I just noticed that my disk usage has suddenly been increasing rapidly:
This started almost exactly when I upgraded to 2024.4.1 (from 2024.3.3).
I first suspected my database, but that is under 2GB, and has not changed much since I last checked. However, I traced down a significant portion of the growth to the main log.
du -sh /homeassistant/home-assistant.log
I do have debug logging enabled, but that has been the case for over a year, and my log file has never grown like this.
logger:
default: info
logs:
homeassistant.core: debug
I haven’t changed much in the last couple weeks, so I’m not sure what is causing this. What can I look at to determine why this is happening (other than poring over this massive file)? Is there a record somewhere of when integrations were added, or had versions change from an update? I guess I’m wondering if an update caused a massive amount of logging suddenly for one of my integrations, or maybe I added something that I’m forgetting about (seems less likely as the time aligns nearly perfectly with the 2024.4.1 update).
