I am seeing this in the HA log file. As far as I can tell, it is causing no issues, no loss of functionality or anything of the sort, but clearly, something has gone wrong with something, I am just not sure what.
16-08-31 07:04:49 sqlalchemy.pool.NullPool: Exception during reset or similar
File "/home/hass/.homeassistant/deps/sqlalchemy/pool.py", line 636, in _finalize_fairy
fairy._reset(pool)
File "/home/hass/.homeassistant/deps/sqlalchemy/pool.py", line 776, in _reset
pool._dialect.do_rollback(self)
File "/home/hass/.homeassistant/deps/sqlalchemy/engine/default.py", line 420, in do_rollback
dbapi_connection.rollback()
sqlite3.ProgrammingError: SQLite objects created in a thread can only be used in that same thread.The object was created in thread id 1613231200 and this is thread id 1995722752
rpitera
(Robert Pitera)
August 31, 2016, 9:31pm
2
You have done it now; you’re infested with gnomes.
Seriously, the only thing I could find related was this; maybe it will point you somewhere?
opened 03:09PM - 24 Apr 16 UTC
closed 06:38PM - 21 May 16 UTC
Feature requests should go in the forum: https://community.home-assistant.io/c/f… eature-requests
**Home Assistant release (`hass --version`):**
0.18.2
**Python release (`python3 --version`):**
3.5.1
**Component/platform:**
sensor.gtfs
**Description of problem:**
I don't see any _actual_ issue here, but since I enabled the GTFS sensor, I often see in my logs a huge quantity of SQLAlchemy related errors. The component seems to be working fine (both in frontend and from automation rules), but…
**Expected:**
No error in logs
**Problem-relevant `configuration.yaml` entries and steps to reproduce:**
``` yaml
- platform: gtfs
origin: 3347699720881315
destination: 3347699720888336
data: tisseo_gtfs.zip
- platform: gtfs
origin: 3347699720888336
destination: 3347699720881315
**Traceback (if applicable):**
``` bash
16-04-24 17:03:35 ERROR (Thread-11) [sqlalchemy.pool.NullPool] Exception during reset or similar
File "/home/kernald/.homeassistant/deps/sqlalchemy/pool.py", line 636, in _finalize_fairy
fairy._reset(pool)
File "/home/kernald/.homeassistant/deps/sqlalchemy/pool.py", line 776, in _reset
File "/home/kernald/.homeassistant/deps/sqlalchemy/engine/default.py", line 420, in do_rollback
sqlite3.ProgrammingError: SQLite objects created in a thread can only be used in that same thread.The object was created in thread id 139793715386112 and this is thread id 139792746518272
16-04-24 17:03:35 ERROR (Thread-11) [sqlalchemy.pool.NullPool] Exception closing connection <sqlite3.Connection object at 0x7f2441952c70>
fairy._reset(pool)
File "/home/kernald/.homeassistant/deps/sqlalchemy/pool.py", line 290, in _close_connection
self._dialect.do_close(connection)
File "/home/kernald/.homeassistant/deps/sqlalchemy/engine/default.py", line 426, in do_close
dbapi_connection.close()
**Additional info:**
LOL. Yeah, maybe, if so they are not doing much damage apparently. Thank you for th
e link @rpitera
rpitera
(Robert Pitera)
September 1, 2016, 9:07pm
4
Best I could do - I found a few other links but they seemed so out of the loop and unrelated I didn’t bother.
Pro Tip: Leave shortbread cookies out near your Pi and then whack them with a newspaper. Gnomes can’t resist shortbread.
Well, you learn something new everyday. I will give that a shot and just take care of it that way.
bnetse
September 20, 2016, 7:19am
6
Did you find a solution to this?
I just set up a clean install of Home Assistant using the all in one installer for raspberry pi and I have this exact same error.
Currently the only thing I have modified is the lat long location and elevation in the configuration.yaml.
Nope, no solution found as of yet. But it wasn’t seemingly problematic either so it was not getting a lot of attention from me either.
