Log Info every few seconds
Hi there,
I’m running HA 0.108.9 on Synology Docker and every few seconds I can see something like this in the log files:
All components of Homematic work like they should, but the logfile reports these infos.
The continue without end and I can’t see certain components, nearly all of Homematic.
What can I do to get rid of that ? Am I in trouble ?
Greetings,
Oliver
These are just information logs. If you want you can change the logging level to warning in your configuration.yaml file.
logger:
  default: warn
This will show warnings, errors, etc… but not info logs. You can see the available levels here:
You can even write an automation to change the level from the frontend:
log
input select:
logging_level:
  options:
  - error
  - warning
  - info
  - debug
Automation:
- id: logging_level
  alias: 'Logging Level'
  initial_state: true
    platform: state
    entity_id: input_select.logging_level
    service: logger.set_default_level
    data_template:
      level: "{{ trigger.to_state.state }}"
