I have a NodeMCU with an ESPHome program monitoring push buttons. One of the buttons is activated when the lock is operated. This comes through Home Assistant fine (ESPHome program has the device_class set to ‘lock’) and shows in the entity as locked/unlocked (complete with the padlock icon). However, I have to ask Google Assistant “is the workshop door closed”. “Is the workshop door locked?” gives me the generic “Sorry, I can’t help you with that”.
Is this something I can change within the settings?
hello
i have a sonoff for lock a door
in my configuration.yaml i did:
lock:
value_template: "{{ is_state('switch.sonoff', 'on') }}"
lock:
service: switch.turn_on
entity_id: switch.sonoff
unlock:
service: switch.turn_off
google_assistant:
project_id: home-ass-xxxxxx
service_account: !include 'Home Ass-cxxxxxxx.json'
exposed_domains:
- lock
and google respond me as you wish.
hope it can help you
Tom,
Thank you for that, however that appears you have a sonoff as a door lock. I want to read the status of a switch (that comes through ESPHome) that in Home Assistant shows as a lock (locked/unlocked) but appears in Google Assistant as a door (open/closed). How could your code be modified to give Google the correct info?
I must note that Google Assistant is connected via Nabu Casa.
The icon in HA does not matter. To have a “lock/unlock” status in GA, the entity should actually be a lock.
Bottom-line: do as tomdudu38 suggested, and ask “Is the thefuckingdoor door locked?” (you can “rename” entities in the google_assistant:configuration, though
maybe it should look like this:
lock:
value_template: "{{ states('sensor.thedoorfromesp') }}"
lock:
entity_id: switch.thedoorfromesp
unlock:
google_assistant:
blablabla.....
Sorry for the late response - didn’t get any time to look at it!
Does this require the manual Google Assistant?
no, but
you will create a new door named " thedummyfuckingdoor" in my code.
and you will have your door from esp.
that mean two doors.
with manual config of google you can show the door you want or not.
And it’s better to configure your projet id and servcie account to synchronize all devices
I’ve added the template code as follows:
lock:
value_template: "{{ states('binary_sensor.lock') }}"
lock:
entity_id: binary_sensor.lock
unlock:
and exposed the entity to Google assistant. However, the exposed entity stays in an unlocked state. I reversed the on/off statements in the template, saved and rebooted but it remains the same. I’ll have another go at it tomorrow after sleep!
try :
optimistic: true
Hi guys, I have a tiny problem, and I am not sure if it even can be solved. I have a electrolock controlled with switch device, and also a reed switch so I know the actual state of the door.
I would like the google to differentiate between door locked/unlocked and closed/opened - as door can be unlocked but still closed for example.
Right now my config is:
# Cover.door giving me door status from reed switch - open/closed
cover:
covers:
front_door:
friendly_name: "Front door"
device_class: door
unique_id: "front_door"
open_cover:
close_cover:
value_template: "{{is_state('binary_sensor.front_door', 'on')}}"
# Actual lock locking and unlocking the door
lock:
unique_id: lock_front_door
value_template: "{{ is_state('switch.1000d8feca', 'off') }}"
lock:
- condition: state
entity_id: switch.1000d8feca
state: "on"
- service: switch.turn_off
unlock:
- condition: state
state: "off"
- service: switch.turn_on
# Google export
google_assistant:
secure_devices_pin: ";)"
project_id: ha-integration-e356
service_account: !include /ssl/ha-integration-e356-1a536463645dd.json
report_state: true
expose_by_default: false
entity_config:
cover.front_door:
lock.front_door:
Query if the front door is open - google responds that it’s locked/unlocked but not considering the sensor (If I command to unlock, it attempts unlocking using empty action and then claims it’s unlocked permanently(. It’s also unable to actually unlock it using the lock.
If I rename the lock for example - then locking and unlocking the lock works, and same with real status of the door (opened and closed) from the reed switch sensor, google is then suddenly aware of that.
Can you advise how (and if ) I can combine such setup, reed switch with lock to have the door lockable/unlockable and open/closed? (i.e. unlocked but still closed - make google notice these are different states)
I can workaround it by renaming the lock - then
