This might be a bug, but before I post to github I want to make sure I havent setup anything wrong from my side. I have setup Insteon Local with a single fanlink that works for the most part with delays here and there. I am running latest version of HA 54.0
2017-10-07 04:14:37 ERROR (MainThread) [homeassistant.helpers.entity] Update for fan.masterbed fails
File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/helpers/entity.py”, line 225, in async_update_ha_state
yield from self.hass.async_add_job(self.update)
File “/usr/lib/python3.4/asyncio/futures.py”, line 388, in iter
yield self # This tells Task to wait for completion.
File “/usr/lib/python3.4/asyncio/tasks.py”, line 286, in _wakeup
value = future.result()
File “/usr/lib/python3.4/asyncio/futures.py”, line 277, in result
raise self._exception
File “/usr/lib/python3.4/concurrent/futures/thread.py”, line 54, in run
File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/util/init.py”, line 306, in wrapper
result = method(*args, **kwargs)
File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/fan/insteon_local.py”, line 161, in update
resp = self.node.status()
File “/srv/homeassistant/lib/python3.4/site-packages/insteonlocal/Fan.py”, line 26, in status
status = self.hub.get_device_status(self.device_id, level=‘03’)
File “/srv/homeassistant/lib/python3.4/site-packages/insteonlocal/Hub.py”, line 347, in get_device_status
status = self.get_buffer_status(device_id)
File “/srv/homeassistant/lib/python3.4/site-packages/insteonlocal/Hub.py”, line 1056, in get_buffer_status
self.set_command_response_from_cache(response_record, device_from, response_record[‘cmd1’], response_record[‘cmd2’])
File “/srv/homeassistant/lib/python3.4/site-packages/insteonlocal/Hub.py”, line 489, in set_command_response_from_cache
command_cache = self.get_cache_from_file(device_id)
File “/srv/homeassistant/lib/python3.4/site-packages/insteonlocal/Hub.py”, line 411, in get_cache_from_file
with open(filename) as cachefile:
FileNotFoundError: [Errno 2] No such file or directory: ‘3FD993.state’
