I’m trying to write and automation to lock my front door at sunset but I can’t get the code right. I’m having trouble understanding how to call the service to lock.
The entity_id of the lock is “front_door_lock_locked” according to the entity list. My automation looks like this:
- alias: UnlockFrontDoorWhenHomeZone
platform: zone
entity_id: front_door_lock_locked
zone: zone.home
# Event is either enter or leave
event: enter
service: lock.unlock
Something isn’t right as the log is complaining about invalid entity IDs.
Does anyone have an example of what I’m trying to do?
Thanks!
Your action should be:
service: lock.lock
entity_id: <the entity id of your lock>
Ok, so I had the entiity_id in the wrong place. Reloaded automations with the change and so far no errors. We’ll see if it works.
Thanks for the quick response!
I find it hard to keep up with the inconsistencies in the syntax for different parts of HASS. For instance in a zone automation the enitity_id you’re acting on is up under the trigger section. But for a sun automation like above it goes down in the service: section. Confusing!
Example of platform zone:
- alias: NotifyWhenHomeZone
platform: zone
entity_id: device_tracker.iphone
zone: zone.home
event: enter
service: notify.ios_iPhone
title: "Lucy I'm Home!!"
message: "I'll be surprised if this works!"
vs platform sun
- alias: LockFrontDoorAtSunset
platform: sun
event: sunset
service: lock.lock
entity_id: group.all_locks
I assume that the entity_id in the first example is the entity which triggers the automation, while the service ios_iPhone contains the entity that should be notified. In the second example, the entity_id refers to which entity to take action upon. In that sense, HA is consistent, it just uses entity IDs everywhere ![:slight_smile: :slight_smile:](https://community.home-assistant.io/images/emoji/twitter/slight_smile.png?v=9)
