Lock status incorrect in android 13 device control panel
Interesting issue (I’m assuming is) with the Android app.
I am on a
  • Pixel 6 pro
  • Running Android 13
  • App version: 2023.9.2-full
  • HassOS: 10.5
  • HassIO: 9.2
When attempting to control my smart lock from the Device control panel the state is… Correctly inverted?
In other words, it says “locked” but shows unlocked and when pressed sends the lock command to the lock. And vise versa.
Says “unlocked”, shows locked, sends unlock command on press.
Making it very confusing to read and impossible to use.
Anyone else experiencing this with the new update?
Image for reference:
Some more things to clarify:
I have removed and re-added the device (lock), restarted my device (phone), the lock, the zwave-js plugin, the supervisor, and the OS and still get the same result.
I am not completely sure when this started as I only use this to unlock the door maybe once every week or so. However I do know I wasn’t having this problem pre 9.0
The correct state is displayed in home assistant, and the correct command is sent when toggling inside home assistant.
I looked around reddit, the docs and the forum and couldn’t find a similar post however I am on mobile right now so I may have missed something.
I am mainly curious if anyone else has experienced this or something similar, to possibly bring attention to it if there is a bug.
I will try some more troubleshooting Monday such as trying earlier app versions, and restoring an older version of home assistant.
This will be fixed in the next update
On mine, the lock entity is completely not responding, shows correct status but wouldnt send any commands. Same phone/ android version/ HASS core. From the app, the locks work but not from the device control panel
Fixed in the beta
Yep it works now.
