costinr
(Costin)
1
I’ve tried to use this addon:
with cloudflare certificates.
I’ve used DuckDNS addon before it, I’ve stopped DuckDNS addon and I’ve made some configurations I thought are ok.
After restart I’m not able to connect, even via localip:8123.
I’m able to ping the local IP and also I have CLI access.
I’ve removed from CLI the addon (core_nginx_proxy is the name).
Still, after restart, I’m not able to connect via http://localIP:8123, but I have access from CLI and I have access to files via Samba.
Please help
costinr
(Costin)
2
Solved by using CLI backups restore
Fortunately I had a recent full backup, still, there must be a way to restore local access after removing the guilty addon.
If you moved from one external service to another, then http on a local IP might not work.
You have to use httpS, then click through the browser warnings to be redirected properly to the insecure http site.
costinr
(Costin)
4
Unfortunately no, it wasn’t http/https issue, the connection was “refused”, like a port change.
