I have an automation inside of a package:
automation:
- id: '1583509362752'
alias: 'Notify: Miki error'
description: Telegram notification when Miki encounters an error
- entity_id: vacuum.miki
platform: state
to: 'Error'
- data:
message: '*Achtung:* Miki steckt!'
service: notify.telegram
- data_template:
message: {{ states.vacuum.miki }}
service: system_log.write
Since I get to much notifications I would also like to log the complete entity. However even when the expression {{ states.vacuum.miki }}
works inside of “Developer tools - Template”, it does not work inside the package. Instead I get the error:
2020-07-18 16:41:21 ERROR (MainThread) [homeassistant.bootstrap] Failed to parse configuration.yaml: invalid key: "OrderedDict([('states.vacuum.miki', None)])"
in "/config/packages/automower.yaml", line 32, column 0. Activating safe mode
Can someone explain why? How would I log the entity?
Kind regards, Christian
