Hi All,
My log time is one hour behind than the time that shown in HA Dashboard and command line.
Country, timezone, location are correct
Hi All,
Been like that for as long as i know, it’s a noticeable “condition” in many aspects
i.e Last_Triggered(i recently got reminded upon), Sun-Integrations, OS(Host) file system etc.
UTC vs GMT , CET
Your specific case, could maybe be “solved” in Your Profile Page
But in short, HA uses UTC on the OS-level, and some extend Core
The screenshot has same time as it is right now. Its so weird…
Have you change from daylight saving time recently and not restarted HA since then?
HA can have issues with applying that change on a running system at times.
Ohh I restart HA many times because of updates. Also reboot whole system (os)
I’ve rebooted multiple times since
Ok. shutdown the system. Moved to a TV. connected to TV and checked the bios. Because I migrated from RPI4 to Dell 3050 I didn’t check the Bios time…
Bios time was different. changed it, put system back in his rack. Restart and problem was solved…
