Error doing job: Task exception was never retrieved
File “/srv/homeassistant/lib/python3.6/site-packages/homeassistant/helpers/entity.py”, line 199, in async_update_ha_state
“No entity id specified for entity {}”.format(self.name))
homeassistant.exceptions.NoEntitySpecifiedError: No entity id specified for entity Door Open
relevant section from my configuration.yaml:
binary_sensor:
- platform: gc100
ports:
'4:1': Doorbell
'4:2': Door Open
'5:2': Upstairs Rear Window Open
Why would there be no such errors for Doorbell or Upstairs Rear Window Open?
(I am the developer for gc100 so if this should be moved under the developer section in the forum that’s fine)
Did you find any solution? I keep getting these since at least a month ago, but I can’t see that there is anything wrong. All works just fine so I don’t give it much thought, but my log file is full of these errors.
As of today, I now seem to be getting this same error, but again, doesn’t appear to be affecting anything.
For me it’s on GPIO, not GC100, but still a binary sensor, so I think it’s related?
Up until today, I had 13 GPIO pins in use, no errors. Today I connected a 14th device (pin 5) and suddenly that one device, and no others, are throwing this error.
Everything about it is the same as the existing devices which had no issues. If you have any ideas, I’m all ears!
