(--secondary-text-color);
.badge {
position:relative;display:inline-block;width:40px;color:var(--status-color);border-radius:50%;height:40px;text-align:center;background-size:cover;line-height:40px
</style>
<div class='horizontal justified layout'>
<div class='horizontal start-justified layout'>
<div class="badge">
<state-badge class="badge" state-obj="[[stateObj]]"></state-badge>
</div>
<div class="info">
<div class="name" in-dialog>[[friendlyName]]</div>
<div class="time-ago">
<ha-relative-time datetime='[[stateObj.last_changed]]'></ha-relative-time>
</div>
</div>
</div>
<paper-button-group>
<paper-button
style="width:85px; background-color:#FFFFFF; color: #44739e; border: 1px solid #44739e;"
on-tap='handleLockedTap'
hidden$='[[!lockedButtonVisible]]'>Locked</paper-button>
<paper-button
style="width:85px; background-color:#FFFFFF; color: #F44336; border: 1px solid #F44336;"
on-tap='handleUnlockedTap'
hidden$='[[!unlockedButtonVisible]]'>Unlocked</paper-button>
</paper-button-group>
</div>
</template>
</dom-module>
<script>
Polymer({
is: 'state-card-custom_lock',
properties: {
hass: {
type: Object,
stateObj: {
type: Object,
observer: 'stateObjChanged',
lockedButtonVisible: {
type: Boolean,
value: false,
unlockedButtonVisible: {
type: Boolean,
value: false,
friendlyName: {
type: String,
value: 'unknown',
stateObjChanged: function (newVal) {
if (newVal) {
if (newVal.state == 'locked') {
this.lockedButtonVisible = true;
this.unlockedButtonVisible = false;
this.friendlyName = this.stateObj.attributes.friendly_name;
this.updateStyles({'--status-color': '#44739e'});
} else if (newVal.state == 'unlocked') {
this.lockedButtonVisible = false;
this.unlockedButtonVisible = true;
this.timeAgo = this.stateObj.last_changed;
this.updateStyles({'--status-color': '#F44336'});
handleLockedTap: function (ev) {
var serviceData = {entity_id: this.stateObj.entity_id}
this.hass.callService('lock', 'unlock', serviceData);
this.stopProp(ev);
handleUnlockedTap: function (ev) {
this.hass.callService('lock', 'lock', serviceData);
this.stopProp(ev);
stopProp(ev) {
ev.stopPropagation();
</script>
For an end result:
You could modify this file to whatever color/text/etc suits your preferences.
winter
July 28, 2017, 11:53pm
10
This is awesome, way more obvious than the current rendering
