I tried upgrading to the newest version of HA but my location tracker with Life360 broke. So, I decided to wipe and restore with my most recent backup. It seems to have gone well, however, now none of my logbook entries are showing up. I have no idea how to fix this, any ideas?
I’ve seen some say you can wipe your logbook entries. Do I just go and delete the file called home-assistant.log? Will that resolve this?
No! This is the log of HA and has nothing to do with the history.
Lookup the log for database errors.
If you use the default sqlite db, delete the home-assistant_v2.db
in your config directory and restart HA.
You will loose your history, but i think it’s broken anyway.
Thanks, I did that and it corrected the problem. It’s also much faster now. I guess I should limit the size of it going forward.
