Is there a log anywhere that shows what commands were successfully(?!) carried out by Voice Assist?
I have the Voice PE confirming that it ‘Turned lights off!’ - but, duh, the ones I wanted to turn off are still on
So, I’d like at least a way to look up, which lights were actually turned off instead.
Or is there a way where I could build a ‘log’ myself by setting up a helper that stores the announcement text - or maybe just the entity that was changed?
Try the following:
UI->Settings->Voice Assistant-> and for your assistant that was used (ex. the default one named Home Assistant) you’ll see 3-dots. Click on the 3-dots and click on Debug. This stores traces of the voice pipeline, so find the trace your after (based on time), or simply start a new session with your VPE and then come back to this debug. At the bottom is “RAW”. Within this you’ll find the entity that was turned on/off (or maybe it failed in its attempt).
