Log Error - Error while passing template
Hi everyone
I have the following error in my log. How can I fix this?
It talks about the use of the an unexpected curly brace. I can’t see where this is.
Please help.
Logger: homeassistant.helpers.event
Source: helpers/template.py:514
First occurred: 12:17:49 (55 occurrences)
Last logged: 12:24:40
Error while processing template: Template<template=({%- if has_value('sensor.bicester_village_station_buses') -%} {%- if (state_attr('sensor.bicester_village_station_buses', 'calls') | count) == 0 %} Information is not available {%- else %} <table style="text-align: left"> <tr> <th style="width: 5%">Bus</th><th>Destination</th><th>Expected</th> </tr> {%- for call in state_attr('sensor.bicester_village_station_buses', 'calls') %} <tr> <td>{{ call.service_description }}</td> <td style="max-width: 10px; white-space: nowrap; overflow: hidden; text-overflow: ellipsis">{{ call.destination }}</td> <td style="width: 20%; white-space: nowrap"> {%- if call.display_time[2] != ":" %} {{ call.expected_departure_time[11:16] }} {{ '(' }} {%- endif -%} {{ call.display_time }} {%- if call.display_time[2] != ":" %} {{- ')' }} {%- endif %} </td> </tr> {%- endfor %} </table> {% if state_attr('sensor.bicester_village_station_buses', 'messages') is not none %} <br /> {% for message in state_attr('sensor.bicester_village_station_buses', 'messages') %} <marquee behavior="scroll" direction="left">{{ message }}</marquee> {%- endfor %} {% endif %} {% endif %} {%- endi -%}) renders=2>
Error while processing template: Template<template=({%- if has_value('sensor.bicester_village_station_buses') -%} {%- if (state_attr('sensor.bicester_village_station_buses', 'calls') | count) == 0 %} Information is not available {%- else %} <table style="text-align: left"> <tr> <th style="width: 5%">Bus</th><th>Destination</th><th>Expected</th> </tr> {%- for call in state_attr('sensor.bicester_village_station_buses', 'calls') %} <tr> <td>{{ call.service_description }}</td> <td style="max-width: 10px; white-space: nowrap; overflow: hidden; text-overflow: ellipsis">{{ call.destination }}</td> <td style="width: 20%; white-space: nowrap"> {%- if call.display_time[2] != ":" %} {{ call.expected_departure_time[11:16] }} {{ '(' }} {%- endif -%} {{ call.display_time }} {%- if call.display_time[2] != ":" %} {{- ')' }} {%- endif %} </td> </tr> {%- endfor %} </table> {% if state_attr('sensor.bicester_village_station_buses', 'messages') is not none %} <br /> {% for message in state_attr('sensor.bicester_village_station_buses', 'messages') %} <marquee behavior="scroll" direction="left">{{ message }}</marquee> {%- endfor %} {% endif %} {% endif %}) renders=6>
Error while processing template: Template<template=({%- if has_value('sensor.bicester_village_station_buses') -%} {%- if (state_attr('sensor.bicester_village_station_buses', 'calls') | count) == 0 %} Information is not available {%- else %} <table style="text-align: left"> <tr> <th style="width: 5%">Bus</th><th>Destination</th><th>Expected</th> </tr> {%- for call in state_attr('sensor.bicester_village_station_buses', 'calls') %} <tr> <td>{{ call.service_description }}</td> <td style="max-width: 10px; white-space: nowrap; overflow: hidden; text-overflow: ellipsis">{{ call.destination }}</td> <td style="width: 20%; white-space: nowrap"> {%- if call.display_time[2] != ":" %} {{ call.expected_departure_time[11:16] }} {{ '(' }} {%- endif -%} {{ call.display_time }} {%- if call.display_time[2] != ":" %} {{- ')' }} {%- endif %} </td> </tr> {%- endfor %} </table> {% if state_attr('sensor.bicester_village_station_buses', 'messages') is not none %} <br /> {% for message in state_attr('sensor.bicester_village_station_buses', 'messages') %} <marquee behavior="scroll" direction="left">{{ message }}</marquee> {%- endfor %} {% endif %} {% endif %}) renders=10>
Error while processing template: Template<template=({%- if (state_attr('sensor.manorsfield_road_stand_2_buses', 'calls') | count) == 0 %} Information is not available {%- else %} <table style="text-align: left"> <tr> <th style="width: 5%">Bus</th><th>Destination</th><th>Expected</th> </tr> {%- for call in state_attr('sensor.manorsfield_road_stand_2_buses', 'calls') %} <tr> <td>{{ call.service_description }}</td> <td style="max-width: 10px; white-space: nowrap; overflow: hidden; text-overflow: ellipsis">{{ call.destination }}</td> <td style="width: 20%; white-space: nowrap"> {%- if call.display_time[2] != ":" %} {{ call.expected_departure_time[11:16] }} {{ '(' }} {%- endif -%} {{ call.display_time }} {%- if call.display_time[2] != ":" %} {{- ')' }} {%- endif %} </td> </tr> {%- endfor %} </table> {% if state_attr('sensor.manorsfield_road_stand_2_buses', 'messages') is not none %} <br /> {% for message in state_attr('sensor.manorsfield_road_stand_2_buses', 'messages') %} <marquee behavior="scroll" direction="left">{{ message }}</marquee> {%- endfor %} {% endif %} {% endif %} {%- endif -%}) renders=2>
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 512, in ensure_valid
    self._compiled_code = self._env.compile(self.template)
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 2607, in compile
    cached = self.template_cache[source] = super().compile(source)
  File "/usr/local/lib/python3.11/site-packages/jinja2/environment.py", line 768, in compile
    self.handle_exception(source=source_hint)
  File "/usr/local/lib/python3.11/site-packages/jinja2/environment.py", line 936, in handle_exception
    raise rewrite_traceback_stack(source=source)
  File "<unknown>", line 1, in template
jinja2.exceptions.TemplateSyntaxError: unexpected '}'
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 694, in async_render_to_info
    render_info._result = self.async_render(
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 562, in async_render
    compiled = self._compiled or self._ensure_compiled(limited, strict, log_fn)
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 765, in _ensure_compiled
    self.ensure_valid()
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 514, in ensure_valid
    raise TemplateError(err) from err
homeassistant.exceptions.TemplateError: TemplateSyntaxError: unexpected '}'
  1. line, last {% endif%} is missing an ‘f’.
Hi @pedolsky
Thanks for your help. The funny thing is that the {%- endi -%} was only put in to see if I could cure another log error. Can you help with this one:
Source: helpers/template.py:570
First occurred: 12:17:49 (106 occurrences)
Last logged: 12:17:49
Error while processing template: Template<template=({%- if (state_attr('sensor.bicester_village_station_buses', 'calls') | count) == 0 %} Information is not available {%- else %} <table style="text-align: left"> <tr> <th style="width: 5%">Bus</th><th>Destination</th><th>Expected</th> </tr> {%- for call in state_attr('sensor.bicester_village_station_buses', 'calls') %} <tr> <td>{{ call.service_description }}</td> <td style="max-width: 10px; white-space: nowrap; overflow: hidden; text-overflow: ellipsis">{{ call.destination }}</td> <td style="width: 20%; white-space: nowrap"> {%- if call.display_time[2] != ":" %} {{ call.expected_departure_time[11:16] }} {{ '(' }} {%- endif -%} {{ call.display_time }} {%- if call.display_time[2] != ":" %} {{- ')' }} {%- endif %} </td> </tr> {%- endfor %} </table> {% if state_attr('sensor.bicester_village_station_buses', 'messages') is not none %} <br /> {% for message in state_attr('sensor.bicester_village_station_buses', 'messages') %} <marquee behavior="scroll" direction="left">{{ message }}</marquee> {%- endfor %} {% endif %} {% endif %}) renders=112>
Error while processing template: Template<template=({%- if (state_attr('sensor.bicester_village_station_concourse_buses', 'calls') | count) == 0 %} Information is not available {%- else %} <table style="text-align: left"> <tr> <th style="width: 5%">Bus</th><th style="overflow: hidden; text-overflow: ellipsis">Destination</th><th>Expected</th> </tr> {%- for call in state_attr('sensor.bicester_village_station_concourse_buses', 'calls') %} <tr> <td>{{ call.service_description }}</td> <td style="max-width: 10px; white-space: nowrap; overflow: hidden; text-overflow: ellipsis">{{ call.destination }}</td> <td style="width: 20%; white-space: nowrap"> {%- if call.display_time[2] != ":" %} {{ call.expected_departure_time[11:16] }} {{ '(' }} {%- endif -%} {{ call.display_time }} {%- if call.display_time[2] != ":" %} {{- ')' }} {%- endif %} </td> </tr> {%- endfor %} </table> {% if state_attr('sensor.bicester_village_station_concourse_buses', 'messages') is not none %} <br /> {% for message in state_attr('sensor.bicester_village_station_concourse_buses', 'messages') %} <marquee behavior="scroll" direction="left">{{ message }}</marquee> {%- endfor %} {% endif %} {% endif %}) renders=28>
Error while processing template: Template<template=({%- if (state_attr('sensor.manorsfield_road_stand_2_buses', 'calls') | count) == 0 %} Information is not available {%- else %} <table style="text-align: left"> <tr> <th style="width: 5%">Bus</th><th>Destination</th><th>Expected</th> </tr> {%- for call in state_attr('sensor.manorsfield_road_stand_2_buses', 'calls') %} <tr> <td>{{ call.service_description }}</td> <td style="max-width: 10px; white-space: nowrap; overflow: hidden; text-overflow: ellipsis">{{ call.destination }}</td> <td style="width: 20%; white-space: nowrap"> {%- if call.display_time[2] != ":" %} {{ call.expected_departure_time[11:16] }} {{ '(' }} {%- endif -%} {{ call.display_time }} {%- if call.display_time[2] != ":" %} {{- ')' }} {%- endif %} </td> </tr> {%- endfor %} </table> {% if state_attr('sensor.manorsfield_road_stand_2_buses', 'messages') is not none %} <br /> {% for message in state_attr('sensor.manorsfield_road_stand_2_buses', 'messages') %} <marquee behavior="scroll" direction="left">{{ message }}</marquee> {%- endfor %} {% endif %} {% endif %}) renders=44>
Error while processing template: Template<template=(<table style="text-align:left"> <tr><th style="width:65%">Destination</th><th style="width:20%">Expected</th><th style="width:20%">Platform</th></tr> {% for train in state_attr('sensor.train_schedule_bit_oxf','trains') %} <tr><td style="width:60%">{{ train.terminus }}</td> <td style="width:20%">{{ (train.expected | string)[11:16] }}</td> <td style="width:20%">{% if train.platform is not none %} {{ train.platform }} {% endif %} </td></tr> {%- endfor %} </table><br /> <table style="text-align:left"> <tr><th style="width:65%">Destination</th><th style="width:20%">Expected</th><th style="width:20%">Platform</th></tr> {% for train in state_attr('sensor.train_schedule_bit_myb','trains') %} <tr><td style="width:60%">{{ train.terminus }}</td> <td style="width:20%">{{ (train.expected | string)[11:16] }}</td> <td style="width:20%">{% if train.platform is not none %} {{ train.platform }} {% endif %} </td></tr> {%- endfor %} </table>) renders=18>
Error while processing template: Template<template=({%- if (state_attr('sensor.bicester_village_station_concourse_buses', 'calls') | count) == 0 %} Information is not available {%- else %} <table style="text-align: left"> <tr> <th style="width: 5%">Bus</th><th style="overflow: hidden; text-overflow: ellipsis">Destination</th><th>Expected</th> </tr> {%- for call in state_attr('sensor.bicester_village_station_concourse_buses', 'calls') %} <tr> <td>{{ call.service_description }}</td> <td style="max-width: 10px; white-space: nowrap; overflow: hidden; text-overflow: ellipsis">{{ call.destination }}</td> <td style="width: 20%; white-space: nowrap"> {%- if call.display_time[2] != ":" %} {{ call.expected_departure_time[11:16] }} {{ '(' }} {%- endif -%} {{ call.display_time }} {%- if call.display_time[2] != ":" %} {{- ')' }} {%- endif %} </td> </tr> {%- endfor %} </table> {% if state_attr('sensor.bicester_village_station_concourse_buses', 'messages') is not none %} <br /> {% for message in state_attr('sensor.bicester_village_station_concourse_buses', 'messages') %} <marquee behavior="scroll" direction="left">{{ message }}</marquee> {%- endfor %} {% endif %} {% endif %}) renders=30>
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 568, in async_render
    render_result = _render_with_context(self.template, compiled, **kwargs)
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 2198, in _render_with_context
    return template.render(**kwargs)
  File "/usr/local/lib/python3.11/site-packages/jinja2/environment.py", line 1301, in render
    self.environment.handle_exception()
  File "<template>", line 1, in top-level template code
TypeError: object of type 'NoneType' has no len()
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 570, in async_render
homeassistant.exceptions.TemplateError: TypeError: object of type 'NoneType' has no len()
Probably that both sensors. When the template gets reloaded, value is none.
So, do I need to use has_value() ?
Your templates should at first check, whether the attribute (already) exists or not. I have not much experience with has_value but in my logic it should work :innocent:
Thank you. It’s not working yet but I’ll get there.
Can you post your code? The error message is cumbersome to read.
Thanks @pedolsky
There are three parts. Apologies fir the formatting but it has become a bit mangled.
type: vertical-stack
cards:
  - type: custom:html-template-card
    title: Manorsfield Road (3)
    ignore_line_breaks: false
    content: >-
    title: Coach House Mews
    content: >-
title: Bicester Village Station
content: >-
  endfor %} </table>
content: >-
I have a Markdown Card to display calendar events, and using is iterable doesn’t throw errors:
{% if state_attr('sensor.anstehende_termine', 'termine') is iterable %}
  {% set blabla %}
  {% for termin in termine if termin.start is defined and termine is iterable %}
    {{ blabla }}
  {% endfor %}
{% else %}Calendar not available
{% endif %}
Despite making no changes, the error seems to have gone from my log files after my regular 2am restart. Time will tell if the problem returns.
I have suspected for a while that it takes multiple restarts or some period of time before dashboard changes are flushed through the system. As an example, watchman will report missing entities in lovelace for a while after corrections are made. After restarts or some time period the issues go away.
Watchman updates after reloading core config, I have a button to do this:
type: tile
entity: sensor.watchman_last_updated
tap_action:
  action: call-service
  service: homeassistant.reload_core_config
