Log Host full of - homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-xxx...xxx.mount: Deactivated successfully
Hi all,
I’m writing about these long list of message present in my Host Log.
I have little knowledge of dockers … I’m not a computer scientist.
Where do I start to analyze this problem.
I have a supervised homeassistant installation on a windows 10 machine with Virtualbox simulating a linux machine
Thank you all
Jan 22 14:00:40 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-157365b08ea583ce48086a592ac2e18687b472d055f797b7d157b3a4af2bd98e-runc.q0yLS1.mount: Deactivated successfully.
Jan 22 14:01:10 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-157365b08ea583ce48086a592ac2e18687b472d055f797b7d157b3a4af2bd98e-runc.0C1KRN.mount: Deactivated successfully.
Jan 22 14:01:40 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-157365b08ea583ce48086a592ac2e18687b472d055f797b7d157b3a4af2bd98e-runc.bFDeSj.mount: Deactivated successfully.
Jan 22 14:02:10 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-157365b08ea583ce48086a592ac2e18687b472d055f797b7d157b3a4af2bd98e-runc.qxaK0s.mount: Deactivated successfully.
Jan 22 14:02:41 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-157365b08ea583ce48086a592ac2e18687b472d055f797b7d157b3a4af2bd98e-runc.nw1V9Z.mount: Deactivated successfully.
NEW!!!
with this error in the host log
i found the correspondending docker
Now is all to undstend
Same issue here, …,.for me it seems to be the Adguard addon also
i reinstalled from 0 ADguard…no result
Nope, tried that also, even install older version like 4.6 or 4.7 and does it.
I remove the endgame addon and the messages disappeared.
I also notice Adguard not responding a lot…
I have a same issue with NodeRed integration.
HA api also crashed few times in the last couple days. I’m not sure that was the issue. I have set up more logs and waiting for crash again…
I have the same with EMQX, no crashes so far but a whole lot of log messages.
After some search effort I found similar logs which had something to do with the health check within the docker image. I have no clue what to do about it but it’s really annoying.
Update:
I checked the dockerfiles of NodeRed, EMQX and AdGuard and all of those have a HEALTHCHECK command, non of my other addons have it and non of them create this extreme amount of logs.
@frenck is this the expected behaviour? Is there something we can do to stop this?
I’m also seeing this with Node-Red and Tasmoadmin addons. Additionally my log is giving every few seconds udiskd error like this:
May 09 04:49:18 homeassistant udisksd[143]: udisks_mount_get_mount_path: assertion 'mount->type == UDISKS_MOUNT_TYPE_FILESYSTEM' failed
May 09 04:49:42 homeassistant udisksd[143]: udisks_mount_get_mount_path: assertion 'mount->type == UDISKS_MOUNT_TYPE_FILESYSTEM' failed
May 09 04:49:48 homeassistant udisksd[143]: udisks_mount_get_mount_path: assertion 'mount->type == UDISKS_MOUNT_TYPE_FILESYSTEM' failed
May 09 04:49:48 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-cb0794d6e6e9d256aca9442de7e9c8f0e2d30679734beedeea48f1d727c64c52-runc.52vHwQ.mount: Deactivated successfully.
May 09 04:50:12 homeassistant udisksd[143]: udisks_mount_get_mount_path: assertion 'mount->type == UDISKS_MOUNT_TYPE_FILESYSTEM' failed
May 09 04:50:12 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-1c020516677b7f21e2228e5b0c50ad6e0b6aa8ccc9e639b9070fe47070f0f55e-runc.rSmLkb.mount: Deactivated successfully.
May 09 04:50:18 homeassistant udisksd[143]: udisks_mount_get_mount_path: assertion 'mount->type == UDISKS_MOUNT_TYPE_FILESYSTEM' failed
May 09 04:50:18 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-cb0794d6e6e9d256aca9442de7e9c8f0e2d30679734beedeea48f1d727c64c52-runc.wuumwT.mount: Deactivated successfully.
May 09 04:51:12 homeassistant udisksd[143]: udisks_mount_get_mount_path: assertion 'mount->type == UDISKS_MOUNT_TYPE_FILESYSTEM' failed
May 09 04:51:12 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-1c020516677b7f21e2228e5b0c50ad6e0b6aa8ccc9e639b9070fe47070f0f55e-runc.gD9FcS.mount: Deactivated successfully.
I’m running on Yellow with:
  • Home Assistant 2023.5.2
  • Supervisor 2023.04.1
  • Operating System 10.1
  • Node-Red addon: 14.1.5
  • Tasmoadmin: 0.24.2
I have this issue and just found that it is related to vscode.
I wonder if this can explain some performance issues I’m experiencing.
no watchdog or start on boot.
Same problem on latest updated system (HAOS)
No adguard addon installed
This is annoying but completely normal. These log entries are related to docker’s health checks. See here.
A nice workaround to disable the noise:
# cat /etc/systemd/system/run-docker-.mount.d/10-silence.conf
[Mount]
LogLevelMax=notice
via
