I’m having the same issue it’s a real pain as the hdd is constantly spinning over and writing the logs.
I found previous ref to this issue #18997 refers, and it’s stated that this is not generated from ASUSWRT component, it’s generated from the asyncssh python module that’s called by asuswrt.
Is there anyway to disable logging on asyncssh?
|2019-03-01 14:39:34|stdout|e[32m2019-03-01 14:39:34 INFO (MainThread) [homeassistant.components.device_tracker.asuswrt] Checking Devicese[0m|
|2019-03-01 14:39:24|stdout|e[32m2019-03-01 14:39:24 INFO (MainThread) [asyncssh] [conn=0, chan=67] Channel closede[0m|
|2019-03-01 14:39:24|stdout|e[32m2019-03-01 14:39:24 INFO (MainThread) [asyncssh] [conn=0, chan=67] Received channel closee[0m|
|2019-03-01 14:39:24|stdout|e[32m2019-03-01 14:39:24 INFO (MainThread) [asyncssh] [conn=0, chan=67] Received exit status 0e[0m|
|2019-03-01 14:39:24|stdout|e[32m2019-03-01 14:39:24 INFO (MainThread) [asyncssh] [conn=0, chan=67] Command: PATH=$PATH:/bin:/usr/sbin:/sbin && cat /var/lib/misc/dnsmasq.leasese[0m|
|2019-03-01 14:39:24|stdout|e[32m2019-03-01 14:39:24 INFO (MainThread) [asyncssh] [conn=0, chan=67] Requesting new SSH sessione[0m|
|2019-03-01 14:39:24|stdout|e[32m2019-03-01 14:39:24 INFO (MainThread) [asyncssh] [conn=0, chan=66] Channel closede[0m|
|2019-03-01 14:39:24|stdout|e[32m2019-03-01 14:39:24 INFO (MainThread) [asyncssh] [conn=0, chan=66] Received channel closee[0m|
|2019-03-01 14:39:24|stdout|e[32m2019-03-01 14:39:24 INFO (MainThread) [asyncssh] [conn=0, chan=66] Received exit status 0e[0m|
|2019-03-01 14:39:24|stdout|e[32m2019-03-01 14:39:24 INFO (MainThread) [asyncssh] [conn=0, chan=66] Command: PATH=$PATH:/bin:/usr/sbin:/sbin && ip neighe[0m|
|2019-03-01 14:39:24|stdout|e[32m2019-03-01 14:39:24 INFO (MainThread) [asyncssh] [conn=0, chan=66] Requesting new SSH sessione[0m|
|2019-03-01 14:39:24|stdout|e[32m2019-03-01 14:39:24 INFO (MainThread) [asyncssh] [conn=0, chan=65] Channel closede[0m|
|2019-03-01 14:39:24|stdout|e[32m2019-03-01 14:39:24 INFO (MainThread) [asyncssh] [conn=0, chan=65] Received channel closee[0m|
|2019-03-01 14:39:24|stdout|e[32m2019-03-01 14:39:24 INFO (MainThread) [asyncssh] [conn=0, chan=65] Received exit status 0e[0m|
|2019-03-01 14:39:24|stdout|e[32m2019-03-01 14:39:24 INFO (MainThread) [asyncssh] [conn=0, chan=65] Command: PATH=$PATH:/bin:/usr/sbin:/sbin && arp -ne[0m|
|2019-03-01 14:39:24|stdout|e[32m2019-03-01 14:39:24 INFO (MainThread) [asyncssh] [conn=0, chan=65] Requesting new SSH sessione[0m|
|2019-03-01 14:39:24|stdout|e[32m2019-03-01 14:39:24 INFO (MainThread) [asyncssh] [conn=0, chan=64] Channel closede[0m|
|2019-03-01 14:39:24|stdout|e[32m2019-03-01 14:39:24 INFO (MainThread) [asyncssh] [conn=0, chan=64] Received channel closee[0m|
|2019-03-01 14:39:24|stdout|e[32m2019-03-01 14:39:24 INFO (MainThread) [asyncssh] [conn=0, chan=64] Received exit status 0e[0m|
|2019-03-01 14:39:24|stdout|e[32m2019-03-01 14:39:24 INFO (MainThread) [asyncssh] [conn=0, chan=64] Command: PATH=$PATH:/bin:/usr/sbin:/sbin && for dev in `nvram get wl1_vifs && nvram get wl0_vifs && nvram get wl_ifnames`; do if type wlanconfig > /dev/null; then wlanconfig $dev list | awk 'FNR > 1 {print substr($1, 0, 18)}'; else wl -i $dev assoclist; fi; donee[0m|
|2019-03-01 14:39:24|stdout|e[32m2019-03-01 14:39:24 INFO (MainThread) [asyncssh] [conn=0, chan=64] Requesting new SSH sessione[0m|
|2019-03-01 14:39:24|stdout|e[32m2019-03-01 14:39:24 INFO (MainThread) [homeassistant.components.device_tracker.asuswrt] Checking Devicese[0m|
|2019-03-01 14:39:23|stdout|e[32m2019-03-01 14:39:23 INFO (MainThread) [asyncssh] [conn=0, chan=63] Channel closede[0m|
|2019-03-01 14:39:23|stdout|e[32m2019-03-01 14:39:23 INFO (MainThread) [asyncssh] [conn=0, chan=63] Received channel closee[0m|
|2019-03-01 14:39:23|stdout|e[32m2019-03-01 14:39:23 INFO (MainThread) [asyncssh] [conn=0, chan=63] Received exit status 0e[0m|
|2019-03-01 14:39:23|stdout|e[32m2019-03-01 14:39:23 INFO (MainThread) [asyncssh] [conn=0, chan=63] Command: PATH=$PATH:/bin:/usr/sbin:/sbin && cat /var/lib/misc/dnsmasq.leasese[0m|
|2019-03-01 14:39:23|stdout|e[32m2019-03-01 14:39:23 INFO (MainThread) [asyncssh] [conn=0, chan=63] Requesting new SSH sessione[0m|
|2019-03-01 14:39:23|stdout|e[32m2019-03-01 14:39:23 INFO (MainThread) [asyncssh] [conn=0, chan=62] Channel closede[0m|
|2019-03-01 14:39:23|stdout|e[32m2019-03-01 14:39:23 INFO (MainThread) [asyncssh] [conn=0, chan=62] Received channel closee[0m|
|2019-03-01 14:39:23|stdout|e[32m2019-03-01 14:39:23 INFO (MainThread) [asyncssh] [conn=0, chan=62] Received exit status 0e[0m|
|2019-03-01 14:39:23|stdout|e[32m2019-03-01 14:39:23 INFO (MainThread) [asyncssh] [conn=0, chan=62] Command: PATH=$PATH:/bin:/usr/sbin:/sbin && ip neighe[0m|
|2019-03-01 14:39:23|stdout|e[32m2019-03-01 14:39:23 INFO (MainThread) [asyncssh] [conn=0, chan=62] Requesting new SSH sessione[0m|
|2019-03-01 14:39:23|stdout|e[32m2019-03-01 14:39:23 INFO (MainThread) [asyncssh] [conn=0, chan=61] Channel closede[0m|
|2019-03-01 14:39:23|stdout|e[32m2019-03-01 14:39:23 INFO (MainThread) [asyncssh] [conn=0, chan=61] Received channel closee[0m|
|2019-03-01 14:39:23|stdout|e[32m2019-03-01 14:39:23 INFO (MainThread) [asyncssh] [conn=0, chan=61] Received exit status 0e[0m|
|2019-03-01 14:39:23|stdout|e[32m2019-03-01 14:39:23 INFO (MainThread) [asyncssh] [conn=0, chan=61] Command: PATH=$PATH:/bin:/usr/sbin:/sbin && arp -ne[0m|
|2019-03-01 14:39:23|stdout|e[32m2019-03-01 14:39:23 INFO (MainThread) [asyncssh] [conn=0, chan=61] Requesting new SSH sessione[0m|
|2019-03-01 14:39:23|stdout|e[32m2019-03-01 14:39:23 INFO (MainThread) [asyncssh] [conn=0, chan=60] Channel closede[0m|
|2019-03-01 14:39:23|stdout|e[32m2019-03-01 14:39:23 INFO (MainThread) [asyncssh] [conn=0, chan=60] Received channel closee[0m|
|2019-03-01 14:39:23|stdout|e[32m2019-03-01 14:39:23 INFO (MainThread) [asyncssh] [conn=0, chan=60] Received exit status 0e[0m|
|2019-03-01 14:39:23|stdout|e[32m2019-03-01 14:39:23 INFO (MainThread) [asyncssh] [conn=0, chan=60] Command: PATH=$PATH:/bin:/usr/sbin:/sbin && for dev in `nvram get wl1_vifs && nvram get wl0_vifs && nvram get wl_ifnames`; do if type wlanconfig > /dev/null; then wlanconfig $dev list | awk 'FNR > 1 {print substr($1, 0, 18)}'; else wl -i $dev assoclist; fi; donee[0m|
|2019-03-01 14:39:23|stdout|e[32m2019-03-01 14:39:23 INFO (MainThread) [asyncssh] [conn=0, chan=60] Requesting new SSH sessione[0m|
|2019-03-01 14:39:23|stdout|e[32m2019-03-01 14:39:23 INFO (MainThread) [homeassistant.components.device_tracker.asuswrt] Checking Devicese[0m|
|2019-03-01 14:39:12|stdout|e[32m2019-03-01 14:39:12 INFO (MainThread) [asyncssh] [conn=0, chan=59] Channel closede[0m|
|2019-03-01 14:39:12|stdout|e[32m2019-03-01 14:39:12 INFO (MainThread) [asyncssh] [conn=0, chan=59] Received channel closee[0m|
|2019-03-01 14:39:12|stdout|e[32m2019-03-01 14:39:12 INFO (MainThread) [asyncssh] [conn=0, chan=59] Received exit status 0e[0m|
|2019-03-01 14:39:12|stdout|e[32m2019-03-01 14:39:12 INFO (MainThread) [asyncssh] [conn=0, chan=59] Command: PATH=$PATH:/bin:/usr/sbin:/sbin && cat /var/lib/misc/dnsmasq.leasese[0m|
|2019-03-01 14:39:12|stdout|e[32m2019-03-01 14:39:12 INFO (MainThread) [asyncssh] [conn=0, chan=59] Requesting new SSH sessione[0m|
|2019-03-01 14:39:12|stdout|e[32m2019-03-01 14:39:12 INFO (MainThread) [asyncssh] [conn=0, chan=57] Channel closede[0m|
|2019-03-01 14:39:12|stdout|e[32m2019-03-01 14:39:12 INFO (MainThread) [asyncssh] [conn=0, chan=57] Received channel closee[0m|
|2019-03-01 14:39:12|stdout|e[32m2019-03-01 14:39:12 INFO (MainThread) [asyncssh] [conn=0, chan=57] Received exit status 0e[0m|
|2019-03-01 14:39:12|stdout|e[32m2019-03-01 14:39:12 INFO (MainThread) [asyncssh] [conn=0, chan=58] Channel closede[0m|
|2019-03-01 14:39:12|stdout|e[32m2019-03-01 14:39:12 INFO (MainThread) [asyncssh] [conn=0, chan=58] Received channel closee[0m|
|2019-03-01 14:39:12|stdout|e[32m2019-03-01 14:39:12 INFO (MainThread) [asyncssh] [conn=0, chan=58] Received exit status 0e[0m|
|2019-03-01 14:39:12|stdout|e[32m2019-03-01 14:39:12 INFO (MainThread) [asyncssh] [conn=0, chan=58] Command: PATH=$PATH:/bin:/usr/sbin:/sbin && cat /var/lib/misc/dnsmasq.leasese[0m|
|2019-03-01 14:39:12|stdout|e[32m2019-03-01 14:39:12 INFO (MainThread) [asyncssh] [conn=0, chan=58] Requesting new SSH sessione[0m|
I’m getting huge log files generated.
My home assistant is installed via docker on a synology.
