Hi, would anyone have hints how to find the culprit for this error. Moved all automations even to config.yaml out from automations.yaml to see if it would give the line info but no. Had not updated HA instance in a while and some of the breaking changes likely pushing this.
Check the most recent automation you created. The problem is with its first action.
