Hi to all,
I’m running the latest Home Assistant in a VM on a Proxmox server (i5 6400, 16gb RAM) and it was running quite fine until latest update.
After upgrading from 2023.4.6 to 2023.5.2 I started getting this error in the logs:
Logger: aiohttp.server
Source: /usr/local/lib/python3.10/site-packages/aiohttp/web_protocol.py:403
First occurred: 09:02:50 (5199 occurrences)
Last logged: 09:28:29
Error handling request
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_protocol.py", line 332, in data_received
messages, upgraded, tail = self._request_parser.feed_data(data)
File "aiohttp/_http_parser.pyx", line 551, in aiohttp._http_parser.HttpParser.feed_data
aiohttp.http_exceptions.BadStatusLine: 400, message="Bad status line 'Expected CRLF after version'"
At the moment eveything seems to be working fine but the number of occurrences of the error keeps increasing significantly every time I check the logs.
Is anyone else having the same problem?
Any idea what could be the cause?
Thank you in advance
Federico
